2021-07-19, 23:59
2021-08-12, 23:13
@sualfred - Is it possible to have Embuary Info just display 1 episode of a TV Show instead of showing for example 3 episodes on the same TV show in the widgets? Maybe it can group them just like Skin Helper Service Widgets does?
Regards,
Shedrock
Regards,
Shedrock
2021-08-13, 07:19
what kind of widget
2021-08-13, 11:30
Ups, I have post at the wrong place.
Sorry
Sorry
2021-08-13, 12:25
(2021-08-13, 07:19)sualfred Wrote: [ -> ]what kind of widgetSorry, I forgot to mention that. I was referring to the Emburay Info - Airing Today Widget. SH Service Widgets has this feature to group all episodes airing today into 1. I've attached a pic for reference.
The pic below shows you the setting in SHS Widgets that is used to accomplish that.
Regards,
Shedrock
2021-08-13, 15:46
Not possible with my simplified next airing feature.
2021-08-13, 16:39
(2021-08-13, 15:46)sualfred Wrote: [ -> ]Not possible with my simplified next airing feature.Thanks
2021-11-01, 22:09
I keep having this kind of errors:
I guess it's not embuary info's fault but of some dependency, could you please tell me if it can be fixed somehow? It's very frustrating since most of times Kodi just crashes after the error.
Thanks a lot!
xml:2021-11-01 20:59:23.762 T:11640 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'AttributeError'>
Error Contents: 'bytes' object has no attribute 'timestamp'
File "C:\Matrix2\portable_data\addons\script.embuary.info\plugin.py", line 5, in <module>
from resources.lib.widgets import *
File "C:\Matrix2\portable_data\addons\script.embuary.info\resources\lib\widgets.py", line 11, in <module>
from resources.lib.helper import *
File "C:\Matrix2\portable_data\addons\script.embuary.info\resources\lib\helper.py", line 15, in <module>
import arrow
File "C:\Matrix2\portable_data\addons\script.module.arrow\lib\arrow\__init__.py", line 2, in <module>
from .api import get, now, utcnow
File "C:\Matrix2\portable_data\addons\script.module.arrow\lib\arrow\api.py", line 12, in <module>
from arrow.arrow import TZ_EXPR, Arrow
File "C:\Matrix2\portable_data\addons\script.module.arrow\lib\arrow\arrow.py", line 34, in <module>
from arrow import formatter, locales, parser, util
File "C:\Matrix2\portable_data\addons\script.module.arrow\lib\arrow\parser.py", line 26, in <module>
from arrow.util import next_weekday, normalize_timestamp
File "C:\Matrix2\portable_data\addons\script.module.arrow\lib\arrow\util.py", line 6, in <module>
from arrow.constants import (
File "C:\Matrix2\portable_data\addons\script.module.arrow\lib\arrow\constants.py", line 16, in <module>
_MAX_TIMESTAMP = datetime.max.timestamp()
AttributeError: 'bytes' object has no attribute 'timestamp'
Thanks a lot!
2021-11-03, 03:05
(2021-11-01, 22:09)manfeed Wrote: [ -> ]I keep having this kind of errors:Same problem here!
import arrow
Thanks a lot!
2021-11-04, 12:30
That's a Kodi Matrix Python3 bug. Propably caused by Python 3 subinterpreters. Nothing that I can fix. To be honest, I'm also affected and it made Kodi Matrix not useable for me now. I'm also looking forward to get it fixed by someone who knows what to do.
2021-11-04, 13:21
(2021-11-04, 12:30)sualfred Wrote: [ -> ]That's a Kodi Matrix Python3 bug. Propably caused by Python 3 subinterpreters. Nothing that I can fix. To be honest, I'm also affected and it made Kodi Matrix not useable for me now. I'm also looking forward to get it fixed by someone who knows what to do.
Thanks for your explanation. I guess that explains many of the errors that I'm getting... The worst is that people blame my skin. Let's hope it gets fixed someday...
2021-11-09, 11:58
Hi ,
I was searching an extended info script alternative and working with Netflix and Amazon addon. I found it with Embuary Info and Embuary Info - Open dialog
Thanks a lot @sualfred
2021-11-28, 20:42
Hi, can anyone help with this code, I need it for videoinfo.xml
the code is totally stupid just l showing an example:
<content>plugin://script.embuary.info/movie/Similar titles,query='"$INFO[ListItem.Label]"')</content>
2021-11-28, 21:15
embuary.info has no /movie/Similar endpoint
What you need is embuary.helper
https://github.com/sualfred/script.embua...d-on-movie
But note that this only returns similar item from within your own library, if you want similar item from the whole of themovieDB then use plugin.video.themoviedb.helper:-
plugin://script.embuary.helper/?info=getsimilar&dbid=$INFO[ListItem.DBID]&type=movie
plugin://plugin.video.themoviedb.helper?info=similar&type=movie&query=$INFO[ListItem.title]
2021-11-29, 18:29
Thanks for help and advice
