Looks like I got things back on track. Builds are working again.
kricker Wrote:Looks like I got things back on track. Builds are working again.
Looks like its working
How can I set it up with scheculer? Is there a parameter to pass in so that it runs automatically?
Put it in your Windows scheduler. Use the " -update" parameter for it to run automatically.
Its a bit behind again
Not now
Is there a parameter to re-open xbmc after an update or is changing it in the settings enough to get it to restart after?
I run a bash script on a cron job from my unraid server to update my library at 6AM everyday and it won't work unless XBMC is open
I think having it set so in the settings is all you need.
Sorry for all the questions
What time are the build normally on the FTP server by?
EDIT: Ignore that, just saw the link in your signature
The FTP site is in France. The time is shown as such. The builds process each night at 1 am EST. They seem to be online usually by 1:45 am EST.
For your information, time on the server is set to GMT+1 with DST enabled so GMT+2 right now.
Been working fine for a while now, just noticed this error though:
Quote:An error has occurred during updateCannot find central
I have the same issue, i think it's an issue with last build.
Wait for next one, it will probably be fixed.
Did that error come from the updater or from XBMC?
The updater show it but once the download and archive decompression is done.
It happends when the install phase start.
I thought it was just me. Same problem here.
