2017-10-24, 10:08
2017-10-24, 21:07
(2017-10-24, 10:08)Eye in the sky Wrote: [ -> ]Working again with v.6.0.4, thanks.
Thanks for letting me know.
2017-12-31, 07:51
I have OSMC/Kodi on a Raspberry Pi.
I am having issues with popcornflix and hope you can steer me in the right direction.
I get the dreaded "one or more items failed to play. Check the log for more information about this message”.
I have just done a fresh install with just the popcornflix 6.0.4 addon.
Here are the logs.
Many thanks in advance.
Here are the logs.
2018-01-03, 01:06
Either part of the log is missing or you haven't enabled debug logging.
2018-01-03, 22:53
2018-01-04, 03:06
Are you only running OSMC? Can you try running Kodi?
The request works fine on Kodi 17.6. Otherwise it would be better to ask in an OSMC support forum.
2018-01-04, 05:53
I am running Kodi on OSMC aren't I?
Quote:11:39:21.218 T:1958461440 NOTICE: Starting Kodi (17.5). Platform: Linux ARM (Thumb) 32-bit
11:39:21.218 T:1958461440 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
11:39:21.218 T:1958461440 NOTICE: Kodi compiled Oct 29 2017 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.39 (200743)
11:39:21.218 T:1958461440 NOTICE: Running on Open Source Media Center 2017.10-1, kernel: Linux ARM 32-bit version 4.9.29-10-osmc
2018-01-04, 05:59
Sorry I meant to write OpenElec, not Kodi.
I've never tested (and won't) OSMC.
Your problem appears to be OS or platform specific. The add-on works fine on others.
2018-01-04, 06:55
OK, I have installed OpenELEC with Kodi which was not that simple as I could not find any installation instructions.
I still have the same error.
My problem now is I have not found how to upload the logs from OpenELEC. SSH in not working. Arrrggghhhh!!!
Is LibreElec a continuation of OpenELEC?
2018-01-04, 06:59
I believe Libreelec is. To be honest the logs don't tell.me anything other than.the http request doesn't return any data
There could be several reasons for that. I'm assuming that you're in.the US.
2018-01-04, 07:11
No. Australia.
I have previously installed a VPN to get around geo blocking but made no difference to the error I am getting.
2018-01-24, 06:57
well, it seems even with the new version it is not working for me. Even on the official website, it is geo-blocked.
but thanks for the addon
2018-02-01, 22:47
Version 6.0.5 fixes the TV Shows content.
A pull request has been issued for the kodi.org repo, the add-on should update in a few days.
2018-05-04, 00:16
unfortunately doesn´t work for me.
Geoblocking doesn´t let me watch the movies, so keeps me giving error on playback and i have updated to latest version.
thanks anyway
thanks anyway
