onebyside Wrote:"font tahoma does not support style regular"
was this ever solved
Win 7/64
here is the solution if anyone else is having the same issue
this error seem to happen when tahoma font is corrupted in windows for some reason,
try overwriting it in your windows directory, you can get a copy from
http://www.webpagepublicity.com/free-fonts/t/Tahoma.ttf
make sure you restart your windows after you copied the file.
kay.one Wrote:can you provide a copy of your logs,
thanks,
Sure, here you have:
2009-07-23 13:07:36.2187-XbmcUpdate.Program.Main|Info|************************************************************************
2009-07-23 13:07:36.4218-XbmcUpdate.Program.Main|Info|XBMCUpdate v0.7.9.0 Starting up
2009-07-23 13:07:36.5468-XbmcUpdate.Program.Main|Info|Framework version installed: Fx35
2009-07-23 13:07:36.5468-XbmcUpdate.Program.Main|Info|************************************************************************
2009-07-23 13:07:36.5468-XbmcUpdate.Program.IsAnotherInstanceRunning|Info|Checking for another instance of XBMCUpdate
2009-07-23 13:07:36.5468-XbmcUpdate.Program.IsAnotherInstanceRunning|Info|Instances of XBMCUpdate Detected: 1
2009-07-23 13:07:36.7031-XbmcUpdate.UpdateEngine.UpdateManager..ctor|Info|Creating temporary folder at: C:\Documents and Settings\FidoBoy\Escritorio\XBMC Updater\temp\
2009-07-23 13:07:38.0625-XbmcUpdate.UpdateEngine.XbmcManager.GerVersion|Info|No version files were found. The latest revision will be installed on next update
2009-07-23 13:07:38.4218-XbmcUpdate.UpdateEngine.XbmcManager.GerVersion|Info|No version files were found. The latest revision will be installed on next update
2009-07-23 13:07:39.2812-XbmcUpdate.SelfUpdate.SelfUpdateManager.DownloadUpdate|Info|Initiating Self-update. Local version:0.7.9.0
2009-07-23 13:07:39.2968-XbmcUpdate.SelfUpdate.SelfUpdateManager.SelfUpdateCleanup|Info|Preforming Selfupdate Cleanup
2009-07-23 13:07:39.4531-XbmcUpdate.Settings.GetConfigValue|Warn|Unable to find config key 'SelfUpdateUrl' defaultValue:'http://code.google.com/p/xbmcupdate/downloads'
2009-07-23 13:07:39.4687-XbmcUpdate.Tools.HtmlClient.GetPage|Trace|Attempting to connect to 'http://code.google.com/p/xbmcupdate/downloads'
2009-07-23 13:07:42.4218-XbmcUpdate.Tools.HtmlClient.GetPage|Fatal|An error has occurred while downloading build list from the server. Se ha especificado una dirección IP no válida.
2009-07-23 13:07:42.4218-XbmcUpdate.SelfUpdate.SelfUpdateManager.DownloadUpdate|Error|An error has occurred while checking for Application update.Se ha especificado una dirección IP no válida.
2009-07-23 13:07:42.4218-XbmcUpdate.UpdateGui.InitiateSelfupdate|Error|An error has occurred while checking for Application update.Se ha especificado una dirección IP no válida.
2009-07-23 13:07:42.4218-XbmcUpdate.UpdateEngine.XbmcManager.GerVersion|Info|No version files were found. The latest revision will be installed on next update
I get a "Unknown local build." Why?
I am using XBMC 9.04.1 on Windows 7
Is it the first time you ran the updater client?
simphax Wrote:I get a "Unknown local build." Why?
Thats completely normal if you are running XBMCUpdate for the first time.
ah ok thanks
kay.one Wrote:Thats completely normal if you are running XBMCUpdate for the first time.
I have a media center pc with windows 7, and have just updated to the latest build. Afterwards it doesn't play my movies?
daniel123 Wrote:I have a media center pc with windows 7, and have just updated to the latest build. Afterwards it doesn't play my movies?
it might be a bad build.
Same here. I think the file "xbmc/system/players/dvdplayer/avutil-50.dll" is broken. Could be because of the ffmpeg update.
New build on the way. Hopefully it cures this issue.
I just wanted to post and tell you guys how awesome this app is - I am continually blown away by the smart and inventive people involved with XBMC. Amazing work.
deepblue Wrote:I just wanted to post and tell you guys how awesome this app is - I am continually blown away by the smart and inventive people involved with XBMC. Amazing work.
+1 :p
Thankyou so much for this program! It has made life a million times easier for those of us not fluent with svn download tools!
Great work guys. A great windows app.
Very much appreciated.
I really appreciate all your feedback, I haven't been able to put alot of time on the app recently, mostly due to work and Shadow complex.
hopefully that will change soon and i'll get to spend a little more time on the app.
