2018-09-03, 15:33
Maybe it's hardware related, I am on nvidia 1030. Which hardware do you have?
(2018-09-15, 17:44)MrNike Wrote: I got the same Problem.The good new is that the issue doesn't affect only AMD platforms...
Win 10 Pro - Intel Pentium G4560 (OnBoard Intel HD 610)
Kodi 18 Beta 2 - 64 Bit
DXVA Deinterlacing is not working. Kodi 17 works fine.
Greetings
MrNike
(2018-09-15, 17:44)MrNike Wrote: I got the same Problem.I did a new install with Beta 3 and the deinterlace is working again. My Problem probably was not related to the discussed issue.
Greetings
MrNike
(2018-10-07, 16:28)MrNike Wrote:I hope is going to work also on my AMD based system. I will report here back as soon as I will be able to try the new build.(2018-09-15, 17:44)MrNike Wrote: I got the same Problem.I did a new install with Beta 3 and the deinterlace is working again. My Problem probably was not related to the discussed issue.
Greetings
MrNike
Greetings
MrNike
(2018-10-22, 09:17)axlt2002 Wrote: Unfortunately I have to report back that on my setup the de-interlacing issue still persists...Does it work with Windows 7 and the default AMD drivers on this system? Seeing yet another AMD driver breakage way too often ...
I really hope that this will be fixed for the official release of Leia...
(2018-10-22, 21:01)fritsch Wrote:Hi fritsch,(2018-10-22, 09:17)axlt2002 Wrote: Unfortunately I have to report back that on my setup the de-interlacing issue still persists...Does it work with Windows 7 and the default AMD drivers on this system? Seeing yet another AMD driver breakage way too often ...
(2018-11-04, 18:27)Darker Wrote: I also have exactly this problem. On kodi 16, during development version PVR stream was interlaced. Then near the end the problem was suddenly sorted and works fine. Now on Leia it is the same again, I wont repeat what other guys already said here. I have a fairly low spec htpc with a Radeaon HD 5760 and an intel CPU."Happy" to read that I'm not the only one...Let's cross our fingers...it seems that the first official release of Leia is near...despite this issue...
(2018-10-22, 21:01)fritsch Wrote:Hi fritsh...do you know if someone is working on this bug? Kodi 18 first release seems approaching...(2018-10-22, 09:17)axlt2002 Wrote: Unfortunately I have to report back that on my setup the de-interlacing issue still persists...Does it work with Windows 7 and the default AMD drivers on this system? Seeing yet another AMD driver breakage way too often ...
