2016-05-12, 19:07
2016-05-14, 05:12
(2016-05-09, 14:27)Martijn Wrote: [ -> ]Kodi v17 uses python 2.7.11 for all versions (not sure if that helps)Has anyone tried tesing the TWiT addon in Kodi v17.0 “Krypton” if that's actually the case?
2016-05-15, 08:11
Just as a test I installed Kodi v17.0 "Krypton" on a cheap Windows 10 tablet along with the TWIT addon.
It failed with the same error as on my Raspberry Pi 2
Who would think that twit.tv upgrading their security to https to be more secure would end up with braking the system so some people who really know security can't watch it anymore using KODI
2016-05-15, 11:21
I'm going to fix this by hard coding the feed URL's. That's the only viable option I see at the moment.
Give me a couple/few days(hopefully work wont call).
2016-05-15, 18:55
(2016-05-15, 11:21)divingmule Wrote: [ -> ]I'm going to fix this by hard coding the feed URL's. That's the only viable option I see at the moment.
Thanks divingmule and good luck
2016-05-16, 20:42
I've been getting an error when opening up TWiT in my kodi-16.1-Jarvis-armeabi-v7a. After error, window pop in offering Movies, TVshows, In progress TV shows, Recently added movies, Recently added episodes, Files, Playlist and Video add-ons, after error message.
None of these allows you to find Leo Laport's broadcast or others.. What can we do to fix .. Thanks in advance.. ctx9 [email protected]
2016-05-16, 21:37
Hope your able to create fix for TWiT for us using Kodi 16.1 Jarvis. My Op System is running Android in a R-Box streaming device.
Again
ctx9
2016-05-17, 00:21
Twit seems to be working for me using SPMC
Sent from my Nexus 5X
2016-05-17, 01:56
Please help test this out and report any issues - Plugin version 2.1.4
Download and install from zip file -> https://github.com/divingmule/plugin.vid...-2.1.4.zip
2016-05-17, 03:11
(2016-05-17, 01:56)divingmule Wrote: [ -> ]Please help test this out and report any issues - Plugin version 2.1.4
Working just fine. Tested on Windows 10 machine and Raspberry Pi running Openelec.
Good work divingmule
2016-05-17, 03:59
Twit 2.1.4 working great on my Windows 10 PC running Kodi 16.1
Big Thanks!!!
2016-05-17, 11:19
Tested on Android 4.4.2 and Windows 8.1, both with Kodi 16.1 - working great.
Thank you!
2016-05-18, 12:01
Working on FireTV stick, Kodi 16.1. Thanks.
2016-05-19, 15:43
Thanks to everyone who helped test. Version 2.1.5 has been merged into the Kodi repo, so everyone should see an update in a day or two. If the previous version is working for you stick with it or you can roll back to v2.1.3 if you get auto updated.
2016-05-24, 22:11
Just wanted to let you know for Twit TV "Bitgravity 1 Mbps" and "Bitgravity http 400 kbps" settings do not work.
Just letting you know in case someone wanted to fix them
