2012-06-11, 23:26
2012-06-13, 05:49
(2012-06-09, 18:04)beschmid Wrote: [ -> ]XBMCbuntu current stable
Just installed 0.2.9 and ran for the first time. It locked up, had to reset. Below is the debug log, hopefully it can help.
09:56:39 T:3042912000 DEBUG: ParentPath = [plugin://plugin.video.xsopcast]
09:56:39 T:3042912000 DEBUG: StartScript - calling plugin X-Sopcast('plugin://plugin.video.xsopcast/','0','')
09:56:39 T:3042912000 INFO: initializing python engine.
09:56:39 T:3042912000 DEBUG: new python thread created. id=14
09:56:39 T:3042912000 DEBUG: WaitOnScriptResult - waiting on the X-Sopcast plugin...
09:56:39 T:2790210416 DEBUG: Thread XBPyThread start, auto delete: 0
09:56:39 T:2790210416 DEBUG: Python thread: start processing
09:56:39 T:2790210416 NOTICE: -->Python Interpreter Initialized<--
09:56:39 T:2790210416 DEBUG: Process - The source file to load is /home/brad/.xbmc/addons/plugin.video.x-sopcast/default.py
09:56:39 T:2790210416 DEBUG: Process - Setting the Python path to /home/brad/.xbmc/addons/plugin.video.x-sopcast:/home/brad/.xbmc/addons/script.module.xbmcswift/lib:/home/brad/.xbmc/addons/script.module.t0mm0.common/lib:/home/brad/.xbmc/addons/script.module.cryptopy/lib:/usr/share/xbmc/addons/script.module.simplejson/lib:/home/brad/.xbmc/addons/script.module.beautifulsoup/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/brad/.xbmc/addons/script.common.plugin.cache/lib:/home/brad/.xbmc/addons/script.module.simple.downloader/lib:/home/brad/.xbmc/addons/script.module.urlresolver/lib:/home/brad/.xbmc/addons/script.module.mechanize/lib:/home/brad/.xbmc/addons/script.module.parsedom/lib:/home/brad/.xbmc/addons/script.module.elementtree/lib:/home/brad/.xbmc/addons/script.web.viewer/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/home/brad/.xbmc/addons/script.module.metahandler/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:
09:56:39 T:2790210416 DEBUG: Process - Entering source directory /home/brad/.xbmc/addons/plugin.video.x-sopcast
09:56:39 T:2790210416 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.xsopcast" dependent on version 2.0 of the xbmc.python api
09:56:39 T:2790210416 INFO: Loading skin file: DialogProgress.xml
09:56:39 T:2790210416 DEBUG: DialogProgress::StartModal called
I get the same thing here, everytime I start the X-Sopcast addon XBMC locks up and I have to kill the application.
I thought it had something to do with older versions so I moved the ~/.xbmc directory (so I could try it on a "clean" xbmc)
and then installed the x-sopcast addon, but it behaves the same way.
I have the SopCast Player working fine here so I guess I have all the libs needed, is that right?
the XBMC I use is the XBMC-PVR from margro github branch
here's the clean install log: http://pastebin.com/F9FuHa3X
2012-06-13, 15:20
try to download http://download.easetuner.com/download/sp-auth.tgz and unzip it in plugin directory like that:
.../plugin.video.x-sopcast/sp-auth/sp-sc-auth
2012-06-14, 17:10
Can't open any channels... So tried to copy the libstdcpp5 files to /usr/lib..
I get Read-only file system.. tried to change /usr/lib DIR to 777 but tht doesn't work either.
2012-06-15, 06:54
you need to be root to do anything there.
activate root account with:
sudo passwd root
and then login as root
sudo passwd root
2012-06-17, 17:44
I SSH in as root into my Openelec system but i cant copy the files into /usr/lib FS. Says Read only no matter what i do.
I ve read somewhere that Openelec OS, is basically an image which is read only except Storage.. Can anyone tell me if there is any easy way
to get the 2 files into lib DIR. I am not a techie so am hoping there is an easy way out or i will have to forget about this addon until something can be worked out.
2012-06-22, 12:34
2012-06-23, 23:25
First off thanks ecinema for the great work reviving this plugin and the example for SportsDevil
I'm getting a tzset error on OpenElec PVR Generic (devel-20120614003416-r11300, 3.2.19 i686) using x-sopcast 0.2.9, am I missing support for this lib?
00:15:23 T:2688064320 ERROR: Error Type: <type 'exceptions.AttributeError'>
00:15:23 T:2688064320 ERROR: Error Contents: 'module' object has no attribute 'tzset'
00:15:23 T:2688064320 ERROR: Traceback (most recent call last):
File "/storage/.xbmc/addons/plugin.video.x-sopcast/default.py", line 1133, in <module>
INDEX(name)
File "/storage/.xbmc/addons/plugin.video.x-sopcast/default.py", line 318, in INDEX
sched = schedule(sch_domain , sch_channel , sch_channel_id , sch_list_expire , sch_timezone , False, True)
File "/storage/.xbmc/addons/plugin.video.x-sopcast/default.py", line 469, in schedule
grab_schedule(sch_list_expire,sch_timezone,sch_channel_id,sch_channel,sch_domain , silent)
File "/storage/.xbmc/addons/plugin.video.x-sopcast/default.py", line 344, in grab_schedule
time.tzset()
AttributeError: 'module' object has no attribute 'tzset'
00:15:23 T:3013969664 ERROR: GetDirectory - Error getting plugin://plugin.video.xsopcast/?mode=1&name=Sports
00:15:23 T:3013969664 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.xsopcast/?mode=1&name=Sports) failed
Any thoughts?
INDEX(name)
time.tzset()
Any thoughts?
2012-06-24, 23:31
I don't know why, but x-sopcast 0.2.6 is woring perfectly (in Eden and Pre-Frodo) but the newest 0.2.9 is not working correctly (most channels not working, the Menu option - "M" key- is not working, I shouldn't change channel -everything the channel is the same-...).
2012-07-09, 18:24
Does anyone know if there a sopcast plugin for Windows Eden 11?
2012-07-10, 16:01
(2012-07-09, 18:24)Repoman Wrote: [ -> ]Does anyone know if there a sopcast plugin for Windows Eden 11?I would be great to have one working for windows.
2012-08-10, 00:21
(2012-06-06, 04:20)jonnojohnson Wrote: [ -> ]0.26 seems to work ok but there are 2 problems with 0.27:
1. Once a stream is opened it doesn't seem to want to die. I can stop the stream using the player controls briefly but then it restarts after a second or so.
Same here, v0.2.10 on xbmcbuntu, aeon nox v3.5. The problem does not occur with confluence.
2012-08-16, 20:17
OHH!!!
Thats what I've waited for!!
Thanx a lot. But I have a problem. Plugin doesn't start.
After start plugin tryin to download www.sopcast.com/chlist.xml
and fails with message:
Cannot parse channel list
Please try again later
in log i see:
http://pastebin.com/wYWAmH7g
please help.
thanx a lot for your golden time
in log i see:
please help.
2012-08-20, 01:52
2012-08-29, 23:31
(2012-08-20, 01:52)Hudson_Hawk04 Wrote: [ -> ]anyone else getting a scrip failed error?
Log File http://xbmclogs.com/show.php?id=6924
Same problem, any solution?
