Thanks @
wrxtasy, most seems working now one thing which i wanted to confirm and not sure is this even possible to configure; Possible to get Smart TV cursor pointer to control the menus , playback with center click ? I'm specifically looking for LG Web OS Remote cursor.
Does anyone have issues with playing 4k content? I have a 12gb test clip that runs my 50mb buffer empty(pressing 'o' while playing). I tried increasing the buffer size with advancedsettings.xml but it seems the system doesn't recognise the changed setting after a reboot. I used example 4 as per the wiki.
Has anyone gotten 23.976 fps video to play properly on the C2? All my 23.976 content plays back at 24 fps, which introduces a slight stutter every 30-40 seconds.
Thanks, wrxtasy!! Downloading now...
(2016-06-27, 01:47)infinity85 Wrote: [ -> ]Your procedure with lircmap.xml is actually correct. But "KEY_EPG" should be the context menu button (sounds weird, but is true). In your case since I guess that you mapped this particular button KEY_EPG for your needs to PVROSDGuide. Well... this blocks the button then for the actual context menu function.
But you can work around it. As you need the PVROSDGuide mapping of KEY_EPG only while watching LiveTV, you can alter this mapping with your Lircmap.xml and especially in a custom remote.xml in this its particular LiteTV-xml-section. Look at my Lircmap.xml and remote.xml:
storage\Userdata\Lircmap.xml:
<lircmap>
<remote device="devinput">
<xbox>KEY_HOME</xbox> -- mappt die EXIT Taste der Harmony mit remote.xml als Homebutton! >
<select>KEY_OK</select> -- Hilfsmap für remote.xml: Dort wirds als OSD Channel list im LiveTV interpretiert >
<hash>KEY_1</hash> -- mappt die cmd1 DisplayTaste der Harmony mit remote.xml als Untertiteldownload >
<volumeplus>KEY_2</volumeplus> -- mappt Cmd2 displaytaste der Harmony mit remote.xml als SubtitleShiftUp >
<enter>KEY_VCR</enter> -- mappt die Guide Taste der Harmony mit remote.xml als EPG im Fernsehen und als Filmliste bei Filmen >
<playlist>KEY_3</playlist> -- mappt toggle watched auf die +-clear-Taste der Harmony neben der 0 in der remote.xml >
<volumeminus>KEY_4</volumeminus> -- mappt Cmd4 displaytaste der Harmony mit remote.xml als SubtitleShiftDown >
<teletext>KEY_5</teletext> -- Videodatenbank aktualisieren gemappt auf Harmony E(nter) Taste neben der 0 in remote.xml >
<star>KEY_6</star> -- togglet den gewählten OpenVPN-Server. Mappt auf remote.xml>
<!--star>KEY_7</star--> -- mappt die cmd7 DisplayTaste der Harmony mit Hilfe der remote.xml zum neuladen der keymaps ohne neustart >
</remote>
</lircmap>
storage\Userdata\keymaps\remote.xml:
<keymap>
<global>
<remote>
<xbox>ActivateWindow(Home)</xbox>
<green>ActivateWindow(Videos,MovieTitles,return)</green> -- startet ueber die gruene taste direkt die Filmliste, auch wenn vorher mal Genre usw an war! >
<blue>ActivateWindow(Favourites)</blue>
<red>Action(PlayPvrTV)</red> -- startet direkt in Vollbild LiveTV, und per OK kann man OSD Kanalliste starten >
<star>RunScript(service.network.openvpn,toggle)</star> -- mappt von der Lircmap.xml die cmd6 taste der lircd.conf und togglet somit den gewählten OpenVPN-Server>
<!--star>Action(reloadkeymaps)</star--> -- mappt das Aktualisieren der keymap.xml und lircmap.xml auf die cmd7 taste! >
<volumeplus>Action(SubtitleDelayPlus)</volumeplus>
<volumeminus>Action(SubtitleDelayMinus)</volumeminus>
<playlist>Action(ToggleWatched)</playlist>
<teletext>XBMC.UpdateLibrary(video)</teletext>
</remote>
</global>
<FullscreenLiveTV>
<remote>
<select>ActivateWindow(PVROSDChannels)</select> -- dadurch kann man mitten Im Fullscreen LiveTV per OK Taste die OSD Kanalliste anzeigen >
<enter>ActivateWindow(TVGuide)</enter> -- KEY_ENTER ist die Harmony Guide taste in der licd.conf und mit enter in remote.xml verbunden. Dadurch wird nur im TV Vollbildschirm das EPG aufgerufen >
</remote>
</FullscreenLiveTV>
<FullscreenVideo>
<remote>
<hash>ActivateWindow(SubtitleSearch)</hash> -- mappt die cmd1 DisplayTaste der Harmony mit remote.xml als Untertiteldownload >
</remote>
</FullscreenVideo>
</keymap>
An example:
1. In lircmap.xml I have the buttons KEY_OK mapped to <select> for remote.xml
2. in remote.xml I take this <select> (which is actually KEY_OK thanks to lircmap.xml) and map it to PVROSDChannels BUT in the <FullscreenLiveTV> section. So the OK button on my remote will function in GUI and during Movies as the usual OK respectively ENTER button, for navigation and for options. But only during LiveTV it will show an OSD List with all the channels to choose. In fact if you choose a channel and press the OK button it will function as OK to actually tune the channel and not as the mapped PVROSDChannels function (so it's fortunately absolutely intuitive).
You will have to transfer this example to your situation. As I don't have mapped the KEY_EPG button in my lircmap.xml I apparently agree with its default mapping, so... you could perhaps just leave the KEY_EPG button (which is strangely not really starting the EPG per default) as is, thus without any changed mapping. And just take some other button from the namespace like KEY_VCR (which is not really used I think, or at least not useful mapped per default) for your favourite PVROSDChannels button. Just open your storage\Configfiles\lircd.conf and exchange the current KEY_EPG there with KEY_VCR. Then you can map this KEY_VCR the same way as I did this in my lircmap.xml to a particular button in remote.xml.
But of cource KEY_EPG is gone then I think (but try it first... perhaps it depends in which section it is in remote.xml). You'll then have to allocate in lircd.conf your Harmony button which you want to use for Contextmenu and then assign this line the KEY_EPG. Then contextmenu will work out of the box. Just don't remap anywhere in lircmap.xml the KEY_EPG.
Here is my lircd.conf (Harmony 900):
# Please make this file available to others
# by sending it to <[email protected]>
# this config file was automatically generated
# using lirc-0.9.1-git(default) on Thu Jun 25 17:39:38 2015
# contributed by
# brand: KLS /storage/.config/lircd.conf
# model no. of remote control: VDR 1.6
# devices being controlled by this remote: VDR 1.6 (Videorekorder --> PVR Gerät in Harmony)
begin remote
name /storage/.config/lircd.conf
bits 13
flags RC5|CONST_LENGTH
eps 30
aeps 100
one 906 871
zero 906 871
plead 900
gap 113816
min_repeat 2
suppress_repeat 4 # war eigentlich auskommentiert!
# uncomment to suppress unwanted repeats
toggle_bit_mask 0x800
begin codes
KEY_NUMERIC_0 0x12C0 #HarmonyOriginal: Taste 0
KEY_NUMERIC_1 0x12C1 #HarmonyOriginal: Taste 1
KEY_NUMERIC_2 0x12C2 #HarmonyOriginal: Taste 2
KEY_NUMERIC_3 0x12C3 #HarmonyOriginal: Taste 3
KEY_NUMERIC_4 0x12C4 #HarmonyOriginal: Taste 4
KEY_NUMERIC_5 0x12C5 #HarmonyOriginal: Taste 5
KEY_NUMERIC_6 0x12C6 #HarmonyOriginal: Taste 6
KEY_NUMERIC_7 0x12C7 #HarmonyOriginal: Taste 7
KEY_NUMERIC_8 0x12C8 #HarmonyOriginal: Taste 8
KEY_NUMERIC_9 0x12C9 #HarmonyOriginal: Taste 9
KEY_EXIT 0x12E2 #HarmonyOriginal: Taste Prev (zurück)
KEY_EPG 0x02C9 #HarmonyOriginal: Taste Menu (Contextmenü)
KEY_OK 0x02C8 #HarmonyOriginal: Taste OK
KEY_UP 0x02C4 #HarmonyOriginal: Cursor Hoch
KEY_DOWN 0x02C5 #HarmonyOriginal: Cursor Runter
KEY_RIGHT 0x02C7 #HarmonyOriginal: Cursor Rechts
KEY_LEFT 0x02C6 #HarmonyOriginal: Cursor Links
KEY_VCR 0x02CB #HarmonyOriginal: Taste Guide (Overlay)
KEY_RED 0x02C0 #HarmonyOriginal: Taste rot (LiveTV)
KEY_GREEN 0x02C1 #HarmonyOriginal: Taste grün (Filme)
KEY_YELLOW 0x02C2 #HarmonyOriginal: Taste gelb (Musik)
KEY_BLUE 0x02C3 #HarmonyOriginal: Taste blau (Bilder)
KEY_CHANNELUP 0x12E0 #HarmonyOriginal: Taste Kanal+
KEY_CHANNELDOWN 0x12E1 #HarmonyOriginal: Taste Kanal-
KEY_INFO 0x02CC #HarmonyOriginal: Taste Info
KEY_HOME 0x02CA #HarmonyOriginal: Taste Exit (Kodi Homebildschirm in Verbindung mit remote.xml und Lircmap.xml)
KEY_STOP 0x12F6 #HarmonyOriginal: Taste Stop
KEY_RECORD 0x12F7 #HarmonyOriginal: Taste Rec
KEY_PLAY 0x12F5 #HarmonyOriginal: Taste Play
KEY_PAUSE 0x12F3 #HarmonyOriginal: Taste Pause
KEY_NEXT 0x12F1 #HarmonyOriginal: Taste Skip
KEY_PREVIOUS 0x12F0 #HarmonyOriginal: Taste Replay
KEY_FASTFORWARD 0x12F4 #HarmonyOriginal: Taste Fwd
KEY_REWIND 0x12F2 #HarmonyOriginal: Taste Rew
KEY_LANGUAGE 0x02D1 #HarmonyOriginal: ImDisplay: Audio (Audiospuren toggln)
KEY_SUBTITLE 0x02D2 #HarmonyOriginal: ImDisplay: Untertitel (Untertitel toggln)
KEY_0 0x02CD #HarmonyOriginal: ImDisplay: Commands
KEY_1 0x02F0 #HarmonyOriginal: ImDisplay: Cmd1
KEY_2 0x02F1 #HarmonyOriginal: ImDisplay: Cmd2
KEY_3 0x02F2 #HarmonyOriginal: ImDisplay: Cmd3
KEY_4 0x02F3 #HarmonyOriginal: ImDisplay: Cmd4
KEY_5 0x02F4 #HarmonyOriginal: ImDisplay: Cmd5
KEY_6 0x02F5 #HarmonyOriginal: ImDisplay: Cmd6
KEY_7 0x02F6 #HarmonyOriginal: ImDisplay: Cmd7
KEY_8 0x02F7 #HarmonyOriginal: ImDisplay: Cmd8
KEY_9 0x02F8 #HarmonyOriginal: ImDisplay: Cmd9
KEY_CHANNEL 0x02D3 #HarmonyOriginal: ImDisplay: Channels
KEY_POWER 0x12CC #HarmonyOriginal: ImDisplay: Aus (triggert Aus per Software für CEC...also RemotePi sonderskript für Softwareshutdown nötig!)
KEY_POWER2 0x12CB #HarmonyOriginal: ImDisplay: Ein (Auf RemotePiBoard programmiert Kaltstart)
KEY_SUSPEND 0x128C #HarmonyOriginal: ImDisplay: Ein-/Ausschalten (RemotePiBoard auf Aus Programmiert (für alle Fälle, aber dank "Software Aus" nicht nötig)
KEY_PVR 0x02CE #HarmonyOriginal: ImDisplay: Recordings
KEY_SETUP 0x02D0 #HarmonyOriginal: ImDisplay: Setup
KEY_TIME 0x02CF #HarmonyOriginal: ImDisplay: Zeitgeber
end codes
end remote
I chose this harmony profile:
Device: PVR
Brand: KLS
Model: VDR 1.6
The reason is that I have round about 10 programmable buttons left, that I can map to what I want. The Media Center SE thing is working out of the box quite well, but there are not more enough buttons to map them to functions like subtitle download or VPN On/Off or Audiostream switching and so on.
Lets say you decide to take over my config... you would just need to copy those 3 files I posted above and but them into the given directories. They will override the default mappings only for the buttons that are mentioned in those files (all others remain mapped default). You would just need to add the KLS VDR 1.6 device in your harmony remote. I'm just not sure how big the differences are between my old Harmony 900 and your new model.
Try to play around with this info and if there are still questions, I'll try to sort them out .
Thank you very much for all your information and ideas.
PVROSDChannels looks really cool in
<FullscreenLiveTV> with AEON Nox.
Got it all to work, no more questions. Now I can use more functions I ever believed.
Greetings from Schleswig-Holstein
Hoppel
(2016-06-27, 22:03)hoppel118 Wrote: [ -> ]Thank you very much for all your information and ideas. PVROSDChannels looks really cool in <FullscreenLiveTV> with AEON Nox.
Hoppel
You're welcome
. Tried this PVROSDGuide and kinda like it! Did not know that this existed, so thanks to you
Backported libCEC from Kodi Krypton, modded by Gerald Dachs for AML v3.1.0 Firmware v5
Kodi > Settings > System > Inputs > Peripherals >
This greatly improves HDMI-CEC remote button repeat signalling and noticeably improves usability:
LibreELEC-Odroid_C2.aarch64-7.0.2.use.Kry.Pulse8.tar
W.
(2016-06-27, 14:47)Fredabc Wrote: [ -> ]Does anyone have issues with playing 4k content? I have a 12gb test clip that runs my 50mb buffer empty(pressing 'o' while playing). I tried increasing the buffer size with advancedsettings.xml but it seems the system doesn't recognise the changed setting after a reboot. I used example 4 as per the wiki.
hi
i have the same issue depending on the format (from network)
trailer tested had issues if they are in X264
no issues in H265
maybe it could be a "limitation" to the format or a decoding issue.
do you play your clip from the network oir on a usb stick ?
i tried directly on usb stick on the tv embedded player and no issue...
(2016-06-28, 10:10)gnzb78 Wrote: [ -> ] (2016-06-27, 14:47)Fredabc Wrote: [ -> ]Does anyone have issues with playing 4k content? I have a 12gb test clip that runs my 50mb buffer empty(pressing 'o' while playing). I tried increasing the buffer size with advancedsettings.xml but it seems the system doesn't recognise the changed setting after a reboot. I used example 4 as per the wiki.
hi
no issues in H265
I play all my files from my network.
check your file format and tell us which one it is
hi
no issues in H265
I'm not having trouble playing files from my network, but I have serious caching problems when playing any content from the internet. I get "Cache full before ..." message each time, and every minute or so, playback stops while the cache refills. I'm using about 300MB of RAM with over 1.5GB available, but I have not been able to make >any< change to this with the advancedsettings controls - I've tried the examples and variations of my own, and none seems to change anything at all.
UPDATE: My advancedsettings.xml file was not properly formatted, but I fixed that. I can now see its contents are being read into the log, but still nothing has changed with caching. I'm still using at most 15% of available memory to cache.
The cache is on the ram ? or on the SD/EMMC card inserted ?
How is the compatibility for driving non-CE resolutions via the HDMI port? Like 1280x800 or 1920x1200?
