Wondering if did 3D MVC ever become a thing or no?
2018-06-26, 09:24
(This post was last modified: 2018-06-26, 09:29 by zgotenz.)
Vero 4k ordered, hope have it at home in 2-3 weeks (web says out of stock, shipping 13th July).
Any one knows how does Eminence skin works on it? Its my favourite Skin on my actual HTPC for Kodi, ordered the Vero 4k as no good APU for 4k HDR out to mount a new HTPC hehe.
Will CEC work with AVR between TV and Vero 4k? I'll have Vero 4k connected to Sony STR-DN1080p and it to my OLED 55B6
Sam is on vacation, maybe that’s why you get the delay in ordering...
CEC should just work fine
Skin I got no idea sorry...
LG 77G1 • Onkyo TX-RZ70 • Q Acoustics F:2050i C:2000Ci R:2020i A:QI65C • 2x BK Elec XXLS400-DF
Vero V (OSMC) • Nvidia Shield TV Pro (2019) • Sony UBP-X800M2 • Sony PlayStation 5
We had a surge of B2B orders and ran out of stock, so it's a good time to take a holiday as well.
Some of our resellers still have units in stock.
gpmc
Junior Member
Updated Vero 4K+ announced.
Waiting for Sam to post new characteristics.
2018-07-25, 17:47
(This post was last modified: 2018-07-25, 17:48 by wrxtasy.)
At first (Github) glance looks like a Gigabit Ethernet equipped S905D minus the DVB.
Any improvements in the passive heat sink used ?
Chipset cooling is always a major concern with AMLogic hardware.
Heatsink is a bit bigger. We managed to introduce good thermal governing for the CPU a couple of months ago and this resolved issues for those using things like newsgroup downloaders (extracting can be CPU intensive). There were some reports of issues with the Mimic skin causing heat so we will soon introduce some GPU based governing as well as initial reports have been positive.
Cheers,
Sam
Order placed. Thanks Sam!
Brill, we'll send you an email when this ships
Sam
Can you tell me if Hue add-on works good with it in ambilight mode? Also for HDR? Not hyperion as it is too complicated to set up and has issues with hue brightness. I know there are some issues with hardware acceleration and because of this it didn't work correctly (wight now on android I have to disable medicacodec (surface).
I would order this as soon as I know it works. Thanks Sam.
