2019-04-09, 16:41
That genre is the most common genre. A TV Show or a game show is 90% of what you can watch
(2019-04-10, 22:32)Dumyat Wrote: Restarting box and updating the guide data yesterday seems to have done the trick. Last night's recording and tonight's two all showing correct guide data.....
Will bear this mind for future reference as well.
Cheers
(2019-04-10, 22:45)phunkyfish Wrote:Ok, might have spoken too soon, as last night's recording doing the same thing. It seems to be showing programme details towards the end of set recording period (including 45mins of padding). Main recording time was from 9pm to 10pm with 5mins padding for the start and 45 mins padding at the end. Programme details being displayed are for the local news item broadcasting from 22.30-22.35pm. I've just checked some previous recordings where the same thing has happened and at least 3 recordings that started at the same time are also showing the same local news description for the recording details. So, I'm wondering if the padding that has been set is causing this behaviour? If it helps, I have screen shots which I can PM to you. I'd post them here, but looks like adding an image has been updated on the forum and can't resize to show a side-by-side comparison. Don't want to fill this thread up completely with my stuff....(2019-04-10, 22:32)Dumyat Wrote: Restarting box and updating the guide data yesterday seems to have done the trick. Last night's recording and tonight's two all showing correct guide data.....
Cheers
If it happens a lot let me know. I doubt it's addon related but I've been proven wrong before
(2019-04-12, 15:15)Dumyat Wrote:(2019-04-10, 22:45)phunkyfish Wrote:Ok, might have spoken too soon, as last night's recording doing the same thing. It seems to be showing programme details towards the end of set recording period (including 45mins of padding). Main recording time was from 9pm to 10pm with 5mins padding for the start and 45 mins padding at the end. Programme details being displayed are for the local news item broadcasting from 22.30-22.35pm. I've just checked some previous recordings where the same thing has happened and at least 3 recordings that started at the same time are also showing the same local news description for the recording details. So, I'm wondering if the padding that has been set is causing this behaviour? If it helps, I have screen shots which I can PM to you. I'd post them here, but looks like adding an image has been updated on the forum and can't resize to show a side-by-side comparison. Don't want to fill this thread up completely with my stuff....(2019-04-10, 22:32)Dumyat Wrote: Restarting box and updating the guide data yesterday seems to have done the trick. Last night's recording and tonight's two all showing correct guide data.....
Cheers
(2019-04-13, 12:00)djnata Wrote: 3.22.0 version channels dont work again... "No Channels Found"
(2019-04-16, 17:07)phunkyfish Wrote: @Dumyat, I’ll have some time this weekend to look at your issue if you want to create a separate thread or github issue.Ok, cool. Soz for the delay. I deleted a couple of the affected recordings/completed timers before I took a screen capture, which I wanted to include. I have another timer set for tomorrow night, so will be sure to make some screen captures. I'll create a separate thread or post on the git.
(2019-04-23, 20:13)Peekstra Wrote: I finally got the change to upgrade to Kodi 18 and thus the new Enigma PVR client. However, the "Use channel numbers from backend" doesn't seem to be working anymore. Is this a Kodi issue or something of the PVR client? Thanks!
