(2017-01-01, 03:30)meowmoo Wrote: [ -> ]Im pretty sure there is one
Happy new Yeah, bzw
Well I can't seem to find it.. That's why I'm asking here..
Sent from my SM-G935W8
(2017-01-01, 03:47)Netix Wrote: [ -> ] (2017-01-01, 03:30)meowmoo Wrote: [ -> ]Im pretty sure there is one
Happy new Yeah, bzw
Sent from my SM-G935W8 (typie typie)
Customize main menu - select your categorie - delete
Envoyé de mon iPhone en utilisant Tapatalk
(2017-01-01, 04:34)sarlan19 Wrote: [ -> ] (2017-01-01, 03:47)Netix Wrote: [ -> ] (2017-01-01, 03:30)meowmoo Wrote: [ -> ]Im pretty sure there is one
Happy new Yeah, bzw
There's no customize main menu button...see above link
(2017-01-01, 04:48)meowmoo Wrote: [ -> ]
Yeah.. Sorry.. Didn't know it was a defiling menu.. Can I go hide now? [emoji21]
Just wondering if this has been put on the back burner for some reason. Haven 't seen any updates in awhile. Thanks for a great skin and Happy New Year to everyone!
Is there/ what is the way to make the INFOLINE have a dark background to always show? Mine is very transparent, and is difficult to see most of the time.
The main menu bar is fine, but the rest isn't.
I feel like I've adjusted everything and can't seem to get it right.
Also, it appears that my TV Infoline has stopped updating. If I add or remove a show, neither the Show amount or Episode amount updates. The Movie version works fine. I have removed, changed, and reset. No change. Ideas? Nothing new has happened to my box in months. It worked fine until yesterday.
Nobody? Seems like easy biz.
I'm sure I can delete the source and rescan, but in case it happens again...I'd rather have a quick fix option
Kodi v17.0 Krypton RC2,
The lastet from GITHUB and installed
all addons, on Win10.
No case 4k Ideas ?
watch gallery
(2017-01-02, 18:47)McButton Wrote: [ -> ]Nobody? Seems like easy biz.
Have you setup the source correct? When you set the source for the movies, you can setup, movies, tv shows etc...
Has anyone else noticed that when you watch a new film or tv show, the main screen widget for recently added movies or tv shows dont get removed !
Unless I've got a setting wrong, was working fine on Jarvis 16.1
Source is solid. I've been using the same source types for like 10 years. This is a skin glitch. I'll just reset the sucker. I just want the weird random pathway fix option...but...I'll just blame technology.
If I can figure out how to get those dang Infolines to stay dark...I'd be set.
(2017-01-02, 23:26)zorg2000k Wrote: [ -> ]Has anyone else noticed that when you watch a new film or tv show, the main screen widget for recently added movies or tv shows dont get removed !
Recently added shouldn't remove them due to you watching them, by default. They were still recently added.
I don't remember if Nox has a setting under the widget menu to adjust as such. There is a hide option somewhere.
McButton, for infolines try changing / removing lines 445 & 500 in Includes_MainMenu.xml, these are colordiffuse for the infoline backgrounds left and right.
I'm using Kodi supplied props for TV counters and working fine here.
forgot to say, have you tried the different options the skin gives already? go to Customer home window furniture, then left when main menubar is hihlighted. This should take you to the library stat bar and then press return, then try the 'bar style' options.
