2014-11-12, 04:46
(2014-11-10, 18:48)menno Wrote: [ -> ]Can we rebuild a linux version off the latest windows?
I started to do this last week, but it is a tremendous amount of code.
(2014-11-10, 15:59)menno Wrote: [ -> ]I wanted to use a logo file earlier generated from a show called Grand Desgins. Because
if i looked to that logo.txt it's much better than the one generated from Speed with Guy Martin.
I renamed Grand Designs.logo.txt to Channel_4.logo.txt
and ran
comskip --logo Channel_4.logo txt "Speed with Guy Martin.mkv"
I use the linux version.
I get this error;
Using Speed with Guy Martin.logo.txt for logo data.
terminate called after throwing an instance of 'std::out_of_range'
what(): x exceeds max width
Aborted
What is wrong?
Also I am very new to this, and I wonder why no logo files and ini's per channel are widely available..
are we all trying to re-invent our own wheels?
(2014-11-13, 11:55)cbxbiker61 Wrote: [ -> ](2014-11-10, 15:59)menno Wrote: [ -> ]I wanted to use a logo file earlier generated from a show called Grand Desgins. Because
and ran
I get this error;
Aborted
What is wrong?
0.93i has been released. 0.93i tries to avoid aborts due to faulty input.
Keep in mind that those std::out_of_range errors are caused by input files that are damaged.
logo files are dynamic....they will not match closely enough between episodes to be reusable. Using custom ini's per program/channel on the other hand may be useful.
I'm just starting work on 0.94 to fix issues that i know exist in 0.93.
(2014-11-13, 23:34)menno Wrote: [ -> ]Ok thanks, are you working together with Asharad?
Quote:Name: comskip
Version: 0.93i
Release: 1%{?dist}
Summary: Commercail Skip Creation Software for Linux
Group: media
License: GPL
URL: http://www.xilka.com/xilka/source/comskip-0.93i.tar.xz
Source0: comskip-0.93i.tar.xz
BuildRequires: tar
BuildRequires: automake
BuildRequires: autoconf
BuildRequires: libtool
BuildRequires: ffmpeg-devel >= 0.9
BuildRequires: argtable-devel
Requires: ffmpeg >= 0.9
%description
%prep
%setup -q
%build
%configure
make %{?_smp_mflags}
%install
make install DESTDIR=%{buildroot}
%files
%doc
%{_bindir}/%{name}
/etc/%{name}/*
%changelog
* Fri Jan 09 2015 Bob Lightfoot <[email protected]> 0.93i-1
- initial packaging for el7
make all-am
make[1]: Entering directory `/var/tmp/ComSkipWork/comskip-0.93i'
gcc-4.9 -DHAVE_CONFIG_H -I. -g -O2 -std=gnu++11 -MT comskip-mpeg2dec.o -MD -
MP -MF .deps/comskip-mpeg2dec.Tpo -c -o comskip-mpeg2dec.o `test -f 'mpeg2dec.cp
p' || echo './'`mpeg2dec.cpp
mpeg2dec.cpp: In function `void {anonymous}::file_close()':
mpeg2dec.cpp:1631:32: error: `avcodec_free_frame' was not declared in this scope
avcodec_free_frame(is->pFrame);
mpeg2dec.cpp:1639:4: warning: `void av_close_input_file(AVFormatContext*)' is de
precated (declared at /usr/include/libavformat/avformat.h:1706) [-Wdeprecated-de
clarations]
::av_close_input_file(is->pFormatCtx);
mpeg2dec.cpp:1639:38: warning: `void av_close_input_file(AVFormatContext*)' is d
eprecated (declared at /usr/include/libavformat/avformat.h:1706) [-Wdeprecated-d
eclarations]
make[1]: *** [comskip-mpeg2dec.o] Error 1
make[1]: Leaving directory `/var/tmp/ComSkipWork/comskip-0.93i'
make: *** [all] Error 2
Quote:Can we rebuild a linux version off the latest windows?
