(2012-11-21, 18:12)Mossy Wrote: [ -> ]Click here
Also see first post, if you haven't already done so.
debug log
/Android/data/org.xbmc.xbmc/cache/temp/xbmc.log
/sdcard/Android/data/org.xbmc.xbmc/cache/temp/xbmc.log
/data/data/org.xbmc.xbmc/cache/temp/xbmc.log
I've got the second path on my device but no /cache/temp/xbmc.log in there. This is what i get instead sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/ followed by some other folders which do not contain /cache/temp/xbmc.log
By the way Debugging is on on my version of xbmc
Wondered if somebody could shed some light?
I've tried to play a drama series called 'Secret State' on 4OD plugin (XBMC Eden - ATV2). Unfortunately every time I try to play I'm greeted by:
error script failed:plugin.video.4od
It is a new series, I think I've read on this thread this may just be an updating issue?
Is there anyway to resolve?
The first post in this thread has a link to information about how to post a debug log.
Post a debug log and I'll have a look.
Version 1.8.3 (22 Nov 2012)
- By default check first two episodes in each show listing to see of they are not Youtube or not (only performed for recent episodes). Prefixed with [Not on Youtube] if that is the case. option in settings, under "Advanced", to do this for ALL recent episodes. Turning on this option may increase the length of time taken to show episode listings for some shows.
See first post:
http://forum.xbmc.org/showthread.php?tid...pid1128537
I've tried adding from the zip file and I get the message that the addon is enabled but I can't find it in the addon lists. Any suggestions anyone?
I've just installed this on a Raspberry Pi with Raspbmc, and found that all of the programmes I wanted to watch aren't available, which turns out to be due to the HDS issue
So I've just been looking into that, to see if there could be any way round it. Do we know whether the stream is actually encrypted in some way, or is it just a matter of dealing with the strange F4F stream format?
It's encrypted.
I'm surprised that none of the shows you're interested in are on Youtube, unless they're all American.
I'm updated to latest 4od and youtube plugins, but when I try to play new material (e.g. latest series of Fresh Meat or Peep Show) I get the error 'couldn't locate video url' after plugin goes through 'looking for video on 4od, youtube, opening stream,...'
Any ideas?
just installed this and tried homeland latest episode and fresh meat latest and both failed to find file. :O(
M
Fresh Meat and Peep Show play fine for me right now, it's possible that the Peep Show episode from yesterday has only just been added to Youtube, but you shouldn't have problems with Fresh Meat.
To see a "[Not on Youtube]" message beside all recent episodes that aren't on Youtube, in the plugin settings go to Advanced and turn on the "Show [Not on Youtube[ for all recent episodes" setting.
Of course I'm assuming that you're logged into Youtube in the Youtube plugin.
Homeland obviously won't play no matter what for reasons stated in previous posts.
As always post a debug log if you want me to look into your problem.
Change log:
Version 1.8.4 (27 Nov 2012)
- Fix disabled cache bug
For repository/download details see the
first post.
Before reporting a problem please read the first post, and note that you need to be logged into Youtube in the Youtube plugin in order to watch recent episodes.
