No, it doesn't redirect, rather it endlessly (> 5 minutes) displays the loading animation...
http://i.imgur.com/bjAZ84k.png
I guess that's some kind of block going on, right?
Try playing some other Popcornflix video links in the browser, possibly just some of the content is blocked. If none play, I think it's safe to assume that, at least for you, the feeds are blocked.
(2014-10-17, 22:10)ferriedeperrie Wrote: [ -> ]No, it doesn't redirect, rather it endlessly (> 5 minutes) displays the loading animation...
When I first found out about popcornflix, It did this for just about everything I tryed. Then I tested with hola better internet setting it to us and stuff started working so I guess this is geoblock. There might be some stuff that works, so I suggest you to try a bit more.
It seems the addon is not working well. I've tryed several films and it just comes up with a "No playableItems Found" message on Kodi Helix stable. This is what the log says:
09:56:10 T:1072 NOTICE: DVDPlayer: Opening:
09:56:10 T:1072 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
09:56:10 T:1072 NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
09:56:10 T:1072 NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
09:56:10 T:2596 NOTICE: Thread DVDPlayer start, auto delete: false
09:56:10 T:2596 NOTICE: Creating InputStream
09:56:10 T:2596 WARNING: XFILE::CSimpleFileCache::Close: failed to delete temporary file ""
09:56:10 T:2596 WARNING: Previous line repeats 1 times.
09:56:10 T:2596 ERROR: XFILE::CFileCache::Open - failed to open source <>
09:56:10 T:2596 WARNING: Previous line repeats 2 times.
09:56:10 T:2596 ERROR: CDVDPlayer::OpenInputStream - error opening []
09:56:10 T:2596 NOTICE: CDVDPlayer::OnExit()
09:56:10 T:1072 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.popcornflix/?url=plugin%3A%2F%2Fplugin.video.popcornflix%2F%3Furl%3D%252Fdream-warrior%252Fee3daf88-1476-4bb3-9b92-8806b88fccd8%26mode%3DGS&mode=SR]
09:56:10 T:4320 NOTICE: 1Channel: Service: Playback Stopped
09:56:10 T:3100 NOTICE: Thread BackgroundLoader start, auto delete: false
09:56:11 T:1072 NOTICE: CDVDPlayer::CloseFile()
09:56:11 T:4320 NOTICE: 1Channel: Service: Resetting...
09:56:11 T:1072 NOTICE: DVDPlayer: waiting for threads to exit
09:56:11 T:1072 NOTICE: DVDPlayer: finished waiting
09:56:13 T:3536 NOTICE: Thread LanguageInvoker start, auto delete: false
09:56:13 T:3536 NOTICE: -->Python Interpreter Initialized<--
09:56:13 T:4420 NOTICE: Thread LanguageInvoker start, auto delete: false
09:56:13 T:4420 NOTICE: -->Python Interpreter Initialized<--
09:56:19 T:1072 NOTICE: DVDPlayer: Opening:
09:56:19 T:1072 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
09:56:19 T:1072 NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
09:56:19 T:1072 NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
09:56:19 T:1740 NOTICE: Thread DVDPlayer start, auto delete: false
09:56:19 T:1740 NOTICE: Creating InputStream
09:56:19 T:1740 WARNING: XFILE::CSimpleFileCache::Close: failed to delete temporary file ""
09:56:19 T:1740 WARNING: Previous line repeats 1 times.
09:56:19 T:1740 ERROR: XFILE::CFileCache::Open - failed to open source <>
09:56:19 T:1740 WARNING: Previous line repeats 2 times.
09:56:19 T:1740 ERROR: CDVDPlayer::OpenInputStream - error opening []
09:56:19 T:1740 NOTICE: CDVDPlayer::OnExit()
09:56:19 T:1072 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.popcornflix/?url=plugin%3A%2F%2Fplugin.video.popcornflix%2F%3Furl%3D%252Fcia--exiled-%2528a.k.a.-curacao%2529%252F4285066b-0e0f-4c6a-a30a-2917d6844e4e%26mode%3DGS&mode=SR]
09:56:19 T:1760 NOTICE: Thread BackgroundLoader start, auto delete: false
09:56:19 T:1072 NOTICE: CDVDPlayer::CloseFile()
Note: the films (Dream Warrior and CIA - Exiled) do start playing in the website, they just take a lot of time until they start. Sometimes, I have to refresh the page or they won't start at all.
I guess popcornflix is overloaded and the addon does not wait for it.
I fixed this yesterday. The change has been submitted to the xbmc.org repo. You can also get it at:
https://github.com/learningit/plugin.video.popcornflix
The default bitrate has been set higher to allow 720p videos. You may need to adjust if you have a slow internet link.
THX! I'll update the addon on my kodi instalation and let you know.
Works great. The new default bitrate streams stuff in 640*480 or 720*516 as far as i can tell. 1200kbps seems to be 360p.
I love the addon, thanks guys.
stop working when updated to V 2.1.0
V 1.0.8 is working fine
(2015-01-12, 20:36)Justinuk Wrote: [ -> ]stop working when updated to V 2.1.0
V1.0.8 is the current version. Don't know where you got 2.1.0 from. Reload from xbmc.org.
(2015-01-12, 20:55)learningit Wrote: [ -> ] (2015-01-12, 20:36)Justinuk Wrote: [ -> ]stop working when updated to V 2.1.0
it automatically updates to version 2.1.0 then it doesnt work. weird. then i uninstall it and version 1.0.8 is there instead. and it works fine?
You must have a different repo installed that has an addon with the same name in it. Probably the easiest thing for you to do if you can't uninstall the repo with the higher version addon in it is:
1) disable auto-updates in Settings-Addons right cursor.
2) uninstall current popcornflix addon
3) install version 1.0.8 from xbmc.org repo
4) exit kodi
5) in your addons directory, open plugin.video.popcornflix directory and edit addon.xml with notepad (or something like it), change the version from 1.0.8 to something higher than 2.1.0 - like 3.0.8 and save the file.
6) start kodi
7) re-enable auto-updates (if desired)
You'll have to look in the xbmc.org repo from time to time (or when the addon doesn't work) to see if there's a new version in the repo and follow the steps above again.
(2015-01-13, 02:45)learningit Wrote: [ -> ]You must have a different repo installed that has an addon with the same name in it. Probably the easiest thing for you to do if you can't uninstall the repo with the higher version addon in it is:
4) exit kodi
6) start kodi
i just started using this program a few weeks ago and that's too complicated for me..lol ill wait for a more stable version, but thanks for the help.
4) exit kodi
6) start kodi
for the 2.1.0 version ,it's still shown as made by 'XBMCHUB' Blazetamer as author..but it don't work..
And this guy Blazetamer say he will no longer update it.. crap
[/quote]
[/quote]
well thats too bad
