Full Version: [RELEASE] Rapier 8.8.15 for Kodi 15 Isengard [DEPRECATED]
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
8.8.15 FOR KODI 15 ISENGARD
24-JANUARY-2017
Available through the official Kodi repository!
Now that Kodi 17 Krypton final version is released, Rapier for Kodi 15 Isengard is deprecated!
If you haven't done so already, I highly recommend updating to Kodi 16 Jarvis, Kodi 17 Krypton or Kodi 18 Leia nightlies, as the new features are incredible! Smile
The first post will always be updated with the latest information and changelog.
If you have any problems or find any bugs, please let me know right away.
Also, if you have features, ideas, designs etc. you would like added, I'll be more than happy to help.
You can always follow latest development, download uncompressed textures etc. on Github.
You can manually install my repository to automatically receive the newest development updates. You will still receive the official updates.
You can find a detailed guide to Rapier's skin settings at the wiki.
Please keep this thread reserved for Rapier for Kodi 15.x Isengard.
Click here for Rapier for Kodi 18 Leia.
Click here for Rapier for Kodi 17 Krypton.
Click here for Rapier for Kodi 16 Jarvis.
INSTALLING
To install this skin for Kodi 15 Isengard, you must do so from the Add-on Manager within Kodi:
  1. Navigate to Settings
  2. Add-ons
  3. Get add-ons
  4. Kodi Add-on repository
  5. Skins
  6. Rapier
  7. Install
SCREENSHOTS
CHANGELOG:
RAPIER 8.8.15 ISENGARD
- New status bar battery notification.
- Added "Add-on Settings" button to top options menu bar when an add-on is running.
- List View normal style now defaults to file icon when no icon is available.
- Fix for home screen widget fanart.
- Added subtitle delay label for subtitle delay button in the fullscreen video OSD.
- Added Reload Skin button to Skin Settings > Skin Settings.
PREVIOUS VERSIONS
8.8.14 (19-December-16)
- Added additional home screen custom category images.
- Clicking Back on all widgets will go to the first item in the list.
- When playing music, home screen progress bar is changed to blue.
- Updated skin settings for artwork downloader to match supported artwork types.
- Added close button to text viewer dialog.
- Updated language strings from Transifex.
- Fixed VC-1 codec media flags.
- If no trailer is available, trailer buttons will display "Search Trailer".
8.8.13 (24-November-16)
- Added media flags for PVR recordings.
- Improvements of artist / album information window.
- Added Play button in album information window.
8.8.12 (18-October-16)
- Added Noto Sans font.
- Update of slideshow window.
8.8.11 (5-October-16)
- Added new fallback image in Favourites dialog.
- Update of Skin Settings > Supported add-ons section with "Manual installation" section.
- Updated login screen.
- PVR radio improvements and updates.
- Home screen weather category will take you to weather settings if no weather add-on is installed.
- Added support for LibreELEC settings (home screen System category submenu).
- Fullscreen video window Paused label will now also show buffering.
- Added Paused / Buffering labels to fullscreen music window.
8.8.10 (19-September-16)
- Added Skin Settings > Media > Music Playing > setting to enable fullscreen window when starting music.
- Updated Presets Dialog with Weather section (when creating custom categories / submenus).
- Increased the size of add-on settings dialog.
- Changed all instances of "Live TV" to "TV".
- Added more info on the next playing item in information dialog when playing fullscreen live tv.
- Bugfixing of PVR section.
- Added fanart for PVR recordings with view option to disable.
- Added Homizio Nova font.
- Added clearlogo to PVR recordings window with view option to disable.
- Bugfixing of unrated / no rating media flags.
- Added multilingual font.
- Updated screen calibration window.
8.8.9 (26-July-16)
- Code cleanup.
- Added more animations to "Low CPU Power Mode".
- Updated playlist windows: changed shuffle button, added info labels and media flags.
- Added Playlist View to current playlist window.
- Updated playlist editor window.
- Added Extended View to movie, tv show and music video tags.
- Added season number breadcrumb to episode window.
8.8.8 (23-June-16)
- Updated main category languages (thanks to patria o muerte, rootsun, NEOhidra).
- Updated favourites dialog.
- Updated README and merged README.txt into README.md
8.8.7 (19-June-16)
- Bugfixing of PVR breadcrumbs.
- Fix skin settings scrollbar navigation.
- Visualisations and fanart are both visible when playing music.
8.8.6 (2-June-16)
- Updated busy dialog with busy spinner.
- Added scroll animation to OSD PVR Channels and Guide dialogs.
8.8.5 (25-May-16)
- Added watched and partially watched overlays to Icon View with view option to disable them (thanks to MaikoHermans).
- Added View Option to use vertical navigation for Wall View.
- Rearranged some View Options buttons.
- Fixed info pane genre labels for movie sets.
8.8.4 (17-May-16)
- Added "Enable Low CPU Power Mode" button to Skin Settings > General. This replaces "Animations" section and can disable animations and reset CPU demanding skin settings.
- Added home screen music playlist widget with player controls.
8.8.3 (12-May-16)
- All Youtube searches will now use ExtendedInfo with Youtube Browser window.
- Added List View and List Info 2 View to Youtube Browser window.
- Skin Settings: Fanart, backgrounds and custom backgrounds are now dimmed individually on a 0-100% scale.
- Skin Settings: Custom backgrounds preview image is now dimmed according to settings when "Background Brightness" button is focused.
8.8.2 (2-May-16)
- Fixed home screen addon shortcut focus animation.
- Update of script.rss.editor windows.
- Next Aired infolabels will now properly use a fallback label.
- Added Subtitle Position button to fullscreen video OSD subtitles popup.
- Updated descriptions for Supported Add-ons with "Required" labels.
- The selected Skin Settings section button will now stay highlighted when other items are focused.
8.8.1 (17-April-16)
- Updated screenshots.
- Added Search button to presets dialog when creating custom categories and submenus.
- Updated language files from Transifex.
- Added Similar Movies button to movie information window Extra Info dialog for movie sets.
- Fix for top options menubar Update Library button.
- Added Awards / Critics to ExtendedInfo video information window.
- Added ExtendedInfo TV Show Information in season and episode levels.
- Skin Settings > Supported Add-ons section will now have add-on descriptions.
- Skin Settings will now have main category descriptions.
- Fixed home screen custom widget scroll animation.
- Bugfixing of add-on settings dialog and system settings radio buttons.
8.8.0 (29-March-16)
- Added sort letter notification for global search window.
- Bugfixing of clear logo visibility in Extended List View.
- Changed labels of breadcrumbs in information windows.
- PVR Windows will now dim when view options dialog is visible.
- Added In Progress TV Shows submenu to the home screen TV Shows category.
- Updated Hebrew home screen category images (thanks to dontel).
- Changed visibility for "Current Playlist" button in the menubar when a playlist is active.
- Fixed missing label for location button in weather window menubar.
- Added date label to Info Pane in pictures windows.
- Added List Info 3 and Thumbs Info Views to pictures windows.
- Increased size of picture information dialog.
- Added CPU usage progress bar and Memory usage progress bar to system information window.
- Added Search dialog when search button or home screen Kodi logo button is clicked.
- Added Search submenu button to the home screen General category.
- Merge, update and redesign of Icon View, Thumbnail View and TV Shows Banner View.
- Added new Icon View for movie sets.
- ExtendedInfo video information window trailer button now closes the window if a trailer exists.
- Added "Edit Nodes" button to top options menu bar when in the nodes section of libraries (will install plugin.library.node.editor).
- Added plugin.library.node.editor to Skin Settings > Supported Add-ons section.
- Centered yes/no dialog, busy dialog, ok dialog and progress dialog.
- Changed top options menubar Filter button to radiobutton.
- Added Preview button to Skin Settings > General when enabling startup video / image.
- Removed add-on star rating and rating since it doesn't work.
- Font fixes.
8.7.0 (12-February-16)
- Greatly improved visible conditions of fullscreen OSD, information and codec information dialogs.
- Added General skin setting to enable startup video, audio or image.
- Added PVR Stream Information when displaying codec info for fullscreen live radio.
- Improved skin settings Media and Backgrounds.
- All movie, set, tv show, episode and music video star ratings are now using half stars (0-10).
- Label position fix for RSS Editor windows.
- Update of home screen system info widget.
- Bugfixing of images in DialogVideoInfo.xml
- Added view option to movies, tv shows and seasons to show year in the info pane.
- Added new view type to movies and sets library: Recommended View (using script.extendedinfo).
- Bugfixing of blu-ray and dvd media flags.
- Removed startup delay from some sounds.
- Add-on settings dialog is now centered in fullscreen video and audio window.
- Update of music OSD. New menu is added for Visualisations.
- Updated languages from Transifex.
8.6.0 (4-January-16)
- Update of text viewer dialog.
- Updated some textures in video libraries.
- Added fanart backgrounds (movies, tv shows, videos, music: random, recent, in progress, unwatched) to custom categories. THIS WILL BREAK ALL CURRENT CUSTOM CATEGORY BACKGROUNDS!
- Updated some home screen category image languages.
- Redesign of home screen weather widget.
- Changed position of home screen system information widget.
- When movies or tv show episodes are paused, a poster or clear art / clear logo will be visible in the bottom left corner.
- Added PseudoTV / PseudoTV Live visible condition to DialogSeekBar.xml
- Bugfixing of home screen In Progress episodes and movies.
- Improved visible conditions for home screen widgets.
- Added labels for music OSD random and repeat buttons.
- Bugfixing of fanart images in Extended List View.
8.5.1 (18-December-15)
- Improved animations in fullscreen video OSD.
- Removed music clearlogo dialog from skin settings.
- Improved setting the path for music library clearlogos in Skin Settings > Media.
8.5.0 (17-December-15)
- Added Supported Add-ons section to Skin Settings. Download/install or configure supported add-ons.
- Bugfixing of video library Order By button.
- Increased size of posters in List Info 3 view.
- Added view option for movies and tv shows to hide genres labels in List Info View, List Info 2 View, List Info 3 View, Thumbs Info View, 3D Wrap View.
- Increased size of fullscreen video OSD Settings dialog and select dialog.
- Bugfixing of setting the custom icon for home screen categories in the skin settings.
- Added extrafanart support for music videos.
- Added fallback image for List Info 2 View / List Info 3 View / Thumbs Info View / 3D Wrap View fanart in movies, tv shows, episodes, music and programs.
- Added button for tv show extrathumbs in Skin Settings > Add-ons > Artwork Downloader > Download Presets - TV Shows.
- Moved Animate Background setting from View Options dialog to Skin Settings > Backgrounds.
- Bugfixing of tv thumb image in tv show library views.
- Added small extra fanart support for movies / sets / tv shows / episodes List Info 2 View / List Info 3 View / Thumbs Info View / 3D Wrap View.
- Replaced custom dialogs custom_DialogCustomCategoryIcons.xml and custom_DialogCustomPane.xml with script.skin.helper.service function.
- Text in DialogOK.xml and DialogYesNo.xml is now always vertically centered.
- All home screen recently added widgets are now hidden until content is available.
- Updated language files from Transifex (thanks to alanwww1).
8.4.1 (17-November-15)
- Fixed some minor bugs in home screen / presets dialog music paths.
- Bugfixing for add-on paths when using an Android platform.
- When CinemaVision is running, DialogKaiToast.xml will be hidden.
8.4.0 (11-November-15)
- Removed support for script.toolbox, script.skin.info.service and script.grab.fanart.
- Added support for script.skin.helper.service including more fanart background options and added PVR fanart backgrounds.
- Removed dependency for script.grab.fanart and added dependency for script.skin.helper.service.
- Updated movie set information window using script.skin.helper.service.
8.3.7 (24-October-15)
- Added partially watched overlay for music videos List Info 2 View.
- Fixed navigation bugs in movie information window menubar.
- Added rating label to album information window.
- Bugfixing of paused screen in fullscreen video window.
- Bugfixing of player control dialog.
- Alignment fixes of buttons for fullscreen music OSD.
- Added OpenELEC Settings button to home screen system submenu (only available on Raspberry Pi).
- Removed PseudoTV Live skin support.
8.3.6 (10-October-15)
- Bugfixing of home screen System submenus.
- Added support for alternative duration in all missing views.
- Bugfixing of global search breadcrumbs and added search label.
- Added In Cinemas / Upcoming Movies widget for home screen movies category (requires script.extendedinfo).
- Party Mode button is now only visible in the music and music video library.
- Bugfixing of budget label for ExtendedInfo movie information window.
- Bugfixing of poster image in fullscreen video information dialog.
8.3.5 (25-September-15)
- Bugfixing in weather window for Hourly and 16 Days animated icons.
- Redesign of NextUp Info and Still Watching dialogs.
- Removed About window.
8.3.4 (17-September-15)
- Added Google Maps dialog for plugin.image.mypicsdb (requires manual installation).
- Minor bugfixes for subtitles dialog.
- When CinemaVision is running, the busy dialog will be hidden.
- ExtendedInfo season menubar work.
- Added episode count label to ExtendedInfo season information window.
- Changed button "Scroll Plot/Description" in View Options to one global setting.
- Added Xzener's movie / tv show genre icons to the skin.rapier/extras folder (huge thanks to Xzener and IIIdefconIII).
8.3.3 (10-September-15)
- Added Information button in fullscreen music OSD.
- Rearranged Media section in the skin settings (no settings removed).
- Moved Next Aired Status Media Flag from view options dialog to Media section in the skin settings.
- Disabling media flags in the skin settings now also disables next aired status and studio media flags in the tv show and season library.
- Added filter wizard and translation editor dialogs for plugin.image.mypicsdb (requires manual installation).
8.3.2 (6-September-15)
- Added up to 20 items for home screen movies, tv shows and music recently added widgets.
- Added home screen pictures recently added / random widget (requires manual installation of plugin.image.mypicsdb).
- Added Latest / Random image backgounds to pictures home screen category and windows (requires manual installation of plugin.image.mypicsdb).
- Added support for CinemaVision script (script.cinemavision) (script.cinema.experience is still supported).
8.3.1 (3-September-15)
- Updated addon.xml.
- Added Fanart View for movies, sets and tv shows.
- Added better add-on support to presets dialog when creating custom categories / submenus.
- Added flat theme (almost no rounded corners / shadows).
8.3.0 (20-August-15)
- Bugfixing of clear logos for music videos.
- Added Extended List View for movie genres, sets, years, actors, directors, studios and countries.
- Added Extended List View for tv show genres, years, actors and studios.
- Added Extended List View for music video genres, years, directors and studios.
- Added Extended List View for music genres and years.
- Added country flag images for countries library views.
- Updated info labels for album and artist information window and added script.skin.info.service info labels.
- The "Next" button in the OSD subtitles dialog will now cycle through available subtitles.
- Better mouse support for top bar home button and top bar global search button.
- Added poster image for movie and episode fullscreen info dialog.
- Fixed season / episode number for live tv and episode fullscreen info dialog.
- Disabled startup sound.
8.2.8 (9-August-15)
- Added simultaneous support for pvr.wmc and pvr.nextpvr add-ons.
- Added support for pvr.dvblink add-on.
- Bugfixing of view options for pictures, add-ons, music, movies and tv show libraries.
- If no extrafanart is available, regular fanart will be visible.
8.2.7 (2-August-15)
- Updated rating media flags.
- Added UK BBFC media flags for script.globalsearch.
- Updated Kiosk Mode.
- Updated mouse support in fullscreen video OSD for subtitles and 3D button.
- Bugfixing of fullscreen video OSD.
- Added skin settings to select multi image path for tv / radio channels / recordings.
8.2.6 (29-July-15)
- Updated support for script.imdbupdate.
- Removed support for script.duration and added skin support instead.
- Added alternative duration support for ExtendedInfo and movie sets.
8.2.5 (25-July-15)
- Added ExtendedInfo Discography button to artist / album information windows.
- Added ExtendedInfo Youtube Music Videos button to artist / album information windows.
- Updated OSD seekbar with skip step progress bar.
- Added studio logo to infopane in movie and tv show libraries.
- Custom categories and submenus will now keep previous settings after they are disabled.
- Bugfixing of home screen General category custom submenus.
- Added custom submenus for the System category.
8.2.4 (22-July-15)
- Removed star rating from music artists.
- Fixes and repositioning of OSD bookmarks dialog.
8.2.3 (20-July-15)
- Fixes for keyboard dialog auto completion.
- Center aligned subtitles dialog.
- Updated global search information windows to use ExtendedInfo.
- Added Extra Info button to menubar in global search information windows (requires script.extendedinfo).
- Bugfixing and update of movie sets visible conditions.
- Bugfixing of movie sets views and view options.
- Updated navigation for ExtendedInfo windows.
- Redesign of sort letter notification.
- Bugfixing of paused in fullscreen video.
- Removal of zorder.
8.2.2 (15-July-15)
- Updated context menu button 2001.
- Fixed navigation bug in ExtendedInfo video information window.
- Fixed some media flag images in red and orange themes.
- Added skin setting in Home to use colored category images in the home screen (blue / orange / red - according to the selected theme).
8.2.1 (12-July-15)
- Added "Mirror Image" button to file browser dialog.
- Update of PVR channels OSD dialog.
- Update of PVR channels window labels.
- Bugfixing of movie set media flag in Wall View.
- Added onclick functions to info labels in ExtendedInfo video information windows.
- Added Reviews to ExtendedInfo video information window.
- Added Extended Information button to the context menu in movie and tv show libraries.
- Updated movie set information window to use script.extendedinfo.
8.2.0 (4-July-15)
- Added menubar dialog to artist / album information windows with 4 buttons: Extra artist info, Popular Tracks, Similar Artists, Search Youtube (requires script.extendedinfo / plugin.video.youtube).
- Added menubar dialog to movie / tv show / season information windows with 3 buttons: Extra Video Info, Similar Videos, Search Youtube (requires script.extendedinfo / plugin.video.youtube).
- Added "Search Youtube" button to episode / music video information windows (requires plugin.video.youtube).
- Added button to ExtendedInfo video information window for local tv shows to enter season / episode library.
- Added season and episode labels for ExtendedInfo tv show information window.
- Update and bugfixing of ExtendedInfo episode information window.
- Bugfixing of trailer buttons using plugin.video.youtube.
- Added 2 color themes: red and orange (big thanks to PetitDroud).
- Changed play / open button label in video information window.
- Added Youtube Browser for script.extendedinfo and script.youtube.browser (requires manual installation).
- Redesign and positioning of OSD slider dialog.
- Bugfixing of Artwork Downloader when downloading music video artwork using the skin settings add-ons section.
- Added view option for ExtendedInfo video list window Thumbnail View to display either Year / Rating or Genre labels.
- Added List View and List Info 3 View for ExtendedInfo video list window.
- Added skin setting in General to enable/disable autocompletions for keyboard dialog (requires installation of script.extendedinfo).
- Updated support for TV Tunes add-on.
- Removed TV Tunes skin settings. All settings are now handled in the TV Tunes add-on settings.
- Updated support for script.videoextras.
- Update and bugfixing of Artist Slideshow add-on.
8.1.5 (10-June-15)
- Bugfixing of global search audio media flags.
- Added additional studio logos.
- Updated ExtendedInfo according to latest changes: duration changes, hide buttons for tv show and episode content.
- Added rating votes to ExtendedInfo video list window.
- Added T9 Live Search for ExtendedInfo video list window.
- Added AutoCompletions to keyboard dialog using ExtendedInfo script.
8.1.4 (2-June-15)
- Added network logo to ExtendedInfo tv show information window.
- Added some info labels to ExtendedInfo tv show information window.
- Added View Options (hide title / hide scrollbar / hide fanart) to ExtendedInfo video list window.
- Added background fanart images to ExtendedInfo video list window.
- Added studio logo to movie set information window.
- Added support for the add-on service.nextup.notification (http://forum.kodi.tv/showthread.php?tid=228435).
8.1.3 (26-May-15)
- Movie Set Information window: added onclick function to movie set list to trigger script.extendedinfo.
- Added Season Information button to context menu in season library (requires installation of script.extendedinfo).
- Updated default icons.
- Bugfixing of ExtendedInfo breadcrumbs.
8.1.2 (22-May-15)
- Added support for script.duration (http://forum.kodi.tv/showthread.php?tid=220753) to display alternative duration (eg. 1H54 instead of 114). Needs to be enabled in the skin settings.
8.1.1 (19-May-15)
- Added Clean Library (videos and music) to the presets dialog when adding custom categories and submenus.
- Added user specified action (using the keyboard) in the bottom of the presets dialog when adding custom categories and submenus.
8.1.0 (18-May-15)
- Added support for actor / director / writer / artist / movie / tv show / season information (old metadata actors) using script.extendedinfo.
- Added 3 panels (widgets) when creating custom categories: In Cinemas / Upcoming Movies, New DVDs / Upcoming DVDs, Trending Movies / Trending TV Shows (requires script.extendedinfo).
- Improved DTS-HD Master Audio and DTS-HD High Resolution audio media flags.
- Added season / episode number, writer and director labels to Live TV fullscreen info dialog (needs a PVR backend that provides this info).
- Added season / episode number to Live TV Channels and Recordings windows (needs a PVR backend that provides this info).
- Increased width of Live TV recording information dialog.
- Added "Edit info labels" button to context menu in libraries (requires manual installation of script.libraryeditor).
- Added "Filmography" and "Actor / Artist / Director Information" button to context menu in libraries (requires installation of script.extendedinfo).
- Added "Movie Set Information" button to context menu in libraries (movie sets or movie set list item) (requires manual installation script.skin.info.service).
- Added Movie Set Information window (requires manual installation of script.skin.info.service).
- Bugfixing of Cinema Experience button in Movie Information window.
- Added Cinema Experience button in movie library context menu (needs installation of script.cinema.experience).
8.0.11 (5-May-15)
- Replaced Party Mode submenu in Videos category to Play DVD, but only when a DVD is inserted.
8.0.10 (2-May-15)
- Added new default icon.
- Added skin setting in Media to disable rating media flags.
- Bugfixing of library options dialog.
- Added missing DTS-HD Master Audio / High Resolution Audio media flags when playing fullscreen video.
- Fixed aspect ratio of DVD media flag.
- Bugfixing of HD-DVD / DVD media flags when playing fullscreen video.
- Added media flags: subtitle count and audio language count (requires script.skin.info.service). Enabling too many media flags may break the bottom layout.
- Changed labels throughout the skin from watched movies, tv shows, episodes and music videos to unwatched.
8.0.9 (19-April-15)
- Fixed missing fallback fanart image for landscape thumbs.
- Increased brightness of genre label for movies, tv shows, episodes, music videos and pvr channels.
- Added movie set media flag.
- Changed skin setting "Hide top bar when idle" to not apply when using Wall View.
- Update / bugfixing of global search windows and added EPG search.
- Created seperate add-on with sound files (resource.uisounds.rapier).
- Added "Add-ons updated" label to the info pane in the addon browser.
8.0.8 (8-April-15)
- Fixed double images in Icon View for focused items.
8.0.7 (5-April-15)
- Added skin setting in General to hide the top bar when idle (after 3 seconds).
8.0.6 (1-April-15)
- Bugfixing of the movie information window when playing trailers windowed.
- Bugfixing of background images when scaled (improves quality).
- Added selectable scripts (in Programs) to the presets dialog when adding custom categories and submenus.
- Upgrade and design changes of OSD bookmarks dialog.
8.0.5 (23-March-15)
- Added small wall view style for movies and tv shows with 5 x 14 posters.
8.0.4 (22-March-15)
- Updated kiosk mode for PVR windows.
- Updated Add-ons custom panel to display all video and music add-ons instead of 20 random add-ons.
8.0.3 (16-March-15)
- Updated kiosk mode for add-on information window.
8.0.2 (10-March-15)
- Bugfixing of navigation in top options menu bar (pictures and addon browser).
- Added button in addon browser to check for updates.
8.0.1 (9-March-15)
- Added new default icons.
8.0.0 ISENGARD (5-March-15)
- Updated skin.rapier to Kodi 15.x Isengard.
- Added button in PVR Group Manager dialog to hide/unhide a group.
- Added premiered label to PVR programme info dialog.
- Reorder of PVR top options menu bar.
- Added 3 buttons to PVR top options menu bar: Filter, Show Hidden Channels and Deleted Recordings.
7.3.1 HELIX (3-March-15)
- Fixed aspect ratio for default icon in tv shows banner view.
- Positioning fixes for unwatched episodes overlay in tv shows banner view.
- Alignment fixes for buttons in PVR programme info dialog.
- Added genre label to PVR views (can be disabled in the view options).
7.3.0 HELIX (2-March-15)
- Fixed broken fanart for add-ons in pictures, programs, videos and music libraries.
- Bugfixing of library update button in the top options menu bar.
- Added a skin setting in Media -> Videos to play trailers windowed in the movie information window.
- Added items to the presets dialog (music) when creating custom categories or submenus: recently added songs, top 250 songs, top 250 albums, play random song, play random album.
- Added items to the presets dialog (tv shows) when creating custom categories or submenus: play random unwatched episode.
- Added items to the presets dialog (movies) when creating custom categories or submenus: in progress, top 250, unwatched, play random unwatched movie.
- Added items to the presets dialog (music videos) when creating custom categories or submenus: unwatched, play random unwatched music video.
- Added items to the music and movie library options dialog: in progress movies, top 250 movies, top 100 songs, top 100 albums, recently added songs.
- Fixed bug in Live TV submenu.
- Updated support for script.globalsearch to include actor results.
- Added startup screen when loading widgets (mainly PVR channels).
- Added PVR TV / Radio Channels widget (can be disabled in the Skin Settings -> Home -> Info Panel).
- Updated navigation for lyrics dialog and OSD when playing fullscreen music.
- Added banner image as fallback image for the home screen tv shows today widget, if no clear logo is available.
- Added a Skin Setting in Backgrounds to change the fanart background refresh interval to any value (defaults to 8 seconds).
7.2.0 HELIX (19-January-15)
- Updated Rapier icon.
- Fixes for List View and TV Shows List Info 2 View.
- Added fadelabel (next track) in music fullscreen window.
- Updated Skin Settings export/import from script.extendedinfo to script.toolbox (https://github.com/phil65/script.toolbox). You need to manually install the script.
- Changed autologin radiobutton to button in profiles window.
- Updated infopane in profiles window.
- Fixed some missing labels in List View, List Info View, List Info 2 View, Wrap Info View and Wide List View.
- Fixed missing fanart in music Thumbs Info View.
- Added selectable add-ons (music, videos, programs, pictures) to the presets dialog when creating custom categories or submenus.
- Added selectable paths (music, videos, programs, pictures) to the presets dialog when creating custom categories or submenus.
- Added selectable playlists (music, videos) to the presets dialog when creating custom categories or submenus, and the choice to either play or enter them.
- Added tags and in progress tv shows (tv shows) to the presets dialog when creating custom categories or submenus.
- Fixed scrolling animation in the right list in presets dialog.
- Added Wall View for tv shows.
- Fixed navigation bugs in the home screen.
- Added Upcoming TV Shows widget using script.tv.show.next.aired. Enable it using script.tv.show.next.aired add-on setting "Show All TV Shows for home screen" and restart Kodi.
- Added missing label to PVR Timer Settings dialog.
- Added UK BBFC media flags.
- Added additional default icons.
- Added Cancel button to select dialog.
- Fixed several bugs in custom categories/submenus. This requires you to set the paths again, when using favourites. Icons, images, backgrounds, panels, labels and also presets are not at all affected.
- Fixed positioning of select dialog when selecting visualization while playing fullscreen music.
- Bugfixing of view animations.
- Added support for PVR series recording using PVR WMC Client.
- If you need support for NextPVR Client, delete the file RecordPrefs.xml from the skin.rapier/720p/ folder and rename the file RecordPrefs.xml.NPVR to RecordPrefs.xml
- Added stream information to fullscreen information dialog when playing live tv.
- Added PVR Stream Information when displaying codec info for fullscreen live tv.
- Changed In Progress (recommended) widget for music albums to Featured (random).
- Fixed dimming of fullscreen video when paused.
- Added Information button in fullscreen video OSD to display the information dialog.
- Bugfixing of music and video library breadcrumbs.
- Added Tags and In Progress TV Shows to tv shows library options dialog.
7.1.0 HELIX (25-December-14)
- Update and bugfixing of OSD bookmarks dialog.
- Added watched/unwatched overlays in movie information, tv show information, episode information, music video information dialogs.
- Update of movie sets support in library windows and additional views added for movie sets.
- Added support for script.skin.info.service (http://forum.kodi.tv/showthread.php?tid=203196) for movie sets information.
- Fixed bug in custom panel type dialog.
- Added additional custom home category images to the extras folder.
- Added skin setting in "Media" to enable both visualization and artist fanart when playing music.
- Skinning and updated support for script.globalsearch.
- Added skin setting to display titles for home screen add-on shortcuts.
- Updated language files (thanks to alanwww1).
- Update and bugfixing of PVR Channel Manager dialog and PVR Group Management dialog.
- Added player controls to the home screen progress bar when playing music (for better touch support).
- Minor update of Kiosk Mode.
7.0.0 HELIX (27-November-14)
- Updated skin.rapier to Kodi 14.x Helix.
- Update, bugfix and rewrite of all PVR.
- Added PVR Radio options to the presets of the custom categories and custom submenus.
- Changed submenu items in the home screen Live TV category.
- Added "TV" and "Radio" custom category images.
- Added Launch button to add-on information window.
- Added "Hide incompatible" button to menubar in add-on browser.
- Redesign and update of keyboard dialog.
- Changed logo to the official Kodi logo.
- Positioning fixes.
- Added additional media flags.
6.3.1 GOTHAM (20-November-14)
- Navigation changes.
- Changed zorder of numeric dialog.
6.3.0 GOTHAM (18-November-14)
- Fixed keyboard dialog to be on top when subtitles dialog is visible.
- Fixes for extended progress dialog when media is scanning.
- Skin Settings: Created seperate "Animations" and "Weather" categories to make the skin settings easier to navigate.
- Update of language strings.
- Changed List Info View posters, thumbs and banners throughout the skin to be more in style with the design.
- Added onclick function to video information directors button.
- Added IMDb Top 250 info to movie information window.
- Redesign, bugfixing and update of movie information, tv show information, music video information, episode information windows.
- Redesign, bugfixing and update of add-on information, album information, artist information windows.
- Added movie sets and tags to the presets of the custom categories and custom submenus.
- Added view option to display the title (artist/track etc.) on the top bar in the music library.
- Movie / TV Show library: pressing right or down on the scroll bar in certain views, plays the trailer for the focused item.
- Removed support for Weather Underground and added full support for OpenWeatherMap Extended.
6.2.1 GOTHAM (11-October-2014)
- Updated language files from Transifex. (Big thanks to alanwww1)
6.2.0 GOTHAM (9-october-14)
- Updated tv shows unwatched episodes overlay in all views.
- Added skin option to select custom background for all system settings and skin settings windows.
- Added view option to display the default thumbnail image for episodes List Info 2 View.
- Added episode number in episodes List Info View and List Info 3 View.
- Fixed landscape images for tv shows and episodes.
- Added next aired info to episodes List Info 3 View: latest episode and next episode (can be disabled in the View Options).
- Added unwatched episodes and watched overlay in tv shows 3D Wrap View.
- Added fanart for music videos.
- Added List Info 2 View for music videos.
- Bugfixing of breadcrumbs.
- Added view option to display tv thumb (landscape) in tv shows 3D Wrap View.
- Added next aired info in tv shows 3D Wrap View: latest episode and next episode (can be disabled in the View Options).
- Added watched partial overlay to movies 3D Wrap Flat Style View and Thumbs Info Clear Logo View.
- Updating and bugfixing of OSD seekbar labels.
- Added Spotify and TV Guide home menu images to the extras folder.
- Bugfixing of the menubar in add-on information dialog for touch devices.
- Positioning fixes for File Manager.
- Added extended info panel for movies Wall View. This can be enabled in the view options.
- Changed opacity on home screen submenus to be 10% brighter when they are unfocused.
- Fixed animation for the home screen next aired widget and added support for up to 18 shows.
- Update and redesign of the weather window and full support for Weather Underground add-on.
- Added support for movie and tv show custom genre icons. Add your .png images to skin.rapier/extras/moviegenres/
- Added support for music custom genre icons. Add your .png images to skin.rapier/extras/musicgenres/
6.1.0 GOTHAM (8-September-14)
- Moved skin setting "Hide Seekbar" to Media: OSD.
- Positioning fixes for the skin settings.
- Fixed genre for tv shows List Info Banner View.
- Added a trailer button to the context menu in movies and tv shows.
- Added List Info 3 View to tv shows.
- Added next aired status, latest episode and next episode to tv shows video information window.
- Added next aired info to tv shows List Info Poster View, List Info 3 View and Thumbs Info View: latest episode and next episode (can be disabled in the View Options).
- Added some next aired info labels to episodes List Info 3 View.
- Fixed trailer button in video information dialog to use Youtube plugin if no other trailer is available.
- Position fixes for clear art in tv shows Thumbs Info View.
- Fixes for video and music codec info.
- Added additional video source, video codec and audio media flags.
- Changed label2 in tv shows List View / List Info View / List Info 2 View when the sort method is title to display unwatched episodes and watched overlay.
- Added unwatched episodes and watched overlay in tv shows Thumbnail View, Banner View and Thumbs Info View.
- Update and redesign of select dialog and file browser dialog.
- Redesign and update of TV Show Next Aired windows.
- Added TV Guide submenu to the home screen tv shows category.
6.0.2 GOTHAM (11-August-14)
- Fixes for tv show OSD clear logos, clear art and covers.
- Added full support for movie OSD clear logos and clear art. You will need to select your preferred setting again under Skin Settings -> Media -> OSD.
- Fixed paused label under fullscreen video.
- Fixed missing scrollbar in profiles.
6.0.1 GOTHAM (25-July-14)
- Changed onclick function in the status bar when playing music or video to display the Player Controls dialog.
- Bugfixing of the Shutdown Menu.
- Bugfixing of the Power submenus.
- Fixed sort method: added one button in the menubar to replace the popup dialog.
- General bugfixing.
6.0.0 GOTHAM (22-July-14)
- Update of Rapier for XBMC 13.x Gotham.
- Fixed navigation issue in EPG Timeline.
- Updated Video OSD + added buttons/menus for 3D and subtitles.
- Redesign of subtitles dialog.
- Removed Stack and Flatten buttons from the menubar.
- Added autologin button to profile settings.
- Added 2 buttons to New Smart Playlist dialog: Group By and Mixed.
- Added 2 buttons to the menubar: Go To Playlist and Fullscreen.
- Added a progress indicator in the EPG Timeline.
- Added additional media flags and media flag support.
- Redesign of Song Lyrics Dialog.
5.7.1 (22-July-14)
- Added OK button to picture information dialog box.
- Added close buttons to PVR dialog boxes.
- Changed handling of OSD clear logos and clear art.
- Added fast forward / rewind buttons to Live TV OSD.
5.7.0 (16-July-14)
- Added button for CDArt Manager in Album Information / Artist Information menubar.
- Changed the defaultcontrol in DialogKeyboard.xml so it focuses the "Done" button.
- Added duration label, menubar, context menu, clearlogo etc. in script.videoextras detailed list window + added support for music video extras.
- Added additional support for script.tvtunes in music videos.
- Added a setting to the Skin Settings: General to change date format - eg. "FEB 4, 2014" or "4 FEB, 2014"
- Added full support for custom submenus in the home screen PVR category
- Removed support for old fanart method and updated support for script.grab.fanart
- Tweaked Song Information dialog
- Added scrollbar to Addon Settings dialog for better navigation.
- Fixed tv shows Icon View when selecting TV Thumbs.
- Updated tv shows List Info 2 View and Thumbs Info View to make them more in style with the rest of the skin.
- Updated movies Thumbs Info View to make it more in style with the rest of the skin.
- Updated all List Info Views to make them more in style with the rest of the views.
- Added clear logos to all episode views in the info pane.
- Completely removed support for skin handling of local images (clear logo, clear art, landscape etc.). This is now handled by Artwork Downloader in the advanced settings.
- Added season information in episodes Wide List View.
- Removed double icons on parent folder items in various views.
- Changed broken clear logo view in tv shows Wide List View to a new layout using clear art.
- Added clear logo view style when using Movies Icon View.
- Added clear logo view style when using Movies Thumbs Info View.
- Added scroll animations to all Thumbs Info Views in movies / tv shows.
- Update and bugfixing of the Shutdown Menu.
- Updated submenus in the home screen Power Category.
- Fixed aspect ratio on Home Screen now playing widget cd art cover.
- Added onclick function to the status bar when playing music or video to enter the music visualisation or fullscreen video (to better support touch devices).
- Added clear logos in the music library when CDArt Manager is installed. When you enter the skin settings, you will be prompted to enter your music library path (this can also be done manually).
- Removed some redundant view options (hide plot/description, hide poster). If you miss your favourite view option, please let me know.
- Bugfixing on PVR + added info pane media details.
- Updated animations for category icons and add-on shortcuts in the home screen.
- Changed category icons and add-on shortcuts in the home screen, so it is now possible to have both enabled at the same time.
- Added a warning dialog when selecting a custom category icon in the skin settings, and an add-on shortcut has already been enabled for that particular category.
- Fixed some navigation issues in the home screen.
- Removed CustomPanelAddons script and replaced with service.skin.widgets random add-on.
- Fixed background for Addon Information dialog in Music and Videos.
- Added a completely new view type: 3D Wrap (with 3D style and flat style) for movies and tv shows (inspired by Rapier Qualar Mod - thanks to Qualar). SEE THE PICTURES BELOW.
5.6.1 (1-Jan-14)
- Bugfixing on the InfoPane under Thumbnail View Movies / TV Shows and added additional View Options.
- Bugfixing on script.videoextras detailed list
- Added clear logos in all views under Movies and added View Option to enable/disable.
- Updated Artwork Downloader in the Skin Settings under Add-ons
5.6.0 (31-Dec-13)
- Fixed skin settings navigation bugs.
- Added settings for script.extendedinfo to the skin settings.
- Fixed all code for script.randomandlastitems
- Added TV Show Next Aired Status mediaflag to tv show views.
- Added clear logo to tv show seasons view.
- Added 3D media flag.
- Added List Info View for tv show seasons.
- Added View Option for display of TV show title in breadcrumbs
- Bug fixing and additions to breadcrumbs
- Full support for script.videoextras (http://wiki.xbmc.org/index.php?title=Add-on:VideoExtras)
5.5.0 (21-July-13)
- Added TV Show Next Aired widget in home screen with shows airing today using clear logos (can be disabled in the skin settings).
- Bugfixing for v5.4.0
5.4.0 (20-July-13)
- Added support for IMDb Update (http://forum.xbmc.org/showthread.php?tid=167754) in the skin settings.
- Fixed bugs in the Weather Notification.
- Added battery notification when using a laptop (can be enabled/disabled in the skin settings).
- Added power icon.
- Changed home screen top left XBMC logo to script.globalsearch button including full navigation support for this.
- Fixed global navigation from menus to make Home button (top left) work properly in all views.
- Fixed issues with the scrollbar in the settings (makes it easier with touch devices).
- Added full support for script.grab.fanart (http://forum.xbmc.org/showthread.php?tid=166572) to replace the broken fanart backgrounds in the home screen.
- Script.grab.fanart can be configured in the Skin Settings under Backgrounds or Add-ons (no need to use the settings in the add-on itself).
- Added add-on shortcuts for the home screen. This can be enabled and configured in the Skin Settings under Home (enabling this will disable all category icons).
5.3.2 (13-July-13)
- Fixed bugs in the new star rating.
- Fixed bugs in View Options menu.
5.3.1 (28-May-13)
- Added View Option for half star rating in Movies, TV Shows and Episodes
- Fixed some image problems (fanart etc.)
- Fixed BreadCrumbs (thanks to kenoi)
5.3.0 (25-Apr-13)
- Fixed transparency issues with AddonInformation etc.
- Fixed order of dialogs in fullscreen video.
- Added a progressbar on home screen main menu when music is playing (can be disabled in Skin Settings under Home).
- Added support for script.libraryeditor in fullscreen InformationDialogs for movies, tv shows, music videos and music (http://forum.xbmc.org/showthread.php?tid=158775).
- Updated and fixed BreadCrumbs.
- Updated support for clearlogo and clearart
- Fixed TV Show Thumbs Info View to fully support clearlogo and clearart (thanks to past79)
5.2.1 (07-Mar-13)
- Added a Skin Setting under General to hide the top options menu bar (show it when selected) or to display it constantly.
- Fixed focus problems in Skin Settings with custom backgrounds for music.
- Updated Add-on Settings dialog box: menu items align vertically for easier use.
5.2.0 (02-Mar-13)
- Added support for clearlogos under TV Shows.
- Fixed issues with artwork downloader + added Settings button under Skin Settings.
- Added Power Menu in home screen.
- Added an option in Skin Settings for the use of script.globalsearch in menus instead of regular XBMC Search.
- Added a Closed Caption media flag icon for video with subtitles.
- Included Spanish translation - thanks to PatOso.
5.1.0 (03-Feb-13)
- Updated Frodo support for script.artwork.downloader and added support in Music Videos and Skin Settings.
- Updated RandomMovie and RecentlyAdded triggers for playing media
- Added support for banners in Thumbs Info View under TV Shows.
- Fixed media flagging for DVD's + some general things.
- Updated Sort Order and added Channels for PVR.
- Setting under Movies in View Options to display the movie title on the top bar.
- Updated icons and thumbs.
- Added a "Paused" label for paused fullscreen video. Select/deselect this in the Skin Settings, under Media.
- Updated DialogSelect.
- Added Subtitle Settings and Lyrics Settings buttons in Skin Settings.
5.0.1 (17-Jan-13)
- Included an option for display of TV Show banner under List View (only available for TV Show Seasons).
- Updated image support for Movies and TV Shows.
5.0.0 (12-Jan-13)
- Updated skin to Frodo.
- Added Auto Update, Notifications and Hide Foreign buttons for AddonBrowser.
- Removed Get Thumb and Get Fanart button for DialogVideoInfo and added Choose Art instead (to support multiple image types)
- removed script.randomitems and script.watchlist and added support for service.skin.widgets
- Added support for Filter.
- Updated menus and Breadcrumb to support Movie Tags.
- Updated DialogPictureInfo to provide more info.
- Added a progress bar for DialogBusy.
- Added an option for display of "Paused" in picture slideshow (Skin Settings).
- Updated Live TV in Settings.
- Added support for new audio flags: DTS-HD Master Audio and DTS-HD High Resolution Audio
Full changelog can be viewed here.
TRANSLATIONS
Translation of the skin is handled on Transifex. Please sign up or join the project to translate this skin.
A huge thanks to all the translators for the great work - it's really appreciated!
RAPIER UI SOUNDS ADD-ON
Kodi 15.x Isengard allows skins to add the skin UI sounds as a seperate add-on. Resource.uisounds.rapier ("Rapier UI Sounds") has been added to the official repository. This new feature allows you to choose other UI sounds to use with the skin instead of the built-in ones.
SUPPORTED AND RECOMMENDED ADD-ONS (AUTOMATIC INSTALLATION)
Artwork Downloader (Martijn)
Artist Slideshow (ronie, pkscout)
Favourites script (ronie, `Black)
Global Search (ronie)
Random and Last items script (MikeBZH44, Martijn, `Black)
Skin Widgets (Martijn, phil65)
TV Show - Next Aired (Ppic, Frost, ronie, `Black, phil65)
Skin Helper Service (marcelveldt)
SUPPORTED ADD-ONS (KODI ADD-ON REPOSITORY INSTALLATION)
CU LRC Lyrics (Taxigps, ronie)
CDArt Manager (Giftie)
ExtendedInfo Script (phil65)
OpenWeatherMap Extended (ronie)
CinemaVision (CinemaVision)
Cinema Experience (Giftie)
Library Node Editor (Unfledged, Team-Kodi)
PVR WMC Client
Next PVR Client
DVBLink PVR Client
service.nextup.notification (im85288)
SUPPORTED ADD-ONS (MANUAL INSTALLATION)
TV Tunes (Ppic,Frost,ronie,robwebset)
Video Extras (robwebset)
MyPicsDB (Xycl, MikeBZH44, Alexsolex)
IMDB Update (Jandalf)
Library Editor Script (phil65)
script.youtube.browser (phil65)
DONATIONS
If you like Rapier and want to buy me a coffee or beer, feel free to donate. Greatly appreciated! Wink
DONATE
Checking it out now Smile
Rapier 8.0.0 for Kodi 15.x Isengard is now available in the official Kodi add-on repository.
(2015-03-08, 12:53)Gade Wrote: [ -> ]Rapier 8.0.0 for Kodi 15.x Isengard is now available in the official Kodi add-on repository.
Thank you for the best ever created XBMC/Kodi Skin ever in my opinion it has everything I like Smile ,And you are indeed a Master Skinner Smile
Great Work and a work I've been using for quite some time now and I would wish this skin to be for as long as Kodi Exist in my time Smile
Thank you again.
Hi Stefan.
Thanks so so much for all the kind words. Feedback (especially positive, hehe) is really what motivates further development and keeping this project updated.
Scarfa is the original creator of Rapier, and Ihave been maintaining it since XBMC Frodo.
Thanks again!
Cheers
Gade
Very welcome Gade and yes I know Scarfa is the original creator of Rapier but you have maintained it perfectly and without you there would be no Rapier so give yourself a big bunch of credit friend.
Cheers and thank you again Smile
I have created an add-on repository for Rapier.
This means that if you install this repository, you will always automatically receive the newest and freshest development updates of Rapier.
You will still automatically get the official updates.
To install this repository for Kodi Isengard, you must do so by following these steps:
  1. Download the zip file from the Github link above
  2. Start Kodi
  3. Navigate to Settings
  4. Add-ons
  5. Install from zip file
  6. Locate the zip file you downloaded
  7. Install
you know that you can provide one single repo adoon containing all versions?
https://github.com/xbmc/xbmc/blob/master...on.xml#L11
(2015-03-15, 20:52)Martijn Wrote: [ -> ]you know that you can provide one single repo adoon containing all versions?
Hi Martijn.
Thanks a lot for the tip.
It's my first time creating repos, and I have now made one for all versions - and it seems to work properly Smile
Cheers
Gade
(2015-03-15, 20:48)Gade Wrote: [ -> ]I have created an add-on repository for Rapier.
  2. Start Kodi
  4. Add-ons
  7. Install
Note that these updates of Rapier are for the latest Isengard nightlies, so if something isn't working properly, this most likely is the cause.
Very nice Smile thank you.
Finally got Isengard installed and could try out the new Rapier. (It was quite the ordeal to get Isengard working.)
Rapier is working great with new Kodi. Really like the ability to hide the options bar when not in use. Also finally saw the option for conditional weather artwork. I don't use the weather screen all that much, but the conditional art is neat to have when I do.
The only little issue I've seen is that I don't have the "Manage..." option in the context menu when selecting a tv show. I needed to remove a couple of shows from the database in order to rescan them and had to go into Confluence to do it. I've seen that happen in previous versions too, so it is probably something with my set up. Not a big deal though to switch over as I don't need that option very often.
Can't wait to see what you do with Phil's extendedinfo script. Will be nice to have access to actor biography and filmography while watching the movie they're in.
(2015-04-09, 05:12)Thales Wrote: [ -> ]Finally got Isengard installed and could try out the new Rapier. (It was quite the ordeal to get Isengard working.)
Hi Thales.
Glad you decided to try out Isengard, and that Rapier is running smoothly.
The "Manage" button is not visible as long as Kodi is scanning your libraries for new content. As long as that is finished, the "Manage" button will appear again. This should be the same for Rapier, Confluence and all other skins.
The extended info script didn't make it into the latest update, but will probably be included in the next Smile
A new update is available. This update includes bugfixing and new features - some are described below. As usual, please report if you experience any bugs or have feature requests Smile
Rapier 8.0.8 is available through the official Kodi repository!
This update is installed automatically.
If this is not the case, you can download it here.
CHANGELOG
8.0.8 (8-April-15)
ENJOY!
Great work and another good release Smile
