2021-03-02, 11:56
(2021-03-02, 10:13)Kodroid Wrote:I stand corrected - its actually avc mkv similarly to what was reported by someone in this thread before. v18 just skips 30 sec into the file right away, v19 starts from the start but skips a second or two every 5 sec. Almost like a container problem... The file specs:(2021-03-01, 12:58)someuser08 Wrote: I must have missed something, but recently (at some point in the last couple of months?) majority of my AVI files (xvid codec) have stopped working on my stick. I used to use v18.9 (where its started freezing completely), but its the same with v19 (although it would just skip a second or two constantly instead of freezing). Is that due to amazon update? Thanks.I have the update people are complaining about and nothing has happened to my AVI files. I just tested it myself. I'd post logs when you try to play such files. That's the only way for anybody to confirm what you claim.
Format : Matroska
Format version : Version 4
File size : 619 MiB
Duration : 23 min 10 s
Overall bit rate : 3 738 kb/s
Encoded date : UTC 2020-03-28 22:28:34
Writing application : mkvmerge v44.0.0 ('Domino') 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23 min 9 s
Bit rate : 3 607 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.073
Stream size : 598 MiB (97%)
Writing library : x264 core 157
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=24 / lookahead_threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=48 / keyint_min=4 / scenecut=0 / intra_refresh=0 / rc_lookahead=48 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.75 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=5000 / vbv_bufsize=10000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:0.80
Language : English
Default : Yes
Forced : No
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -41 ms
Stream size : 21.2 MiB (3%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 22 min 50 s
Bit rate : 166 b/s
Count of elements : 495
Stream size : 27.8 KiB (0%)
Language : English
Default : No
Forced : No
