Lockos I fixed some issues already so I cannot test that anymore. I just checked all library views for France:-12 and France:-16 and they work... Now... But not sure if they always did...
Please try latest from Git.
EDIT: I don't have porn either but I am not French so I just picked a rating to add to my library
EDIT 2: Bare minimum means some icons are missing as well as support for Games and probably some other little stuff like that. In other words unless you find an issue the skin should work just fine with Leia!
mikeSiLVO
Video source flag :
OK
Ratings in info pannel :
OK
Ratings in view and info pannel for -12 and -16 :
as I was afraid of, still not workin...
If that can be a helping hand, I think that a setting in german ratings for ages 12 and 16 is overwriting the french ones, which make them display instead of the french ones.
The thing that gave me that clue is that there is not GermanU or German-10 or German-18
I will not miss my mission of reporting all the little bugs here and there, I like my skin to be perfect. And games support is not a big deal for me, I'll keep launching BigBox through Kodi
Anyway, thanks a lot for your help !
Lockos You need to be more specific as to where it is not working cause I cannot see what you see. Your image from your original post does not work for me...
A screenshot would be helpful in knowing where it does not work correctly.
Lockos You are correct. There is a problem in the VAR. I didn't notice cause I assumed the rating I saw was correct but I cannot tell the difference between French and German ratings
Fix is on Git
Thanks a lot Mike, you're the best !
(2019-02-17, 19:40)meowmoo Wrote: [ -> ]@mikeSiLVO
Hi again
for some reason the CDart in the MusicViz SiLVIO view and in Includes_NowPayingBottom dont work. it always shows the vinyl, I try to fix it for my self but i failed :/
the bad thing is on my PC both works fine only on my Linux Box it dont work so I guess its a Typo but i cant find any...
If you have some spare time and can take a look it would be very nice
Thanks you !
Hi Mike, just quoting myself, maby you can take a look
mikeSiLVO if you have time, something is remaining from yesterday. It's the same bug with german flag instead of french is ocurring for video playback.
During playback (in the left corner) for instance I have a -6 FSK German flag instead of a csa:-12 french one. Thx
(2019-03-16, 11:57)meowmoo Wrote: [ -> ] (2019-02-17, 19:40)meowmoo Wrote: [ -> ]@mikeSiLVO
Hi again
Thanks you !
Please post a screenshot of where you're talking about. Also what settings are you activating and where?
(2019-03-16, 12:18)Lockos Wrote: [ -> ]@mikeSiLVO if you have time, something is remaining from yesterday. It's the same bug with german flag instead of french is ocurring for video playback.
Should be fixed on Git now.
Damn you're fast ! Thank you !
(2019-03-16, 21:32)mikeSiLVO Wrote: [ -> ] (2019-03-16, 11:57)meowmoo Wrote: [ -> ] (2019-02-17, 19:40)meowmoo Wrote: [ -> ]@mikeSiLVO
Hi again
Thanks you !
Here it shows the cdart (MooViz option)
https://imgur.com/SnDi6Cf
when i change to "Silvio" it only shows vinyl
https://imgur.com/wWsKG4K
settings
https://imgur.com/VbQl3sI
also in the Home menu it only shows vinyl, settings are all "turned on"
https://imgur.com/EPWWHTK
thanks for taking a look
(2019-03-17, 16:59)meowmoo Wrote: [ -> ] Here it shows the cdart (MooViz option)
settings
Problem seems to be Skin Helper Service related. None of the player art INFOlabels are populating for me. MooViz works cause it is looking for cdart.png in the folder path.
Do you use Artwork Beef?
Skin Helper isn't maintained anymore so I think I should remove all support for it and just use the Music Information folder and/or Artwork Beef to add the missing images so we can use regular ol' INFOlabels for discart and logos...
Yes I use artwork beef.
If skinhelper isn't maintained anymore, infolabel should be the way to go, since v18 finally added the missing ones like cdart/banner the music side of kodi finally get some love..
(2019-03-17, 20:14)meowmoo Wrote: [ -> ]Yes I use artwork beef.
Alrighty then... This is gonna be a decent change so I am going to do it in stages to minimize issues. The biggest complaint from others that I can foresee is current users who will be disappointed when their discart/logos/whatever don't work anymore. I hope some folks here can take the time to help out others with issues migrating to these changes.
I don't use MadNox unless fixing problems that are posted here so I definitely need feedback from those that are interested.
Please check GitHub for updates and let me know of any problems you notice
(2019-03-18, 04:07)mikeSiLVO Wrote: [ -> ] (2019-03-17, 20:14)meowmoo Wrote: [ -> ]Yes I use artwork beef.
I will test thoroughly also. Thanks Mike.
Regards,
Bart
Sure, will help out as much as I can.
Thanks again Mike, for all the work you out in this skin to keep it alive!
