2019-09-21, 19:31
(This post was last modified: 2019-09-21, 20:13 by DarrenHill.)
Hi, I'm not sure how or where to post this, sorry beforehand.
The m@ive C@nfirmation with K@rry Washingt@n, when the m@ive plays it shows the "The Confirmation w/Cliv@ Ow@n" instead
How can that be fixed??
Peace be with you!
Mod edit - stupid fonts and colours removed.
Klojum
Lost connection
Does your keyboard have an @-problem?
2019-09-21, 20:00
(This post was last modified: 2019-09-21, 20:12 by DarrenHill.)
Before you go any further, please stop posting in stupid fonts and symbols. We can't help you if we can't read what you post.
Why wouldn't you be allowed to post names?
Klojum
Lost connection
Thread moved to the Metadata section for now.
For movies with similar names where the wrong one is getting picked up, normally we would add the year. But as in this case the year is also the same, the scraper makes its best guess, in this case wrongly.
What you need to do is navigate to the movie, then open its context menu (long-press on it) and select information. From the page that opens up go across to the refresh menu option and select that then put yes to refresh from the internet. You should then be presented with a list of matches from the database, and this time select the correct one.
By the downloaded app, do you mean the Downloader app from the Amazon Appstore? If so then that's fine, but not really relevant here as it's just the simpler way to get non-store apps sideloaded onto the Fire TV devices.
DarrenHill: Yes "Downloader app from the Amazon Appstore"
Thank you for the advice you gave me!
