Hello
When VDPAU is used for decoding for TS stream playback (mpeg4-avc, recorded from DVB-T source via mythtv), then screen output have nasty artifacts.
No artifacts, when using "software" for decoding.
1. "Latest" is NOT a revision, of ANYTHING! (See below)
2. Linux Distribution and Version (eg. Ubuntu 8.04, Gentoo 2007.0-r1, etc)
-> ubuntu based distro named Mythbuntu 8.10 (
http://mythbuntu.org/8.10/release)
3. Architecture (eg. i686, x86_64, etc. See below.)
-> i686
4. Install Method (PPA, RPM, build.sh, manual, other)
-> make distclean; svn up; ./configure; make
5. SVN Revision (See below.)
-> 19318
6. Detailed Instructions to Reproduce the Problem (The more specific the better.)
-> video playback have artifacts when using VDPAU for decoding
7. FULL Debug Log (Please use your favorite paste site! See below.) << NOT OPTIONAL!
http://rapidshare.com/files/218616637/xbmc.log.htm
8. Backtrace (Only attainable if XBMC has crashed. See below.)
-> no
9. Compiler Output (Only useful if XBMC doesn't build. See below.)
-> no
10. kernel
-> Linux htpc 2.6.27-7-generic #1 SMP Tue Nov 4 19:33:20 UTC 2008 i686 GNU/Linux
10. GPU
-> VGA compatible controller: nVidia Corporation GeForce 9500 GT (rev a1)
10.1 TV-OUT
-> S-Video
11. CPU
-> Intel® Core2 Duo CPU E8400 @ 3.00GHz
12. RAM
-> 2GB DDR3
13 Motherboard
-> Gigabyte GA-EP45T-DS3R
14. Video codec & containter
-> codec: "MPEG-4 AVC"
-> container: MPEG2TS
15. Sample file
http://rapidshare.com/files/21857865...ample.mpg.html (86MB)
16. Videofile location
-> local HDD
17. playback output (captured from TV screen via camera)
http://rapidshare.com/files/21861306...pture.avi.html (29MB)
