Well, I know that, but the last build for the updater was still OpenGL and as far as I know you can choose between building for OpenGL and DirectX.
That build wasn't released for the updated. There haven't been any builds available for the updated client since the alpha process started. I planned to release some for it, but I am waiting to hear back from Kay.one. Unless someone else can come forward with some direct linkable bandwidth, these updates will have to wait.
kricker Wrote:That build wasn't released for the updated. There haven't been any builds available for the updated client since the alpha process started. I planned to release some for it, but I am waiting to hear back from Kay.one. Unless someone else can come forward with some direct linkable bandwidth, these updates will have to wait.
are there plans to support the camelot build too? as there are no new ones for babylon I think about changing to camelot project but i dont know if this is a resonable step. as its still beta an babylon is working fine for me....what do you think
I plan to. I just need to hear back from Kay.one.
kricker Wrote:i plan to. I just need to hear back from kay.one.
tia!!!
Hello,
I just downloaded the app (0.7.9.0) but when checking for updates, I have the error message "An error ocured while checking for updates". Before that, the app is not responding.
I am running it on win7.
Here is the log:
http://pastebin.com/m48347863
cault Wrote:Hello,
Here is the log:http://pastebin.com/m48347863
uhm...probably because we have a new build, being version 9.11 now pas alpha and beta stage and called Camelot.
I think you either need a new SVN address (if there is one yet?) or just download the build from the main website
http://www.xbmc.org
I think it's actually working again... last night I was running the official Camelot release, and it found a newer one...
Could the default skin “
Confluence“ please be included in theese autoupdates? Right now it removes it every time you install a new update.
MrT Wrote:Could the default skin “Confluence“ please be included in theese autoupdates? Right now it removes it every time you install a new update.
it shouldn't be removed since XBMCUpdate doesn't delete any files, it just copies the new files over the old ones.
kay.one Wrote:it shouldn't be removed since XBMCUpdate doesn't delete any files, it just copies the new files over the old ones.
Okey? Weird. I'll have to look into what happend for me then.
I would like to use this client to install only the GL version until such time as the DX version catches up with the features/fixes i need.
Can it be configured to do so?
If ikons makes the GL builds, then yes you can. GL is no longer the default build option. I see ikons is still making builds and I am just assuming he may be upping to the location for the updater client.
I cannot see any options in the client to specify.
I can manually install Icons exe builds but the zip builds will be DX.
What am I missing?
