2008-12-20, 18:39
2008-12-20, 19:45
Done and done. Posted to #5508
2008-12-20, 19:49
CapnBry Wrote:Done and done. Posted to #5508
Thanks, creating a test build now.....
2008-12-20, 20:09
Upped XBMCSetup-Rev16618-jester-intel-test with CapnBry's diff
2008-12-20, 20:27
I can confirm the patched build works but must be used with the -fs attribute removed.
2008-12-20, 22:15
EDIT/REMOVED. sorry, wrong thread.
2008-12-21, 00:51
HexusOdy Wrote:I can confirm the patched build works but must be used with the -fs attribute removed.
i wonder why forcing fullscreen on startup changes vsync behaviours.
2008-12-21, 16:18
Jester Wrote:Upped XBMCSetup-Rev16618-jester-intel-test with CapnBry's diff
Hi CapnBry,
Just tried your intel test build on my AOpen MP-45DR. The tearing/vsync issue is solved but now pictures don't show anymore, not even thumbnails?
I've also tried your build on my other computer with a nvidia gfx card and pictures do show on nvidia so looks like it's related to the intel gfx again??
Keep up the good work!
Thanks,
Net
2008-12-21, 17:18
NeTaXe Wrote:Hi CapnBry,
Thanks,
Net
Thats odd Netaxe. I don't get that on mine. Maybe try uninstalling and reinstall?
2008-12-21, 17:22
Thanks,
Net
Maybe on your other machine you are missing some .dll files that another thread mentioned...
2008-12-22, 13:16
Any update on this being applied to the main SVN branch?
2008-12-22, 14:35
HexusOdy Wrote:Any update on this being applied to the main SVN branch?
maybe ask for it in the ticket, or ask CapnBry to do so...
2008-12-22, 16:34
NeTaXe Wrote:Hi CapnBry,I have no idea why this would happen but I can't imagine it is related to the change I made.
As for getting into trunk, I don't have commit access to SVN, you'll have to wait until it gets picked up by someone else. I'd avoid repeated posting to the ticket though, as that just gets annoying. I'll pm Jonathan to let him know the status though.
2008-12-23, 21:28
Thanks,
Net
Hi, i had the same issue.
You need the following dlls: MSVCP70.DLL, msvcp71.dll, msvcr71.dll and you can get them from http://www.dll-files.com
I hope it will help you. Best of luck !
2008-12-25, 19:30
mdalacu Wrote:Hi, i had the same issue.
Where do these files need to be placed?
