Its after selecting the TV or Movies library view.
Cant be network delays as my connection speed has not changed and the NUC is connected via ethernet.
Hello, I've since moved from Windows to Libreelec ever since v17 to the now new Beta V18 "hide progress of library updates" option does not work. Everytime the library updates the progress bar comes up stopping you doing whatever you are doing.
Does anyone know if this will ever be fixed. I've a Windows machine and several Kodi boxes running Libreelec and all are the same.
2018-09-17, 23:20
(This post was last modified: 2018-09-17, 23:21 by beeswax.)
I can confirm the huge delays introduced in opening libraries recently. Build #911 was fine, for example my 'TV Shows' library opens in ~2s. Update to #912 and it sits on a blank screen for over a minute before the list appears. Problem remains in #916, I normally use Aeon Nox but it's the same with default skin. Intel NUC, wired ethernet (although it's powerline). Problem improves somewhat if I move the NUC so I can cable it straight into the router however it's still >10s compared to ~1s with #911. So it seems a slower network connection exacerbates the problem, whatever it is.
I could really use those DVBViewer fixes in #912 to as well!
Milhouse
Retired Team-Kodi Member
Regarding the Movie/TV Show delays - can someone provide a debug log??
About the only change in #0912 that might make sense is the range-based loop change, maybe it now loops unnecessarily wasting time - check if CPU load is high while you are waiting.
I'm not seeing a problem on any of my test machines (RPi3+, NUC, Rev3700), all of which have a MySQL backend.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
