Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
The strm files that are created by this addon from scraping another addon are not all importing into Kodi correctly. Some strm files above 4KB are not importable in Kodi. Has anyone else seen this issue? Here is a couple of examples: one works and one doesn't.
https://gofile.io/?c=OsJziQ
(2019-05-24, 18:00)eric859 Wrote: [ -> ]The strm files that are created by this addon from scraping another addon are not all importing into Kodi correctly. Some strm files above 4KB are not importable in Kodi. Has anyone else seen this issue? Here is a couple of examples: one works and one doesn't. https://gofile.io/?c=OsJziQ
Does anyone know if there's another addon that lets me do what LIT does? There are too many strm files created that Kodi won't recognize.
The LIT addon puts all metadata about a movie in the strm file. Is there a way for it to create a strm file with just a link and an nfo file for the metadata?
(2019-05-24, 20:04)eric859 Wrote: [ -> ] (2019-05-24, 18:00)eric859 Wrote: [ -> ]The strm files that are created by this addon from scraping another addon are not all importing into Kodi correctly. Some strm files above 4KB are not importable in Kodi. Has anyone else seen this issue? Here is a couple of examples: one works and one doesn't. https://gofile.io/?c=OsJziQ
Yes . There is another Addon ,it's called add to lib . I use it cause LIT doesn't work for the illegal Addon i use .
Here it is
https://forum.kodi.tv/showthread.php?tid=268997
I love it, working wonderfully.
Any chance we could add music library integration to this? I'm using Google Play EXP to listen to my Google Play Music library but it would be nice if I could integrate it into Kodi's library also.
So I guess this doesnt work on Leia?
As mentioned earlier, most of the .strm files created by LIT are not being scraped by Kodi. Only files 4kb or less are scraped!? If you edit the .strm files created by LIT to decrease the file size to 4kb or lower, they scrape fine.
Does anyone know of a workaround? LIT pulls the .strm files just fine and actually does full directories along with bypassing the next page. Adding individually is not ideal.
(2018-04-25, 12:53)manfeed Wrote: [ -> ]Hi, I just discovered your addon and I love it! Thanks for your work. I'm trying to use it with the amazon prime addon...
https://forum.kodi.tv/showthread.php?tid=331136
...the movies do play through the amazon addon and also get added to the library, but when trying to play them when browsing from the library I get a message error; do you know if your addon is compatible with the amazon addon? Thanks again!
Hi ,
I have the same issue.
I am on windows ,Kodi18.6, Bingie ,Amazon VOD
Everything adds up, I use ember media manager to scrape , but playing the STRM does nothing and on second attempt playback failed error comes up.
Could you please look into this , Thanks !
(2020-04-30, 13:44)Pug3ter Wrote: [ -> ]As mentioned earlier, most of the .strm files created by LIT are not being scraped by Kodi. Only files 4kb or less are scraped!? If you edit the .strm files created by LIT to decrease the file size to 4kb or lower, they scrape fine.
Does anybody know if that issue has been fixed in new release? Is this still being developed?
I am very happy to find your Tool. Have been searching for something like this for awhile. Thank you for making it.
I have been able to add movies to libraries very easy but I am unable or missing something trying to add TV Series. They are added into the files but they don't show up under TV Shows below the Movies. I am performing the same steps as movies but they don't seem to sync in this front screen. It only shows the usual "recently added" which is empty.
Anything, I may be missing for TV Series?
Thank you!
(2020-05-27, 17:11)rorolei Wrote: [ -> ] (2020-04-30, 13:44)Pug3ter Wrote: [ -> ]As mentioned earlier, most of the .strm files created by LIT are not being scraped by Kodi. Only files 4kb or less are scraped!? If you edit the .strm files created by LIT to decrease the file size to 4kb or lower, they scrape fine.
What service and content did you have this problem?
(2020-07-07, 06:37)derrgoo123 Wrote: [ -> ]I am very happy to find your Tool. Have been searching for something like this for awhile. Thank you for making it.
Thank you!
This probably happens due to the lack of the .nfo file and the episode id (ex: S01E01) in the file name.
The ideal scenario in my point of view is that of this example image.
I am modifying the addon to try to obtain this result, but for now it is only possible to add a series, without database.
