2018-11-09, 06:39
(2018-11-09, 03:02)Snickerdoodle Wrote: ... scratch that. I just tried the latest beta of Leia anyway and so far so good.
I just saw that the Leia Beta 5 released around the same time I tried Leia on mine. Not sure if I tried Beta 4 or 5, so I'll try it tonight and see if that fixes my issue with 24p content.
***UPDATE***
After installing the Leia Beta 5 it seems that the problem with 24p content is fixed...but now it won't play 4k (which I didn't have a problem with before). When I play a 4k video, it switches the resolution to 4k for a second, then returns me to the home screen for a second, then plays the video correctly but in 1920x1080 resolution. I have all the resolutions whitelisted except for the 720 ones.
***UPDATE 2***
I removed everything from the Whitelist and now it is switching to the correct frame rates and playing smoothly.
I have a question though. If I let the movies/shows play at 24p, with the auto frame rate switching, is that better than letting it go to my QLED (2017 Q7f) at 60p (auto frame switching off)? I prefer smooth motion
