Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
(2015-03-15, 19:18)bromix Wrote: [ -> ] (2015-03-15, 18:58)mrmls Wrote: [ -> ]I'm having issues with signin when using Raspbery Pi B (too?),
the logs: http://xbmclogs.com/pgd8kdpjk
Can you switch to 'Debug'...so we can see more in the log...this is strange.
new log:
http://xbmclogs.com/pkaeavrdq
actions taken:
I went to Video Add-ons->Vimeo->Sign in
there were my credentials already entered
pressed OK,
no errors visible, but not signed in as well; only options I see are the Feature, Search, Sign in.
(2015-03-15, 22:20)mrmls Wrote: [ -> ] (2015-03-15, 19:18)bromix Wrote: [ -> ] (2015-03-15, 18:58)mrmls Wrote: [ -> ]I'm having issues with signin when using Raspbery Pi B (too?),
new log: http://xbmclogs.com/pkaeavrdq
actions taken:
pressed OK,
Found it...should be working again with the final 4.0.3
I have v4.0.2 installed, but it's not showing an update available, and checking for updates doesn't come back with anything.
I'm on an rPi OpenELEC v5.0.4, Kodi 14.2 helix beta
(2015-03-16, 21:24)cmeans Wrote: [ -> ]I have v4.0.2 installed, but it's not showing an update available, and checking for updates doesn't come back with anything.
Update was merged just an hour ago. Check for updates or Force Refresh.
Still no update available.
(2015-03-17, 01:03)cmeans Wrote: [ -> ]Still no update available.
I'm on raspbmc and I don't have update available either. Although 'last updated' is set to current time.
I'll just wait for now.
I tried to 'install from zip' v.4.0.3, but that didn't solve the issue with sign in. Maybe that was because upgrade didn't really work. Just waiting now.
Have you ttird to uninstall and re-install the addon?
I've uninstalled it, but it still only shows 4.0.2 as the available version to install.
Is 4.0.2 the version available in the official repo, and 4.0.3 is only available in Bromix's repo?
If that's not it, try doing a force refresh on Bromix's repo and see if that get's you the newest version.
The update is now available (at least to me)
, and it appears to be working fine.
Yeah!
Any chance of adding Vimeo On Demand support to this addon? I can add a watch-later to on demand videos (High Maintenance), but they only play the trailer when I try to access them through kodi.
On raspbmc I still have 4.0.2, but that's a minor issue for now and probably not related to the plugin as such.
I uninstalled the plugin and installed 4.0.3 from the zip and still can't sign in:
The logs:
http://xbmclogs.com/pklkx8ufy
If more info necessary, let me know.
After uninstall+re-install the config files remained in the system and I didn't enter new credentials. Just in case, that could make the difference..
(2015-03-17, 21:15)mrmls Wrote: [ -> ]On raspbmc I still have 4.0.2, but that's a minor issue for now and probably not related to the plugin as such.
The logs: http://xbmclogs.com/pklkx8ufy
Can you please use my Repos for installing addons. Now you have this:
plugin.video.vimeo-4.0.3
Under the addon folder.
(2015-03-17, 20:42)Diskotechjam Wrote: [ -> ]Any chance of adding Vimeo On Demand support to this addon? I can add a watch-later to on demand videos (High Maintenance), but they only play the trailer when I try to access them through kodi.
At the moment not because I use a different API. For the current API vimeo doesn't allow me to create a new 'APP' for Desktop. If someone can help with this I'm glad to try to implement based on that API.
great addon
bromix
having installed 4.0.3 i fail a successful login. there is no error message in Kodi
see my log
http://xbmclogs.com/peuuvatpm[/b]
