2012-03-04, 16:46
2012-03-05, 01:30
konti Wrote:It's not an issue with XBMC. It seems there's an issue with the website of theghost16 that is used by the scraper. There is an issue with his mysql server. Let's just wait for theghost16 to fix it.
@Thegost16 I suggest to hide the "user friendly" error messages. It provides too much information.
Oke hope he will fix it soon whant my Dutch movie info back hahaha
2012-03-05, 10:06
I changed some database settings last week and was thinking it would work but i will try to fix this ASAP.
EDIT: Problem is fixed it should work now.
2012-03-05, 16:55
yes downloading moviemeter ingo again ty for the fix
2012-03-18, 22:41
these two movies fail to download info:
Karen Llora en un Bus (2011)
and
Guizi Lai Le (2000)
Does scaper need to be "fixed" to get them to download? The information is exactly as listed on the site.
thanks!
and
Guizi Lai Le (2000)
thanks!
2012-03-19, 10:49
I could find both movies. So I think something else is going wrong.
Can you enable debug logging and see what it says.
2012-03-19, 13:21
Edit: Oops, I misread your answer, I'll turn on the debugging level and post the results.
thanks.
thanks.
2012-03-20, 12:29
I COULD find both movies in Moviemeter and on my own website. Now trying to add them to XBMC to see what happens then.
Edit: Tested with XBMC and also find them both. Could you update your library again and see what happens.
2012-03-20, 22:50
Hmmm... I now was also able to refresh the information and update the info from moviemeter. The previous time I did this a keyboard appeared to enter a name and now I could select the correct entry.
Maybe XBMC just wasn't able to connect to the internet service at that time? Or should that produce an error?
2012-03-21, 09:39
It could be that the movies weren't known to my website so it has to look at the moviemeter website. And my website already made 5000 requests to the API and therefore it couldn't find anything.
But I don't know this for sure.
I'm glad it works.
I'm glad it works.
2012-03-25, 21:05
I have movie which I've not been able to scrape for a couple of days now. I have the debug log so maybe you can see why it's not working?
The title of the movie is Le Havre (2011).
If I manually go to http://www.theghost16.nl/MovieMeter/inde...e%20(2011) I get the following message:
Movie already not found today.
thanks!
20:58:44 T:6180 DEBUG: ADDON::CScraper::FindMovie: Searching for 'Le Havre' using MovieMeter scraper (path: 'C:\Users\admin\AppData\Roaming\XBMC\addons\metadata.moviemeter.nl', content: 'movies', version: '1.2.0')
20:58:44 T:6180 DEBUG: scraper: CreateSearchUrl returned <url>http://www.theghost16.nl/MovieMeter/index.php?movie=le%20havre%20(2011)</url>
20:58:44 T:6180 DEBUG: FileCurl::Open(0124C5A0) http://www.theghost16.nl/MovieMeter/index.php?movie=le%20havre%20(2011)
20:58:44 T:6180 INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://www.theghost16.nl
20:58:44 T:6180 DEBUG: scraper: GetSearchResults returned <?xml version='1.0' encoding='iso-8859-1' standalone='yes'?><results></results>
thanks!
2012-03-26, 08:40
I looked at the movie and i tried to find it.
But in Moviemeter I can find the movie by using this title but I can't find the movie by using the API of Moviemeter.
I've added this to my own database by hand so it can be found. But it could be that the information that is shown isn't complete.
2012-03-26, 10:28
2012-03-30, 15:28
I have multiple movies that don't get scraped, f.e.
Abduction (2011)
No: http://www.theghost16.nl/MovieMeter/inde...=abduction
Yes: http://www.theghost16.nl/MovieMeter/inde...%282011%29
Why does year have to be added instead of just "abduction"?
Captain America - The First Avenger (2011)
No: http://www.theghost16.nl/MovieMeter/inde...%20america
Why not only part of movie name?
Thanks in advance!
Abduction (2011)
Thanks in advance!
2012-04-04, 16:25
(2012-03-30, 15:28)Dr_IT Wrote: [ -> ]I have multiple movies that don't get scraped, f.e.This is because there can be more than one movie with that title. In this case with the movie Abduction there are 3 movies found.
Abduction (2011)
(2012-03-30, 15:28)Dr_IT Wrote: [ -> ]Captain America - The First Avenger (2011)For this case it is the same as the above one. It can find more than one movie and therefore give incorrect results.
For the scraper it is very important to have correct filenames because that makes the result much more accurate.
