Per my PM, happy to be a guinea pig on 3D.
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
Cheers. I have made some progress, and we found out what was wrong with 3D signalling / autoswitching.
The same regs are used for DV and 3D > gxl. In hdmitx, AML was checking DV capabilities after 3D, which meant that even if 3D should have been signalled it wouldn't be.
Sam
How does the Vero 4K handle UHD rips playing to a 1080p projector. My panasonic UHD bluray players down-res the 4K content to 1080p, when playing through my 1080p projector. Also does HDR to SDR conversion. Does Vero 4K do that?
Yes — the output would be clamped at 1080p.
There is indeed HDR to SDR dithering.
There will also be some colour calibration options coming in the next update which will be released in a few days
Sam
Skank
Posting Freak
I'm gonna take the jump as soon as 3d is included :p
2017-12-28, 20:55
(This post was last modified: 2017-12-28, 20:56 by t2ffn.)
Don't wait, its a great box. I now need to swap my other chromeboxes for these so I can play 4K on more than just the 1 TV I have with the Vero 4K. They're also tiny, so very easy to mount behind the TV on wallmounts etc.
@ Sam, I'd be interested to know if we could get some other approved power supplies than the bundled one. It's fine, but would prefer a low profile (UK) plug or could it run off a USB > power cable so it could be plugged into a slim USB plug like an Apple plug?
