Full Version: Auto frame rate switching & dynamic range matching - 4K (HDR10) capable Hardware
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
Start a thread over here in the LibreELEC AMLogic Subforum and ask, you will find users with working 4K HDR S9xx boxes that come with inbuilt DVB-S2 tuners:
https://forum.libreelec.tv/board/38-amlogic/
(2018-03-14, 18:32)hdmkv Wrote: [ -> ]I ‘burned’ the Android.img file onto mSD using Win32 Disk Imager, and used toothpick method to boot to it and install.
 Thanks`
(2018-03-14, 17:18)wrxtasy Wrote: [ -> ]When AML Android devices are pretty much bricked (not WeTek) you use the Amlogic USB Burning Tool and a Win. PC and whatever Android Firmware .img file that is compatible with your AML Android device like:
rom-vorke-z6-tanix-tx92-tvstock-nexus-rom-android-tv-7-1 (click)
Then there is this method using an OTA_update.zip file for whatever AML device you have:
Tutorial - how to recover / unbrick the U9 (click)
Kodi DSPlayer should probably be included, even though it isn’t an official Kodi. It does everything mentioned at the highest quality due to the use of madVR.
(2018-03-19, 01:24)Warner306 Wrote: [ -> ]Kodi DSPlayer should probably be included, even though it isn’t an official Kodi. It does everything mentioned at the highest quality due to the use of madVR.
Is this the thread you are talking about ?
HOW TO - Set up madVR for Kodi DSPlayer & External Players (click)
Confirming auto colorspace switching works for SDR <<-->>HDR, Without a user having to go back into Windows settings all the time ?
Please also detail a list of specific hardware (if possible) and which Windows OS is needed for 4K Windows HDR video playback so I and other users do not need to go on an easter egg hunt ?
(2018-03-19, 05:36)wrxtasy Wrote: [ -> ]
 Auto color space conversions are handled by the Calibration feature in madVR. Any color space can be matched to what your display is calibrated to. HDR is turned on and off as needed, as long as you are using the right GPU. So this isn't the cheapest option.
For Kodi DSPlayer, you need:
Thx. added to the list in Post #1 Smile
@wrxtasy, you can now add Zidoo X9S as being able to properly manage auto frame rate switching & resolution switching, with the right color spaces. Hope @wesk05 is able to add his (more technical) insights.
This is with the just released beta f/w v2.0.15. Switches between 720p/1080p/2160p, 23.976/24/25/50/60, 8/12 bit (no 10 bit w/my PJ), and BT709/BT2020 properly.
(2018-03-22, 00:00)hdmkv Wrote: [ -> ]@wrxtasy, you can now add Zidoo X9S as being able to properly manage auto frame rate switching & resolution switching, with the right color spaces. Hope @wesk05 is able to add his (more technical) insights.
 How about 59.94?
My Epson PJ shows 60.00. From what I've read, there's no difference between 59.94 and 60.00; that technically 60Hz displays run at 59.94. Apparently some kind of holdover from the old U.S. TV days when color was added, and they had to 'slow' the refresh rate by 1% to avoid interference on then B&W sets. When I view the 1080p/59.94 test pattern I posted here with Zidoo via my Epson, the panning bars are smooth.
Thx. Added to Post #1
Any additions, bugs to Zidoo X9S Firmware testing please for auto frame rate, resolution, colorspaces etc - please direct me where to hotlink into for Post #1 of this thread.
Currently I've hotlinked to Post #144 above
Will do, thanks. X9S, X8 and X10 all benefit from improvements w/their latest beta f/w.
(2018-03-23, 01:26)hdmkv Wrote: [ -> ]My Epson PJ shows 60.00. From what I've read, there's no difference between 59.94 and 60.00; that technically 60Hz displays run at 59.94. Apparently some kind of holdover from the old U.S. TV days when color was added, and they had to 'slow' the refresh rate by 1% to avoid interference on then B&W sets. When I view the 1080p/59.94 test pattern I posted here with Zidoo via my Epson, the panning bars are smooth.
 Yes - in reality there is little-to-no commercial 60.00Hz content out there - as all broadcast content is shot 59.94Hz. (The field-rate was altered to tweak the composite chroma subcarrier away from a frequency that could have interfered with the FM sound sub-carrier on broadcasts, not just for B&W compatibility reasons. They had to alter the field rate as the line count was fixed, and the subcarrier is locked to the line-rate...)
However 59.94 isn't 60.00... The early Japanese HD systems that evolved into 1080i were originally based on 60.00Hz (they had fiendish ways of converting to 59.94 480i...) and some phone cameras may shoot at 60.00Hz - so it is important to differentiate.   Also 24.000Hz content output with 3:2 will be at 60.00Hz - and there is quite a lot of 24.000Hz content in the wild. (Quite a number of European Blu-rays are 24.000Hz)
Hi!
I want to by a 4k HDR Kodi Player and need your advice which player I should buy - Apple TV 4K or MINIX U9-H. Here are my thoughts and question about both devices:
- AppleTV has MrMc instead of "native" Kodi. MrMc is based on Kodi v16 to my knowledge, therefore, I am little bit afraid the MrMc might lag a little bit behind over time regarding features. I really like the Kodi v17 Skin and not so much the MrMc Skin...
- On the AppleTV I have to start MrMc manually. I guess there is no autorun feature for certain apps after powering the AppleTV on, or?
- I guess the Wifi/LAN performance of the AppleTV is better than compared to the MINIX U9-H, right?
- Does the AppleTV has a better performance or picture quality than the MINIX U9-H?
- Currently, I am not interested in other streaming Apps like Amazon or Netlix. My TV (LG 2017 webOS) support both anyways. Would there be an advantage using the AppleTV instead of TV Apps?
- What about audio format support? Can both devices play DD+, DD TrueHD, DD ATMOS, DTS-HD, DTS:X?
- I would want to control the player with my Harmony remote. Are there any restrictions doing that for the AppleTV or MINIX U9-H?
Thank you in advanced. I hope you can help me with my decision Smile.
Apple TV 4K with MrMC (highly modded Kodi Jarvis) advantages:
- The Apple TV 4K's - A10X Fusion SoC is a bit of a beast, it's a really impressive ARM based chipset. This results in one slick 4K HDR10 media player. Great picture quality.
- MrMC has a cool FFWD / RWD video scrubbing feature, tvOS Netflix style that shows a little video preview Picture box whilst swiping the remote's touchpad - left and right.
- Near instantaneous OTA TV channel switching with TvHeadend.
- I can even add some Picture post processing to SD TV streams.
- 7.1 HD audio is decoded to 24bit 48kHz lossless 7.1 LPCM for no loss in audio quality from Bluray sources.
- Audio can also be downmixed and output as 5.1 Dolby Digital due to the onboard Dolby Audio licence.
- The touchpad remote has an IR blaster learning function, so it can learn TV or audio receiver Infra Red volume signals. You really only need a single remote in hand then.
- The ATV 4K can also easily learn any multi buttoned Infra Red remote control you have lying around using it's easy tvOS IR learning functionality.
- Inbuilt support for Emby, TrakTV, mySQL and Plex databases.
- Recent MrMC releases include the Plex Skin as well - works better than the actual Plex App from user reports:
https://mrmc.tv/2018/03/28/mrmc-and-mrmc...th-python/
- In the future I can see MrMC branching further from Kodi with additional features you will not even get in mainstream Kodi. There is now a lot of ex-Kodi developer experience in the MrMC team.
- great App & Firmware support from the MrMC team & Apple.
Disadvantages:
- No USB port, so all video has to come from Networked file servers like a NAS, PC or HDD USB connected to a home router.
- No additional Kodi Addons or Skins can be installed to those already pre-packaged. This is already improving going forward.
- No audio passthrough, so no Atmos or DTS:X - 3D spacial audio.
- Multichannel 24bit 192kHz FLAC will be resampled and output as multichannel 24bit, 48kHz LPCM.
- No auto resolution switching to let a 4K TV upscale 1080p > 4K video content and then auto switch to a 4K resolution when watching actual 4K content. You have to do it manually in tvOS settings.
However the ATV 4K's picture upscaling is above average vs the competition so in reality it is not really needed unless you are a ultra demanding video enthusiast. There is an interesting ATV 4K picture upscaling / post processing discussion HERE (click)
- I do miss the clean, uncluttered look of Kodi Krypton's standard - Estuary Skin & the Oz Weather Addon.
- MrMC - Kodi Jarvis does not have the smart auto searching Kodi PVR Addon recording features that Kodi Krypton now has.
- The ATV 4K touchpad remote still causes me occasional issues. It's a bit small for guys with Gorilla sized hands, even with a great Fintie silicon remote cover that adds some bulk and much needed grip.
Touchpad controls are never as easy to use as physical remote buttons. The Xiaomi Mi Box's remote by comparison I consider near perfect for a minimal remote, but that does not have the cool - ATV 4K Video Thumbnail FFWD / RWD scrubbing or IR blaster functionality.
LibreELEC 8.2.4 -Kodi Krypton (my recent personal release) for S912's like the MINIX U9:
Advantages:
- boots straight into Kodi Krypton, once setup. Even faster if you copy the LE data partition to internal eMMC storage.
- a full blown Kodi Krypton with all the Skins, Addon bells and whistles you normally expect from Kodi.
- Auto resolution switching 1080p <<-->> 4K
- HD audio passthrough including Atmos and DTS:X
- LibreELEC, a Linux based OS is a lot more open to DIY so you can use the inbuilt SAMBA server and Plug in compatible TV Tuners for use as a TvHeadend server for example.
- VP9 (profile 2) hardware decoding if you come across any of that Youtube ripped content.
Disadvantages & bugs:
- it's DIY, not exactly Plug N Play. But it's easy to install LE these days, especially on MINIX S9xx devices utilising the power button for initial LE install.
- Multichannel 24bit 192kHz FLAC will be output as multichannel 16bit 192kHz LPCM
- Chroma 4:2:2 subsampling results in green video outputs (4:2:2 only big screen Projector owners beware).
- 4:4:4 10bit which you use for 24p 4K HDR is fine, both for auto refresh and auto resolution switching.
- Very subtle, occasional, rare, video frame upsets when subtitles are displayed onscreen during long camera panning scenes. I had to look really really hard to even notice this. It really does not bother me too much personally and I never see it all the time. Fixed - see HERE (click)
- Not enough CPU ponies to software decode 1080p 11Mbps Hi10P Anime. - Looks to be fixed as well !
- Slightly slower OTA TV channel switching.
Apart from that I cannot notice any differences in WiFi, LAN, or visual picture quality between the two devices. Both are fast devices and play virtually any video content you throw at them. OTA TV deinterlacing picture quality is excellent on both.
The ATV 4K's settings, has a real easy to use IR learning function to use with any IR remote.
Click HERE for Harmony remote support for use with LE on the U9.
I use the ATV 4K for beautifully smooth video playback of 24p video in Apps like Netflix and Amazon Video as well as local 25fps IPTV catchup Apps. It's really is nice to have Apps support for Frame Rate and Dynamic range matching that the Apple TV 4K tvOS Firmware provides. Features and Apps support Android TV is sorely lacking.
MrMC also gets use for OTA TV and viewing local home 1080p / 4K server content.
It's a solid dependable App but needs some more Kodi Bling IMHO packaging cleaner looking modern Kodi Skins.
EDIT: The upcoming Ariana Skin (click) shows great promise, especially with the ATV's auto "Dark Mode"
LE on the MINIX U9 is speedy, auto switches everything and has better Kodi Krypton PVR Addon support. I also like to experiment and install minimal, clean, sensible Kodi Skins (from Jurialmunkey) now and again. I prefer the MINIX A2 lite remote with it's mini keyboard because I can use Kodi keyboard shortcuts and easily custom map it with the Keymap Editor Addon.
In the end pick what features are most important to you personally. Smile
