(2019-12-01, 00:16)beatmasterrs Wrote: [ -> ] (2019-11-30, 18:45)junitodx Wrote: [ -> ]beatmasterrs,
First and foremost I'd like to thank you for this great skin.
I do have a question though. I am not sure if I am doing something wrong or if this is by design but when I have movies in a collection the skin, when using the Big-Icons Flix view, attempts to fill up the entire row with covers regardless of how many movies are in the collection.
For example, I only have three OT Spider-Man movies but inside the collection it looks like this:
Is there a way to fix this in the settings that I am missing? Seems almost like a "wrap" function. Something similar also happens on the main movie screen when in the Big-Icons Flix view. Once I scroll all the way to the last movie if i continue to scroll the movies just keep scrolling along as well. I'd prefer to have it "jump" to the first movie in the playlist instead of just scrolling endlessly.
Thanks again
You are right, thats mainly a problem on infodialog for moviesets e.g.:
But when im using a list or fixedlist e.g. insteat of a wraplist, there's an "abnormal" behavior for me. When on Dialoginfo you press up, scroll and press down/back, then it may be that a few elements are not visible due to scrolling. I'm still looking for an elegant solution for that.
beatmasterrs can you tell me how you were able to pull up information on the entire movie collection?
I can pull it up for individual movies but none of my collections even has the Information option on the context menu:
(2020-05-22, 17:33)junitodx Wrote: [ -> ] (2019-12-01, 00:16)beatmasterrs Wrote: [ -> ] (2019-11-30, 18:45)junitodx Wrote: [ -> ]beatmasterrs,
Thanks again
@beatmasterrs can you tell me how you were able to pull up information on the entire movie collection?
Just by pressing "i" or the Infobutton on your remote.
I will add a button for this in the context menu, if this is possible
(2020-05-22, 20:25)beatmasterrs Wrote: [ -> ] (2020-05-22, 17:33)junitodx Wrote: [ -> ] (2019-12-01, 00:16)beatmasterrs Wrote: [ -> ]You are right, thats mainly a problem on infodialog for moviesets e.g.:
Just by pressing "i" or the Infobutton on your remote. I will add a button for this in the context menu, if this is possible
Well duh, that was obvious, can't believe I didn't try that
I always used to use my Nvdia Shield game controller to control Kodi and it doesn't have an info button. I just figured if there was no option for information on the context menu for an item then there was no information screen available. Of course when i clicked the information button on my Harmony remote the movie collection information came up just like you said.
Thanks for pointing that out
Would there happen to be an xml where wraplist could be replaced with fixedlist on this info screen as well? So that the movies within the collection don't loop endlessly like in your screenshot?
(2020-05-23, 13:11)junitodx Wrote: [ -> ] (2020-05-22, 20:25)beatmasterrs Wrote: [ -> ] (2020-05-22, 17:33)junitodx Wrote: [ -> ]@beatmasterrs can you tell me how you were able to pull up information on the entire movie collection?
That shouldn't be a problem
I am not yet happy with the behaviour either.
Please downoad
https://github.com/beatmasterRS/skin.arc...iesets.zip and test
Note: this is just a testversion. I have to look at all this again, because this behaviour also affects other lists
(2020-05-23, 13:53)beatmasterrs Wrote: [ -> ] (2020-05-23, 13:11)junitodx Wrote: [ -> ] (2020-05-22, 20:25)beatmasterrs Wrote: [ -> ]Just by pressing "i" or the Infobutton on your remote. I will add a button for this in the context menu, if this is possible
That shouldn't be a problem I am not yet happy with the behaviour either.
Please downoad https://github.com/beatmasterRS/skin.arc...iesets.zip and test
beatmasterrs I gave it a test run and now the movies in the collection info screen do not loop so that's good. I see you also made fixed list as the default view for the Big Icon-Flix view with wrap list as optional, which is great.
The only issue I noticed is when you play a movie from within the movie collection info screen. If you click the Play button on the bottom left corner the first movie in the collection plays as perfectly.
However if you click up to highlight a specific movie in the collection
The movie you selected then starts to play but it has a weird overlay of some of your library items. In my example it's a mixture of collections as well as individual movies. You then need to hit the back button for the overlay to disappear:
(2020-05-23, 14:48)junitodx Wrote: [ -> ] (2020-05-23, 13:53)beatmasterrs Wrote: [ -> ] (2020-05-23, 13:11)junitodx Wrote: [ -> ]Would there happen to be an xml where wraplist could be replaced with fixedlist on this info screen as well? So that the movies within the collection don't loop endlessly like in your screenshot?
@beatmasterrs I gave it a test run and now the movies in the collection info screen do not loop so that's good. I see you also made fixed list as the default view for the Big Icon-Flix view with wrap list as optional, which is great.
I was able to reproduce this issue. This only happens, when the "library default select action"
is not "Show information". When using "Show information" the play-button in dialogvideoinfo is closing the dialog. But I think, i've found a solution for this issue:
Please download and test:
(2020-05-24, 00:56)beatmasterrs Wrote: [ -> ] (2020-05-23, 14:48)junitodx Wrote: [ -> ] (2020-05-23, 13:53)beatmasterrs Wrote: [ -> ]That shouldn't be a problem I am not yet happy with the behaviour either.
I was able to reproduce this issue. This only happens, when the "library default select action" is not "Show information". When using "Show information" the play-button in dialogvideoinfo is closing the dialog. But I think, i've found a solution for this issue:
That seemed to fix the issue as now I can play the movie the same way I initially described and the overlay no longer pops up.
I did, unfortunately, find something else. i think at this point you are just going to stop asking me to test stuff
Ok, so the steps to reproduce are:
1. Go to a movie collection that has like 3 or 4 movies and hit info
2. On the movie collection info screen arrow up and then arrow to the right and play one of the last movies so the entire group of movies shifts to the left
3. Stop the movie, which should take you back to your main screen, then click info on that same movie collection
Seems like it remembers that the all the movies in that collection were shifted so it looks like this. In this case I have all 6 mission impossible movies but only 3 are showing and the 3 that are showing are shifted too far to the left, covering part of the poster art. To fix this I just arrow up and then arrow down again and this resets it and realigns the movies correctly
(2020-05-24, 02:20)junitodx Wrote: [ -> ] (2020-05-24, 00:56)beatmasterrs Wrote: [ -> ] (2020-05-23, 14:48)junitodx Wrote: [ -> ]@beatmasterrs I gave it a test run and now the movies in the collection info screen do not loop so that's good. I see you also made fixed list as the default view for the Big Icon-Flix view with wrap list as optional, which is great.
Please test the latest version:
I am still not really happy with the behaviour. Maybe I can think of a more elegant way to reset the container position invisibly. We will see.
(2020-05-24, 11:42)beatmasterrs Wrote: [ -> ] (2020-05-24, 02:20)junitodx Wrote: [ -> ] (2020-05-24, 00:56)beatmasterrs Wrote: [ -> ]I was able to reproduce this issue. This only happens, when the "library default select action" is not "Show information". When using "Show information" the play-button in dialogvideoinfo is closing the dialog. But I think, i've found a solution for this issue:
Please test the latest version: https://github.com/beatmasterRS/skin.arc...iesets.zip
Looks good now, no issues that I can see. I think the first time I tested I might have seen the container reset a millisecond after I hit play. Every subsequent test after that on the same, as well as other movie collections, I could not detect the reset at all even though I was specifically looking for it. Great job
(2020-05-24, 13:49)junitodx Wrote: [ -> ] (2020-05-24, 11:42)beatmasterrs Wrote: [ -> ] (2020-05-24, 02:20)junitodx Wrote: [ -> ]That seemed to fix the issue as now I can play the movie the same way I initially described and the overlay no longer pops up.
I tried to improve it again:
When all is fine, i'll push the changes to the master branch.
(2020-05-24, 13:56)beatmasterrs Wrote: [ -> ] (2020-05-24, 13:49)junitodx Wrote: [ -> ] (2020-05-24, 11:42)beatmasterrs Wrote: [ -> ]Please test the latest version: https://github.com/beatmasterRS/skin.arc...iesets.zip
Oddly enough it seems that I can now see the reset almost every time
Very good
Every day this mod is better, excellent work.
Beatmasterrs, have you been able to obtain advances in the subject of the trailers of the television series?
Regards.
(2020-05-25, 13:24)kevylluma Wrote: [ -> ]Very good
Regards.
I've seen how it works in the bingie skin. Az-leia mod now supports script.bingie.helper. Trailers for tv-shows (tv-show -and season level) are now working fine.
For local trailers I have no solution yet.
Thank you very much again.
How do we do to see the progress of the series? We have to install the script.bingie.helper.?
Regards.
OK, I see how it works, FABULOUS !!!!.
There is no challenge for you to resist, thank you very much.
Now the wait becomes more bearable until I find the solution for the trailers in local.
1,000,000 thanks !!!
