2018-02-04, 01:19
(This post was last modified: 2018-02-04, 05:02 by nickr.)
Is there a way for Kodi to make the coverart for a Collection look different then just a regular movie? I am using the regular kodi skin. Just want it easier to spot a collection when scrolling through movies.
This has been updated with Kodi 18 as well by default.. but you will need to run my script library helper for it to set the artwork.
O and you will need to rescraped your library under Kodi 18 for it download the artwork.
olympia
Team-Kodi Member
This will be fixed in Leia eventually and set artwork will be set automatically. You will also be able to choose between scraped artwork.
Thank you for the help. It is much appreciated.
Yes, that is clear.
I have also experienced that. Most recently when I was playing with Live TV Logos.
It seems to be a little glitch in the way Kodi cache's artwork, and has been mentioned by the developers a few times. All you need to do is wait, and they will change. Best to restart Kodi, and leave it running for 24hrs and Kodi will sort it out.
Thanks again - it was driving me mad
