2009-04-16, 20:11
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
2009-04-16, 21:25
Shadok Wrote:Does your updater allow us to choose the installation method ?
(eg. where to put the user data)
the updater will just follow how the XBMC was originally installed, so i recommend you install XBMC manually for the first time. and use XBMCUpdate to update after that.
2009-04-17, 03:10
Sorry kay.one, i've missed that... I was sure that my installed version was the self-update one... I'll remain testing your application. Thanks man.
2009-04-17, 05:44
is the built-in scheduler supposed to work? Mine is grayed out?
2009-04-17, 20:23
Using XBMC Version 0.72 and I noticed last night when I was updating my build, it gave me an error after it was finished downloading .. I pressed ok on the error dialog and it extracted the build and installed it ...
2009-04-17, 20:36
CrashX Wrote:Using XBMC Version 0.72 and I noticed last night when I was updating my build, it gave me an error after it was finished downloading .. I pressed ok on the error dialog and it extracted the build and installed it ...Upload your log.
2009-04-17, 20:38
Can you please send me acopy of the logs or post it in pastebin.com
2009-04-18, 02:54
Livin Wrote:is the built-in scheduler supposed to work? Mine is grayed out?
yes - no - maybe ?
2009-04-18, 03:49
Livin Wrote:yes - no - maybe ?
No, it doesn't work. I put it there as a place holder. I was planning to put it there but don't know if there is much interest in it. So its on hold for now.
2009-04-18, 15:23
Had the same issue. Upgrade went well but my clipboard screwed with me so missed the output when i closed the error.
Can't remember exactly but it was something with Jet-engine or something like that (no I was not high)
2009-04-18, 16:38
i've just downloaded this useful utility, but i only get this error:
it doesn't work
Initiating Self-update. Local version:0.7.2.0
Preforming Selfupdate Cleanup
Attempting to connect to 'http://code.google.com/p/xbmcupdate/downloads'
An error has occurred while downloading build list from the server. Se ha especificado una dirección IP no válida.
An error has occurred while checking for Application update.System.NullReferenceException: Referencia a objeto no establecida como instancia de un objeto.
en XbmcUpdate.Tools.HtmlClient.GetPage(String strUrl) en D:\OpenSource\xbmcupdate\trunk\XBMCUpdate\Tools\HtmlClient.cs:línea 48
en XbmcUpdate.SelfUpdate.SelfUpdate.GetLatestBuildInfo() en D:\OpenSource\xbmcupdate\trunk\XBMCUpdate\SelfUpdate\SelfUpdate.cs:línea 92
en XbmcUpdate.SelfUpdate.SelfUpdate.DownloadUpdate() en D:\OpenSource\xbmcupdate\trunk\XBMCUpdate\SelfUpdate\SelfUpdate.cs:línea 38
it doesn't work
2009-04-18, 16:44
fidoboy Wrote:i've just downloaded this useful utility, but i only get this error:Do you have the requirements?
it doesn't work
Quote:XBMCUpdate requires .NET Framework Version 2.0 or Higher
2009-04-18, 16:51
Yes, i've .NET 2.0 framework installed on Windows XP Pro SP3
2009-04-18, 19:29
kay.one Wrote:Can you please send me acopy of the logs or post it in pastebin.com
Successfully downloaded html page http://code.google.com/p/xbmcupdate/downloads
Trying to parse out the builds list from HTML string
Latest build available from the server: 0.7.2
You have the most recent build of XBMCUpdate. No Update is necessary
Selfupdate preparation took 0.4307427s
2009-04-18, 20:05
abusharif Wrote:Had the same issue. Upgrade went well but my clipboard screwed with me so missed the output when i closed the error.
there is a logs folder in your XBMCUpdate folder, if you send me the files in there i could see what is causing this.
