ruuk
Team-Kodi Member
For some reason when the addon was updated, the dependencies did not install. Try un-installing it and re-installing it.
...tried uninstalling and installing again. No soap.
Can anyone attach a zip of xbmcswift2 for me to install? I can't find it in XBMC's repo and the zip I get from Github doesn't have the "correct structure"...
Oh, thanks for the pointer. Are these zips installable or do I have to unzip them manually?
ruuk
Team-Kodi Member
Since they are modules, I don't think you get any notification that they installed, they will just do so silently.
If for some reason that does not work, you can unzip them into the addons folder and restart XBMC.
ruuk
Team-Kodi Member
If you try to install an addon from a zip file, the zip file must contain a folder named with the addon ID. So for instance script.module.picasa. This folder must be what goes into the addons folder.
ruuk
Team-Kodi Member
Normally installing directly from the zip is a Bad IdeaTM, but since your install seems to be frelled...
Can anyone tell me how this plugin can read photos uploaded to Google Drive? From what i've seen i can only read photos uploaded directly to picasaweb/google+ even though they integrated drive pictures.
