I have a random code question, in the FileBrowser.xml file (thats the file when say you want to choose artwork for a movie, say a poster for example) Browse is listed at the very end of the list after all of the remote image list's, does anyone know how to move browse to the top of the list above the remote images?
That would be allot handier I think. That way you don't have to scroll down past all the remote images (which in turn, loads them all from the web)
Thanks for any assistance.
Press the up direction key once.
(2015-08-29, 06:52)brazen1 Wrote: [ -> ]Press the up direction key once.
Yes I know about that but thanks. I use a wireless mouse most of the time.
Not quite sure where to post this problem? I'm not sure it's a skin issue, but figured I'd start here. I've got a large number of videos that don't display language flags. They are all mkv and the language headers are set properly. I've tried refreshing the listings. Even tried removing and re-adding them.
Here's one example-
Header info from MediaInfo-
General
Unique ID : 67476763680285636838137948947097735999 (0x32C38D4E0D2A9029FA6BA6CA68BE533F)
Complete name : /Volumes/Media/XBMC/Movies/16 Blocks (2006) HDTV/16 Blocks (2006).HDTV.mkv
Format : Matroska
Format version : Version 2
File size : 3.38 GiB
Duration : 1h 41mn
Overall bit rate : 4 772 Kbps
Writing application : HandBrake 0.10.0 2014112200
Writing library : Lavf55.12.0
Language : und
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 41mn
Width : 1 920 pixels
Height : 1 088 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 41mn
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : Surround
Language : English
Default : Yes
Forced : No
Anybody have any ideas?
[/quote]
Could that be the problem ?
(2015-08-29, 14:09)sarlan19 Wrote: [ -> ]Quote:Anybody have any ideas?
Didn't even see that. Language is set to English for all video and audio tracks, not sure how to change that setting though.
(2015-08-29, 14:31)wgstarks Wrote: [ -> ] (2015-08-29, 14:09)sarlan19 Wrote: [ -> ]Quote:Anybody have any ideas?
und is normal
script.videolanguage is installed ?
(2015-08-29, 14:39)schimi2k Wrote: [ -> ]und is normal
Not sure how to check. Some videos do display the correct flags though.
Just a stab in the dark but, do you have a language flag image called und.png? I ask cause I checked mine and I don't?
Checked the addons folder and no script.videolanguage, so I installed it. Didn't make any difference though, still no language flags.
(2015-08-29, 15:51)ShadowTek Wrote: [ -> ] (2015-08-29, 14:09)sarlan19 Wrote: [ -> ]
I probably don't, but the headers are set to english and I do have that flag. It's displayed for some of my videos. Just not all of them.
Just for testing, where could I get the und.png flag from?
what country is it? You can check the media\flags\language folder and see if that flag is there called something else, then make a copy of it and name it und.png, place it it folder and see if that does the trick.
It may show for some movies because it uses a different country code then und
(2015-08-29, 16:48)schimi2k Wrote: [ -> ]und=undifined
Ahh, I feel rather silly lol, was searching around trying to figure out what country that was :/
I don't have a und.png. und stands for undertermined. (Edit : Schimi beat me to it !)
My mkv don't have a language entry in the General section of the header, I don't know why wgstarks have it. If a langage entry is available on audio tracks in the header the language icon DO appear when I play the file and they stay there then. Note that most of my files poses no problem.
You can edit Mkv header with MkvToolNix header editor
