2015-10-29, 09:13
(2015-10-29, 09:02)tomer953 Wrote: OK Thanks, About the labels, I have togglebuttons\buttons inside a grouplist, right now they have:
<label>-</label>
Should I edit it to something else? I don't want any text to appear (just the texture...)
If you've set all labels to be "-" the script will see all buttons as equal and cannot detect that the user is actually navigating on the OSD.
Just set some labels on there, e.g. osd1, osd2, osd3 etc. You don't have to display them, just set the label on the control. Same as in confluence skin which also has labels set on the player controls but displays images and not text
