2019-04-22, 14:23
(2019-04-22, 14:13)zloty777 Wrote: Hi
I have installed recorder and face some concerns.
I configured 'all' in recorder settings but nothing appears in plugin folder. I can't see epg list nor programs nor groups.
When I schedule timer in IPTV SC it confirmes it has been scheduled
no errors so far
but nothing is recorded and in logs I have this https://paste.kodi.tv/emalonefus.kodi
appreciate any helps
PS
everything works fine in IPTV, full epg and can choose each channel from it
ignore there is error in first line of xmltv file
If you have no channels and no programs in
IPTV Recorder \ Channel Groups \ All Channels
then there is a problem reading your xmltv and m3u files.
Did you restart Kodi and wait 60 seconds before IPTV Recorder loads the xmltv and m3u file?
There should be some errors in kodi.log about plugin.video.iptv.recorder if that failed.
If it loaded ok there should be at least 3 files in
userdata\addon_data\plugin.video.iptv.recorder
channels1.m3u, xmltv1.xml and xmltv.db
