i started to develop a script to connect from xbmc to my emuleplus client and control it... (20-04-2005 now support also emule and some mods)
http://cvs.sourceforge.net/viewcvs.py/xb...c-ecp-new/
i'm very new to python and xbmc... sooo i wait for any suggestion...
bye
sambarza
you say your new to python and xbmc? no way!
that's scripts brilliant, not only does it function well it looks great. i can't wait to see your next project!
(sambarza @ april 03 2005,19:18 Wrote:xbmc-ecp screenshot
the control list you have in the screenshot would benefit from the new label2 funtionality.
http://home.no.net/thor918/xbmc/xbmcgui.html#listitem
the label2 is the greyed-out text you see on the right of some of the lists. i think the numbers would go better in it. you may want to wrap the call to that in a try: catch: though since older builds will not have the new control lists.
how can i use this feature? i need to compile from cvs version?
thanksssss
sambarza
hi!
no, using last build (april 1) should be enough!
cu lolol
hi again!
i like your script-idea very much but not testet yet...
does it run with any version of emule including a webserver?
i run morph xt 6.4 i dont want to change that...
i read in cvs there are no icons yet: i made some, here:
download from rapidshare maybe they could be used? :o :agree:
greets lolol
i'm using new build with new listcontrol ... very very good (see new screeshots)
thanks for the icons i will use :thumbsup: maybe i will need also icons for status of download files (complete downloading etc etc...
if morph use the same templates of emuleplus there are no problems... probably...
ohhh a wizard... thats a neat idea... i dont think ive seen any other script do that :-)
the interface is looking pretty slick
hi!
no problem, status icons will follow....
i think i'll make them tonight...
ps: still had no time to test th script
cu lolol
hi!
great work... what icons do you need for the download status exactly?
i would think these:
- downloading
- paused
- stopped
- waiting
- finished
in what size should these icons be?
cu lolol
mmmhh... i think i will not have so much time to implement... i will ask you when necessary thanks
can you make a smart logo (like "xbmc-ecp") to put on the main screen in the top left?
:bowdown:
i can do a logo, ok
i'll post it here, when i finished it.
cu lolol
hi!
here is a first try of logo for this script. its png 24 bit.
link:
download
what do think about?
cu lolol
