Downloaded kodi, when i launch the application, i get an error message below
“Kodi” is damaged and can’t be opened. You should move it to the Trash."
Ok, still need the rest of the information I asked for. Follow that first link.
Have you tried downloading again... in case the corruption occurred during the download?
downloaded using google chrome. mac is os sierra 10.12.5. tried multiple times using different browsers
nickr
Retired Team-Kodi Member
I believe you have to turn off "gatekeeper" on OSX.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
currently under security and privacy app store and identified developer is selected
HI all, sorry to be a pain.
I'm very new to this and have the same issue error message when trying to install Kodi on my mac.
Does anyone have a fix to this they can help me with ?
thanks in advance.
Hi I have just tired that and still the same error message. I'm running mac OS Sierra which does not give the option to install software from anywhere , do you think this could be the problem?
