Using Shelf 3D view... in the upper left corner either an Icon is displayed or SEASON 01/ SEASON 02, etc.
What causes some shows to ONLY show the Show Icon instead of Season listing? I rescraped all my tvshow.nfo and reloaded Kodi. No changes on some shows. Ideas?
I did notice at the bottom of my nfos it just had plot info. After scrape, I get season info and tvdb id listed at the very bottom. I figured that would mean something, but no. I used Texture Cache Utility and reloaded each. Nothing.
****I think I got it. As long as the Seasons are scraped with the .nfo showing individual seasons listed at the bottom, it'll be good. Gotta delete the shows individually and clear the cache. I had to reset my system 2 or 3 times, but it finally grabbed them all. It's hard to see the season # from the cover art side, so it's nice to have at the top too. Amazing stuff.
Based on Ember's old scrape options, it wasn't available. I had to scrape every show again. Worth it.
i apologize for asking this again as i've seen no replies to my question. i've been using this skin since it was in private beta.
on the jarvis master build how can i use smart playlists? i can see nothing for smart playlists now, for instance if you want to show latest movies for a smart playlist like i didn in the past. where smart playlists used to be is widget settings or something like that. just not sure how to do what i used to in this jarvis build. i read the first post again and didn't see anything either. i'm sorry if there is something i'm missing.
thanks
(2015-12-30, 04:53)Mr. V Wrote: [ -> ]I am working on the madnox widgets as write this post. All fonts and highlight colours ect will be taken care of, so it will be identical to silvo widget in every other way including all widget options. Everything will work the same as nox silvo. The only exception will be the widget info dialog for the media flags. Not sure how you guys plan to handle this in the future with the addition of the image resource addons in Jarvis. If any changes are needed it as simple some small changes to the widget vars.
Correct on the system info widget, this will be added not long after I push the big update. The main thing that would slow me down for the system info widget is artwork. For each static item I need a square icon and fanart image. If schimi2K could provide some artwork that would be great. It would help me speed things up for the system info widget.
For the mixed widgets they wont be available at the time of the update. I would just use the skin helper mixed widgets. With some small changes to the overrides they should mostly work. I actually had them working within silvo but removed them temporally. All the widget Vars artwork should support mixed widgets. So this will be another addition after the big update.
Just send me the sizes in pm and i make you everything you need buddy ( will contact you later... Still in bed with tablet hehe) and i mean the stuff for silvo mod too
(2015-12-30, 05:54)McButton Wrote: [ -> ]Using Shelf 3D view... in the upper left corner either an Icon is displayed or SEASON 01/ SEASON 02, etc.
Will check it later...
(2015-12-30, 06:21)knives of ice Wrote: [ -> ]i apologize for asking this again as i've seen no replies to my question. i've been using this skin since it was in private beta.
thanks
Hey buddy... Are you using the git version of sir bob with new widgets? If yes i need to make a new howto... You need to work with a second playlist... The old System should work like before...
Big update for all for the widgets. I have 100% implemented everything within silvo widgets to madnox, too much to test to see if it is fully working or not so I invite the community to try and break the widgets. I have done some basic testing and all seems ok.
Things to note;
- Now playing Info visibly condition are not complete. So there may be some slight overlap.
- I have temporally removed the system info widget. I will re-add this soon with additional options
- The way you select the widget type has changed (for now anyway). More to think about and discuss with bob.
- Lots of missing icons when selecting widget type
The Widgets;
- 'General main menu settings' is the place to look for global widget settings
- 'Setup the madnox main menu' all settings on a per widget basis are here.
- This is for KODI JARVIS ONLY, so if you install this on isengard expect things to break. So bug reports only if you are running JARVIS.
If you don't already know this is the GitHub link to the skin shortcut branch which is the same branch as mentioned in previous posts.
https://github.com/Ignoble61/skin.aeon.m...cuts/1080i
THX Mr.V
will test it later this day
Many Thanks Mr. V, like Schimi will test it soon for you.
Mike.
Hi Mr. V
The 'sort order' and 'sort by' don't seem to work for playlists. When selecting 'sort by' and choosing ascending it sets 'sort order' in the window and sort order isn't selectable, nothing appears to allow random to be selected. I have a playlist which is configured as Random but is not working when selected. I know Bob did a change with regards to 'random' but that may have been lost with the latest update?
This seems to be widget 2, if I setup widget 1 as random I get sort by and sort order and it works but not widget 2?
Also, sources is no longer available as a choice or Skin shortcuts defaults as well?
Infolines aren't working as well.
Mike.
I tried Mr V widgets they cool but I wish when we choose cleartart display there is option not to show panel in background in silvo there is no option to remove panel like you can in madnox so hopefully there is an option and regarding mixed widgets it was one of coolest options so hopefully get added back in future
The new widgets look great! Other than what has already been mentioned, if you remove the label when selecting a widget there are no options for art, case, etc. Backspace to remove the label, then a space and the options show up. Not a biggie, just thought I'd mention. Thanks.
Mr V., thank you so much! In general, the widgets work great.
I have seen also some of the issues mentioned, like the infolines not working for any menu option. I have encountered a couple more issues:
1. I have no labels for the weather widget, just icons. I think this is something that Bob Cratchett looked at and fixed before, so I guess we can expect a fix in the future. Also, there is no possibility to select a label type for the weather widget, the option is not there.
2. For the Recent Episodes widget, the only widget art types I can select are poster and fanart, and before we could select most of the same types available for movies (clearat, banner, thumb, etc)
I will continue to test and report other issues, if any, as I find them.
Regards,
Bart
(2015-12-30, 18:50)bsoriano Wrote: [ -> ]Mr V., thank you so much! In general, the widgets work great.
Regards,
Bart
Bart, both of your problems are fine on my setup
. Just a fyi.
Thanks bobrap!
I will do a full reset of my settings for MadNox and skin.shortcuts and see how it goes.
Regards,
Bart
Can any of you confirm that you can get cleart art widget view without any panel in backgroud
like just clearart and not background at all
? cos i tried in silvo there was no option to remove panel background completely
