2018-08-27, 20:11
(2018-08-27, 20:07)purplehorseshoes Wrote: Thanks for your reply! One more question, if I enable "Use Task Scheduler on Windows", should I be able to see the scheduled task within the Task Scheduler? I'm not able to find the task if so.I can't guarantee that the Windows Task Scheduler code is working perfectly. I haven't fully tested it for a while.
What I tried to do was create tasks that weren't dependent on Kodi still running when the recording takes place.
So most of the task handling is offloaded to Task Scheduler.
I think you can still delete the jobs from within Maintenance but I'm not sure.
