(2019-11-14, 04:09)BoeboeBE Wrote: [ -> ]Is anyone still maintaining this plugin? The github repo seems to be deleted and I would be interested to take over this maintenance, as there are some menu items that don't work anymore...
An alternative as suggested by @
dkoch84 is to look for the RT live feed on YouTube and then add it as a Favorite. You can then add that to your Main Menu etc.
Regards,
Shedrock
(2019-11-14, 05:21)shedrock Wrote: [ -> ] (2019-11-14, 04:09)BoeboeBE Wrote: [ -> ]Is anyone still maintaining this plugin? The github repo seems to be deleted and I would be interested to take over this maintenance, as there are some menu items that don't work anymore...
An alternative as suggested by @dkoch84 is to look for the RT live feed on YouTube and then add it as a Favorite. You can then add that to your Main Menu etc.
Regards,
Shedrock
Thanks Shedrock,
I saw that suggestion. This will only work for 2 of the 6 livestreams from RT however, as the other 4 are still not migrated to YouTube (not sure if they plan to do so).
I am creating my very first video plugin myself, for CGTN... so in the process of learning. It all goes pretty smooth... kodi is well documented and the websites of CGTN have nice rest API's to enumerate livestreams and videos.
Hence my question to take over the maintenance of this plugin... as I think it is useful and I like it
Hi all,
All existing issues with the RT plugin are now fixed (v3.0.6).
- All livestreams and shows are working again
- Fixed thumb image retrieval
- Added banner image
- Adjust default fan-art
- Up-step Youtube version and adjust new calling parameters
xml:
3.0.6 regex updates, upstep and adjust youtube call, adjust arab live url, add banner, adjust fanart (boeboe)
3.0.5 minor website change (t1m)
3.0.4 added YT playback (t1m)
3.0.3 added French feed (t1m)
3.0.2 added Spanish and Arab live feeds that I forgot (t1m)
3.0.1 clean up and fix live feeds (t1m)
2.0.2 website chnages (t1m)
2.0.1 Isengard version - fixed live streams (Isengard)
Zipped release available at:
https://github.com/boeboe/plugin.video.r...tag/v3.0.6
(2019-12-04, 23:36)BoeboeBE Wrote: [ -> ]Hi all,
xml:
I am unable to install this on Krypton 17.6. I get a "The Dependency on xbmc.python 2.26.0 could not be satisfied" error.
Is there a workaround to this without having to upgrade to Kodi 18?
I have some addons that will break with python 3.
xml:
Excellent! It's working for me on Kodi 18.7.
thank you. Working very fine
(2021-06-26, 16:37)cosmos19 Wrote: [ -> ] (2019-12-04, 23:36)BoeboeBE Wrote: [ -> ]Hi all,
xml:
https://github.com/boeboe/plugin.video.rt
This plugin including the new version 3.0.8 has stopped working.
Get YouTube error: no streams found
(2021-06-26, 16:41)cosmos19 Wrote: [ -> ] (2021-06-26, 16:37)cosmos19 Wrote: [ -> ] (2019-12-04, 23:36)BoeboeBE Wrote: [ -> ]Hi all,
xml:
Issue resolved with YouTube addon update.
Regards,
Shedrock
youtube has removed all RT content due to info war. We need this add-on! All Livestreams are failing:
https://paste.kodi.tv/mohedusasu.kodi
(2021-10-14, 18:22)woprr Wrote: [ -> ] (2019-11-14, 05:21)shedrock Wrote: [ -> ] (2019-11-14, 04:09)BoeboeBE Wrote: [ -> ]Is anyone still maintaining this plugin? The github repo seems to be deleted and I would be interested to take over this maintenance, as there are some menu items that don't work anymore...
Regards,
Shedrock
youtube has removed all RT content due to info war. We need this add-on! All Livestreams are failing: https://paste.kodi.tv/mohedusasu.kodi
What region are you in? RT, RT America. . .UK and Russia Insight, are all available I view the channels daily
Russian side have probably changed the url and addon needs to be updated
Youtube addon Kodi
(2021-10-15, 00:39)fsurfer Wrote: [ -> ] (2021-10-14, 18:22)woprr Wrote: [ -> ] (2019-11-14, 05:21)shedrock Wrote: [ -> ]An alternative as suggested by @dkoch84 is to look for the RT live feed on YouTube and then add it as a Favorite. You can then add that to your Main Menu etc.
Regards,
Shedrock
DE, RT.DE has been shutdown. RT Livestream 24/7 found on youtube is running without stutter and buffer. Thanks for the tip.
(2021-10-15, 13:05)woprr Wrote: [ -> ] (2021-10-15, 00:39)fsurfer Wrote: [ -> ] (2021-10-14, 18:22)woprr Wrote: [ -> ]youtube has removed all RT content due to info war. We need this add-on! All Livestreams are failing: https://paste.kodi.tv/mohedusasu.kodi
Glad I could help, have you added any settings to your Advancedsettings.xml?
I added
<cache>
<buffermode>4</buffermode>
<readfactor>10</readfactor>
</cache>
