I have the same issue on rPi 3. ScummVM seem to be installed but when I search for it RUN is grayed out. Anybody?
Hi Guys,
Exactly same problem here.... not sure if it's something I can't see but there is not "run" button on the add-on itself and no way to choose folders or recognize folders with ScummVM games, I would appreciate any input !
Hi ZachMorris,
Thanks for your help ! Unfortunately I followed your instructions with no luck, i tried with a few games:
I ssh into my kodi instance
Roms/Simon the Sorcerer/vi simon.scummvm
simon1
But on the kodi interface, I go to my games folders on the Games section, and no files with the .scummvm extension are displayed... I can see .rom files or .exe for example.
Anyways thanks for trying to help us !
Carles
Hmm. I didn't have to do anything to have the files show up. I'll also note ScummVM shows up as a game emulator addon on OSX, and if I go to the addon info window, and press run, ScummVM interface will startup.
the addon looks working - but I am not able to load some game
this is known for a while but we have no solution for that
could also a libretro problem
I just update CoreElec to 9.01 and then updated ScummVM plugin. Reboot. And now I can see it in add-ons menu.
Just click and hold the mouse button to pick up or use stuff.
Right click goes to inventory.
That’s pretty much all you need to know.
Enjoy!
