(2021-11-20, 12:33)beatmasterrs Wrote: [ -> ] (2021-11-20, 08:04)mark_dj Wrote: [ -> ] (2021-11-20, 01:14)beatmasterrs Wrote: [ -> ]Does this issue only affect the upper centred clearlogo? Or all clearlogo in general?
It only happens to the upper centered logos as far as I can tell.
Thanks. Could you please test the latest master? https://github.com/beatmasterRS/skin.arc...master.zip
I get a ‘failed to install add-on from zip file’ error?
Hi
Would it be possible to add an unwatched indicator for the reloaded type?
(2021-11-20, 21:17)mark_dj Wrote: [ -> ] (2021-11-20, 12:33)beatmasterrs Wrote: [ -> ] (2021-11-20, 08:04)mark_dj Wrote: [ -> ]It only happens to the upper centered logos as far as I can tell.
Maybe you should try to download the file again and rename it, or restart Kodi before installing it. Maybe this helps?
(2021-11-20, 23:01)Grumpyman Wrote: [ -> ]Hi
That would be possible, but not planned so far. Maybe in a future update
(2021-11-21, 01:09)beatmasterrs Wrote: [ -> ] (2021-11-20, 21:17)mark_dj Wrote: [ -> ] (2021-11-20, 12:33)beatmasterrs Wrote: [ -> ]Thanks. Could you please test the latest master? https://github.com/beatmasterRS/skin.arc...master.zip
That did the trick. And it’s perfect now, thank you!
(2021-10-18, 11:56)beatmasterrs Wrote: [ -> ] (2021-10-17, 22:27)hdmkv Wrote: [ -> ]Love this skin, this mod, thanks for all the work @beatmasterrs. One thing I'd like to do, but can't figure out is something other than list view when browsing into videos. The top two screenshots are from Arctic: Zephyr - Reloaded, and the bottom two from Aura.
How can I force a view so that my thumbs don't get cut off? Reloaded stays with List view no matter what other view type I choose from the list of options...
Aura
For content type files, there is only the list view, thats right. You could edit the code to your liking, to keep always the aspect ratio:
[Open]
1080i/View_50_List.xml
[Search] for lines 197, 224
xml:
<aspectratio align="center" aligny="center" scalediffuse="false">scale</aspectratio>
[Replace] with
xml:
<aspectratio aligny="center" scalediffuse="false">keep</aspectratio>
After that, save the file and reload the skin, or restart kodi for changes to take effect.
Hi I can't figure out to made a force view fore the add-ons - it always comes back to double flix mode even if I change it to another view ?
(2021-11-23, 22:27)jakepe88 Wrote: [ -> ] (2021-10-18, 11:56)beatmasterrs Wrote: [ -> ] (2021-10-17, 22:27)hdmkv Wrote: [ -> ]Love this skin, this mod, thanks for all the work @beatmasterrs. One thing I'd like to do, but can't figure out is something other than list view when browsing into videos. The top two screenshots are from Arctic: Zephyr - Reloaded, and the bottom two from Aura.
Aura
[Open]
xml:
[Replace] with
xml:
Does this affect all addons? If not, please be more specific, thanks.
is there a way to see Genre on fullscreen netfllix view widgets? If not is there any plans to add it?
I see the genre in the movie views but not in the widgets.
thanks
Hello,
I have activated autotrailer in the skin. When the trailer starts and I go back, it continues to run in the background. The whole thing is in the tmdb helper addon. But not in the main menu. Is it wanted like that? Or can I disable that? So when I go back the trailer stops
(2021-11-24, 12:33)Reichi Wrote: [ -> ]Hello,
If you go back, do you have the same viewtype as before, where the trailer began to start?
I was able to reproduce this issue. I dont know, if this can be fixed. I will try.
(2021-11-24, 02:45)terpsarlington Wrote: [ -> ]is there a way to see Genre on fullscreen netfllix view widgets? If not is there any plans to add it?
thanks
I did some tests. I will try to implement that as an option, but I can't promise anything.
I loaded the Arctic:Zephyr - Reloaded right from the Kodi skin and got a POPUP saying "something" didn't load, it may have said skin shortcuts? But not sure as it disappeared quickly... now I have this BLANK SCREEN and don't know how to get back out to default skin... this is on an Apple TV, I have the same skin on my Chromecast and it works perfect... any ideas to fix or to get back to default?
(2021-11-25, 16:38)mccaffertee Wrote: [ -> ]I loaded the Arctic:Zephyr - Reloaded right from the Kodi skin and got a POPUP saying "something" didn't load, it may have said skin shortcuts? But not sure as it disappeared quickly... now I have this BLANK SCREEN and don't know how to get back out to default skin... this is on an Apple TV, I have the same skin on my Chromecast and it works perfect... any ideas to fix or to get back to default?
There are several ways, you can try to get to the default skin, sure. You can:
- try to press "back"
- try to press "S" if you have a keyboard, to show the power menu, from which you can go to skin settings
- open the guisettings.xml, located in userdata folder, search for
<setting id="lookandfeel.skin">skin.arctic.zephyr.mod</setting>
, delete the line, save the file, restart kodi
- delete the guisettings.xml file, located in userdata folder, restart kodi
- delete the script-skinshortcuts-includes.xml file, located in addons\skin.arctic.zephyr.mod\1080i folder, restart kodi
- try to delete the skin.arctic.zephyr.mod folder, located in addons, restart kodi
