2021-05-04, 02:56
(2021-04-27, 16:38)MrPatate Wrote: Really happy to use every Day kodi and find many function i appreciate.I'm having the same problem on Kodi 19.
I actually use kodi 18.8 on my nvidia shield tv with catchup tv and more and iptv manager, work really fine and it's à real pleasure.
Now i will try to record some program with iptv recorder, after some problem with ffmpeg i was able to find the Good android version and my epg show fine in iptv recorder.
Try to put my record on a network attached storage and seems the config work well.
But.....
When i try to record a programm in iptv recorder screen, this one begins, create the folder for this programm, a json file and a ts file but the ts file was empty.
When i want to record something, i have a notification for the begining of the record and just after a notification for the end of the record, but like i said before only have create thé file but do not record anything.....
Where can be the issue ?
I used the plugin.video.iptv.recorder-1.0.zip file from here:
https://github.com/Publish3r/repository....v.recorder
I used the prebuilt-binaries armeabi-v7a ffmpeg file from here:
https://github.com/WritingMinds/ffmpeg-a...tag/v0.3.4
I created a folder for IPTV recordings on my USB hard drive that is attached to my Shield TV and used for OTA recordings.
Did I use the right files for my Shield TV?
