2017-05-16, 00:37
2017-05-16, 00:39
Oh. I thought this was supposed to be a native PVR client for SD DVR. I assumed that meant showing me recordings, timers, etc.
2017-05-16, 14:07
@rykr Use the official SiliconDust video plug-in to record.
2017-05-16, 14:55
Right. I'm familiar with that plugin and have used it before. I was just under the impression that this plugin was trying to be a full PVR client for SD DVR. I see now that is not the case.
2017-05-27, 21:24
The Plex DVR addon is crap, there is no proper guide, it is not intuitive. That is not to say that the KODI app is any better either. 4 to 8 hours of Guide data makes it absolutely not usable in the living room, and allowing the guide to scroll back in time beyond the current time is just not workable.. I was hping that Silicondust would allow more guide data.. right now, the only good and reliable system for watching live TV including DRM channels from a PC remains MCE!
2017-05-27, 22:34
@ronvp this is a third party add-on. It can be updated to utilize the 24 hour guide allowance recently announced someone just has to do it.
2017-05-28, 22:34
-- deleted --
2017-06-27, 17:19
I'm switched back to Linux from Windows because Windows 10 was annoying me with all of it's damn Windows Update pop-ups and other annoying notifications while watching stuff on Kodi, but the problem is that when I installed the kodi-pvr-hdhomerun add-on (version 2.4.2+git20160820-2) from the Ubuntu 17.04 repository and then enabled it in Kodi(Version: 2:17.1+dfsg1-1ubuntu0.1) it works, but when I restart Kodi it says the add-on isn't compatible with this version and disables it. If I go in and re-enable it, it works as expected.
How can I get it to stop disabling the add-on??
Edit: fixed this by installing Kodi from the TeamXBMC PPA instead of the one included with Ubuntu.
2017-06-28, 01:55
Why can we not build in support for Schedules direct? the 24 hour is really not sufficient enough, for scheduling recordings
2017-06-28, 01:58
(2017-06-28, 01:55)ronvp Wrote: [ -> ]Why can we not build in support for Schedules direct? the 24 hour is really not sufficient enough, for scheduling recordings
Because it's a standalone HDHomerun PVR addon and specific to their api. You are welcome to contribute a PVR backend for HDHomerun which includes Schedules direct support
2017-06-28, 02:04
Thanks, I will continue to use MCE until something else comes along. I think we are good to go unit l2022 or so..
2017-06-28, 02:12
(2017-06-28, 02:04)ronvp Wrote: [ -> ]Thanks, I will continue to use MCE until something else comes along. I think we are good to go unit l2022 or so..
Not to redirect or spam this thread... PseudoTV Live has built in HDHomerun Support and includes Schedules Direct Support... unfortunately you'll have to wait for v.0.9.x for the Schedules Direct feature.
https://www.youtube.com/watch?v=QFY-YqQr1xQ
https://twitter.com/PseudoTV_Live/status...9129507841
2017-07-04, 23:14
If only we could schedule and record with this add-on
The SD addon is crap - you need to subscribe to SD to enable recording
Argus for OTA and NextPVR for CableCard Encrypted are the only two solutions at present
If Argus supported CC Encryption (for non premium channels) it would be great, but there's been nothing gong on there for more than 3 years
NextPVR - well the UI is not that great...
2017-07-04, 23:43
Or get yourself a Pi, stick TVheadend into it and feed it with your hdhomerun.
It's the setup I run and it works beautifully, including recording.
2017-08-07, 01:15
(2017-07-04, 23:43)DarrenHill Wrote: [ -> ]Or get yourself a Pi, stick TVheadend into it and feed it with your hdhomerun.
Hey Darren, can you suggest a simple pi to get that is ready to go and possibly a guide you would recommend? I have an Hdhomerun and overall I'm pretty techy with stuff but I've never tried any of the Pi stuff.
