ok guys please forgive me, having a bit of a brain fart and I cant seem to get the sopcast.text file updated to work with sports devil. I think I am getting the move command wrong some where, probably due to the passive headache I am fighting off and a serious lack of sleep. By the way I am running crystalbuntu and when I am trying to access other streams from the actual addon itself they all seem to fail. I will look at it more tomorrow. Thanks for the help.
can you please add a manual entry channel
like sop://broker.sopcast.com:3912/***** where the user can enter the channel number?
Hi, really awesome work!
What's new on the 0.2.7?
Thanks for your time
can anyone do this for windows?
I'm getting script failed right after I select a channel to play
does it work on ubuntu x64?
here's the debug log:
http://pastebin.com/c2iPssT7
(2012-05-20, 04:59)diego-ch Wrote: [ -> ]I'm getting script failed right after I select a channel to play
here's the debug log: http://pastebin.com/c2iPssT7
works like a charm on ubuntu x64 builds.
do you have sopcast libs installed? check the first post for download location.
This plugin is using the sp-sc-auth executable from sopcast.com. You can try test it from shell.
A simple example of sp-sc command line.
./sp-sc-auth sop://broker.sopcast.com:3912/6001 3908 8908 > /dev/null &
Start to transfer channel 6098, and you can play it on 8908 with VLC or mplayer
by open the url:
http://localhost:8908/tv.asf
can you tell me after downloading this link:
http://www.tusfiles.net/oawtvyvvvpyo
how to install in the apple tv 2 ,i have installed xbmc,
so how to do it? to see the romanian channels !
thank you!
regards,
suceava20
(2012-05-29, 02:57)suceava20 Wrote: [ -> ]can you tell me after downloading this link:
thank you!
regards,
suceava20
This add-on is only worinkg in Linux (sp-sc auth is only avaliable in Linux).
oh,thanks..sorry,i was looking for appletv2 ,
0.26 seems to work ok but there are 2 problems with 0.27:
1. Once a stream is opened it doesn't seem to want to die. I can stop the stream using the player controls briefly but then it restarts after a second or so.
2. The "Enter Channel ID" option doesn't seem to work at all. The script fails.
The add-on is updated to 0.2.9 version, diego-ch with the new version all is working correctly? Thanks!
XBMCbuntu current stable
Just installed 0.2.9 and ran for the first time. It locked up, had to reset. Below is the debug log, hopefully it can help.
09:56:39 T:3042912000 DEBUG: ParentPath = [plugin://plugin.video.xsopcast]
09:56:39 T:3042912000 DEBUG: StartScript - calling plugin X-Sopcast('plugin://plugin.video.xsopcast/','0','')
09:56:39 T:3042912000 INFO: initializing python engine.
09:56:39 T:3042912000 DEBUG: new python thread created. id=14
09:56:39 T:3042912000 DEBUG: WaitOnScriptResult - waiting on the X-Sopcast plugin...
09:56:39 T:2790210416 DEBUG: Thread XBPyThread start, auto delete: 0
09:56:39 T:2790210416 DEBUG: Python thread: start processing
09:56:39 T:2790210416 NOTICE: -->Python Interpreter Initialized<--
09:56:39 T:2790210416 DEBUG: Process - The source file to load is /home/brad/.xbmc/addons/plugin.video.x-sopcast/default.py
09:56:39 T:2790210416 DEBUG: Process - Setting the Python path to /home/brad/.xbmc/addons/plugin.video.x-sopcast:/home/brad/.xbmc/addons/script.module.xbmcswift/lib:/home/brad/.xbmc/addons/script.module.t0mm0.common/lib:/home/brad/.xbmc/addons/script.module.cryptopy/lib:/usr/share/xbmc/addons/script.module.simplejson/lib:/home/brad/.xbmc/addons/script.module.beautifulsoup/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/brad/.xbmc/addons/script.common.plugin.cache/lib:/home/brad/.xbmc/addons/script.module.simple.downloader/lib:/home/brad/.xbmc/addons/script.module.urlresolver/lib:/home/brad/.xbmc/addons/script.module.mechanize/lib:/home/brad/.xbmc/addons/script.module.parsedom/lib:/home/brad/.xbmc/addons/script.module.elementtree/lib:/home/brad/.xbmc/addons/script.web.viewer/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/home/brad/.xbmc/addons/script.module.metahandler/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:
09:56:39 T:2790210416 DEBUG: Process - Entering source directory /home/brad/.xbmc/addons/plugin.video.x-sopcast
09:56:39 T:2790210416 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.xsopcast" dependent on version 2.0 of the xbmc.python api
09:56:39 T:2790210416 INFO: Loading skin file: DialogProgress.xml
09:56:39 T:2790210416 DEBUG: DialogProgress::StartModal called
I didn't see an option in 0.2.9 to enter your own channel number.
beschmid
what is your display resolution and what skin are you using?
