2009-01-17, 03:06
2009-01-17, 07:58
dirtylion Wrote:i always get the msg
cvs -d:pserver:[email protected]:/cvsroot/lirc login
cvs [login aborted]: cannot get working directory: No such file or directory
someone can help me pls
Same problem here.
Using XBMC Live installed to HDD
UPDATE
Figured it out, you have to make sure you are in the home folder "/home/xbmc"
2009-01-17, 22:29
Today I bought a logitech harmony 895 and I'm very happy with it. but now comes the part to get xbmc working.
I'm using the Antec Micro Fusion 350 as enclosure with Soundgraph iMON IR/LCD.
Standard it comes with a tiny remote named veris rm100 (with the settings on the first page only back and enter are working)
So now I want my logitech to be configured as a MCE remote but i'm not exactly sure how to do this.
Anyone with a logitech remote managed to fix this?
2009-01-18, 01:35
dirtylion Wrote:maybe someone who use xbmc live with antec case and rm200 remote can explain how he get lirc working pls...
That would be sweet !
I have tried for two days now without any success.
So if anyone could help it would be much appreciated.
2009-01-18, 06:11
Hello everybody,
I have an Antec Fusion Remote. Following this great tutorial, I got the remote working - well I got only to the point I could see some code by using the irw.
BUT - the LCD seems decided to not work. Or to be more precise lcdproc seems decided to not work. I manage to display the clock, to erase it and to completely turn off the LCD by using those perl commands. Apart from that, nothing works.
I tested lcdd&lcdproc in many ways - it seems that the communication between the client & the server is OK - I tested using the ncurses driver, I have the information passed to the server which afterwards passes it in the ncurses window. I cannot understand why it doesn't work using imon driver - it even tells me that it's using the /dev/lcd0 device for writing - nothing at all is displayed on the LCD.
Please help me, please, I am get dizzy.
Thanks a lot to everybody who might have a suggestion.
2009-01-18, 07:05
I have messages through "dmesg" which show smth like this:
/var/lib/dkms/lirc/0.8.3~pre1/build/drivers/lirc_imon/lirc_imon.c: lcd_write: invalid payload size: 32 (expecting 8)
Please help, many thanks !
2009-01-18, 13:07
Hi realn.
I have to ask do you use XBMC Live, or did you install XBMC into a preinstalled Ubuntu ?
2009-01-18, 14:31
Hi, thanks for the support. I have it on a preinstalled Ubuntu. Anyway, please help me if you have any suggestions. Thanks a lot !
2009-01-19, 21:45
philippeb06 Wrote:Hello and thank you for your great help!
However, I'd like to add some comments as you solution did not work "out of the box" for me.
I am using an Antec Fusion Remote Black with a RM200 VERIS remote and add some problems getting the two lircd working together.
I ran two irrecord, the first one on /dev/lirc0 putting configuration on /etc/lirc/remote1.conf about the pad and the numbers on remote and the second one on /dev/lirc1 putting configuration on /etc/lirc/remote2.conf about the other keys.
Code:sudo irrecord /etc/lirc/remote1.conf -d /dev/lirc0 --disable-namespace
sudo irrecord /etc/lirc/remote2.conf -d /dev/lirc1 --disable-namespace
Once this done, I ran the following commands:
Code:sudo /usr/local/sbin/lircd --driver=default --device=/dev/lirc0 --pidfile=/var/run/lirc0.pid --listen=8765 /etc/lirc/remote1.conf
sudo /usr/local/sbin/lircd --driver=default --device=/dev/lirc1 --pidfile=/var/run/lirc1.pid --connect localhost:8765 --output=/dev/lircd /etc/lirc/remote2.conf
This is now working and the irw mixes the two parts of the remote.
Hope it will help
Philippe
philippe: Could you please provide the conf-files you've recorded with irrecord? I can record on /dev/lirc0 but on /dev/lirc1 is always busy (even though I thought that I've made sure no process is using it).
/Andreas
2009-01-23, 01:13
Everything goes fine until I run this in the howto:
Can anyone shed some light on what's causing this.
sudo dpkg-reconfigure lirc-modules-source
Quote:bmc@htpc:~/lirc$ sudo dpkg-reconfigure lirc-modules-source
Removing all DKMS Modules
Done.
Adding Module to DKMS build system
Doing initial module build
Error! Build of lirc_imon.ko failed for: 2.6.24-23-generic (i686)
Consult the make.log in the build directory
/var/lib/dkms/lirc/0.8.3~pre1/build/ for more information.
Installing initial module
Error! Could not locate lirc_atiusb.ko for module lirc in the DKMS tree.
You must run a dkms build for kernel 2.6.24-23-generic (i686) first.
Done.
xbmc@htpc:~/lirc$
2009-01-24, 03:36
I have got my "Antec Fusion Remote" case working atleast somewhat together with the RM200 remote that came with it (ubuntu 8.10 and cvs lirc as suggested here).
It seems to me that remote commands are recieved on /dev/lirc0 and the volume knob on the case is on /dev/lirc1, both of them are working at the same time when using irw, except for one detail: Only about half of the buttons on the remote seems to be working. All buttons that work begins with either 0x01 or 0x02, and those that do not work begin with 0x2 (These 0x2 buttons does not register at all in irw/mode2 --raw)
Anyone got any idea what could be causing this behaviour?
snippets from the remote conf:
begin remote
name rm200d1.conf
bits 64
eps 30
aeps 100
one 0 0
zero 0 0
gap 139998
ignore_mask 0x0000000000000301
min_repeat 1
toggle_bit 0
begin codes
KEY_EXIT 0x2881d5b700000201 # AppExit FAILS
KEY_POWER 0x289115b700000201 # Power FAILS
MouseKeyboard 0x299115b700000201 # Mouse/Keyboard FAILS
KEY_1 0x0200001e00000201 # 1 WORKS
KEY_2 0x0200001f00000201 # 2 WORKS
KEY_UP 0x0100800000000201 # Pad Up WORKS
KEY_DOWN 0x01007f0000000201 # Pad Down WORKS
end codes
end remote
2009-01-24, 19:21
NismoC32 Wrote:Code:sudo dpkg-reconfigure lirc-modules-source
Quote:Error! Could not locate lirc_atiusb.ko for module lirc in the DKMS tree.
Done.
The lirc_atiusb module failed to build (probably because the old atiusb code is incompatible with the new lirc_dev code). I had the same problem and cleaned up all the devices I don't need.
I could send you my cleaned up code but I patched it for my 045e:0039 device. Which device do you have?
2009-01-24, 19:27
todderod Wrote:Anyone got any idea what could be causing this behaviour?
Something went wrong when recording your buttons. Your button codes look kind of strange. My lirc configs look like this:
lirc_imon.0.conf
begin remote
name IMON_RM200
bits 32
eps 30
aeps 100
one 0 0
zero 0 0
post_data_bits 32
post_data 0x0
gap 200000
toggle_bit 0
begin codes
KNOB_LEFT 0x01000080
KNOB_RIGHT 0x0100007F
KNOB_UP 0x01008000
KNOB_DOWN 0x01007F00
BACKSPACE 0x0200002A
SELECT 0x0200002C
LMENU 0x02800000
RMENU 0x02000065
LMOUSE 0x01010000
RMOUSE 0x01000000
ESCAPE 0x02000029
ENTER 0x02000028
NUM_0 0x02000027
NUM_1 0x0200001E
NUM_2 0x0200001F
NUM_3 0x02000020
NUM_4 0x02000021
NUM_5 0x02000022
NUM_6 0x02000023
NUM_7 0x02000024
NUM_8 0x02000025
NUM_9 0x02000026
NUM_STAR 0x02200025
NUM_HASH 0x02200020
end codes
end remote
lirc_imon.1.conf
begin remote
name IMON_RM200
bits 64
eps 30
aeps 100
one 0 0
zero 0 0
gap 195989
min_repeat 2
toggle_bit 0
begin codes
APP_EXIT 0x288195B700000201
POWER 0x289115B700000201
RECORD 0x298115B700000201
PLAY 0x2A8115B700000201
EJECT 0x29B195B700000201
FAST_REW 0x2A8195B700000201
PAUSE 0x2A9115B700000201
FAST_FWD 0x2B8115B700000201
SKIP_PREV 0x2B9115B700000201
STOP 0x2B9715B700000201
SKIP_NEXT 0x298195B700000201
MOUSE_KEYB 0x299115B700000201
APP_LAUNCH 0x29B715B700000201
GO 0x2AB195B700000201
DISC 0x299395B700000201
TASKSW 0x2A9395B700000201
MUTE 0x2B9595B700000201
VOL_UP 0x28A395B700000201
VOL_DOWN 0x28A595B700000201
CHAN_UP 0x289395B700000201
CHAN_DOWN 0x288795B700000201
TIMER 0x2B8395B700000201
VIDEOS 0x2B8515B700000201
MUSIC 0x299195B700000201
PICTURES 0x2BA115B700000201
TV 0x28A515B700000201
BOOKMARK 0x288515B700000201
THUMBNAIL 0x2AB715B700000201
ZOOM 0x29A595B700000201
FULLSCREEN 0x2AA395B700000201
DVD 0x29A395B700000201
MENU 0x2BA395B700000201
SUBTITLES 0x298595B700000201
AUDIO 0x2B8595B700000201
end codes
end remote
2009-01-24, 19:49
Temar Wrote:The lirc_atiusb module failed to build (probably because the old atiusb code is incompatible with the new lirc_dev code). I had the same problem and cleaned up all the devices I don't need.
Hey thanks for the reply, I have this device 15c2:0038. It came with my Silverstone CW02 case.
After starting from scratch again I managed to get the "irw" to detect all my buttuns except the knob button witch is only detected like this, no mater where on the knob i press:
0100800000000000 00 knop lircd0.conf
0100800000000000 01 knop lircd0.conf
0100800000000000 02 knop lircd0.conf
0100800000000000 03 knop lircd0.conf
0100800000000000 04 knop lircd0.conf
I have no idea why. UPDATE look at next post.
What did you do to assign the different config files to right device so it is there when you reboot?
Now I have enter this command everytime I reboot:
Quote:/usr/local/sbin/lircd --driver=default --device=/dev/lirc0 --pidfile=/var/run/lirc0.pid --listen=8765 /etc/lirc_imon.0.confThe other problem is that XBMC doesn't pick up on any buttons. (Any chance you can post your Lircmap.xml file?)
/usr/local/sbin/lircd --driver=default --device=/dev/lirc1 --pidfile=/var/run/lirc1.pid --connect localhost:8765 --output=/dev/lircd /etc/lirc_imon.1.conf
And neater does the display, but using the pearl
perl -e 'print pack "H*", "80000000091e0088"' > /dev/lcd0
PS: Are you sure your device is 045e:0039 ? My search on this number it comes up as Microsoft Intellimouse
2009-01-24, 20:19
Gues what Temar.
I copied your lirc_imon conf files and wouldn't you know the knob button works
Well it looks like the knob is a bit sensitive I can't get under four recording in a row by just touching it in irw
Is there a setting for fixing this ?
The only thing missing now is to get XBMC to bother with them.
Where does XBMC look for the Lircmap.xml file ?
I have it in /home/xbmc/.xbmc/userdata/
But doesn't work.
Have I forgot to install somthing, do you need the xbmc-event packages ?
I have only installed xbmc package
But doesn't work.
Quote:sudo apt-get install xbmc
