Hello hope you can help me here downloaded BBC IPLAYER most things seem to work Ok except being able to watch live TV I am using WIN7 64 on a laptop been here for about 3 weeks making very slow progress but XBMC looks really good and will do everything I need it to do and also free up a lot of space I use at the moment
Hello everybody I have loaded Iplayer and most thing seem to work on the old programmes but live TV I get nothing I am not in UK but have DNS on my laptop
For what it's worth, I also use Get iPlayer Automator. I can grab a programme and it will add the show and thumbnail right to iTunes. Might there be a 'fix' in that code?l
OK - found a way to fix it, but getting intermittent results on one of my systems.
Give me another couple of hours and I should have a fix...
2014-04-25, 17:14
(This post was last modified: 2014-04-25, 17:17 by J@CKY.)
Hi, I am new to XBMC. Recently bought an OUYA as my XBMC box, SPMC installed
I have difficulties when using the iPlayer addon. thumbnail grey out mentioned in the threads above is one thing. But for me, I have playback issue as well. While I can play contents from the beginning without problem, whenever I fast forward, the video just frozen at the same frame, but audio keep running Strangely though, I can access XBMC settings and menu without problem. So that means the application was not frozen, XBMC still running, but the video just refused to show up.
I then stopped the playback, go back to video addon -> iPlayer play the same video by resuming to the last position, this time there was just no video. I got stuck in the XBMC menu page, background became grey instead of blue (the skin default beground), audio keep on playing, just no video. Again, the application seems to be running, not frozen, but video not playing
Eventually, I have to go back to iPlayer add on page, remove the resume point, play from the beginning, then it works. But then, I cannot fast forward the position where I left coz of the issue mentioned above.
Anyone came across this issue before? Any suggestion to sort it out? I have the same issue with ITV add on as well. But haven't had any problem with other online content addon (e.g. icefilms)
Yeah I was experiencing that last weekend on my Ouya. I installed the beta 4 of XBMC 13 and it handles things better. Not perfect but not as disastrous as SPMC.
I have no idea what the source of the problem is.....just that things are a lot better in Gotham! There are a few niggles with Gotham but it is a beta after all and all my addons are working. Surely it's worth a go before you get rid?
Hitcher
Team-Kodi Member
Thanks, updated on my repo.
