hubi2000 Wrote:Thanks Man! Always wanting this for my mobile.
Testet it, almost everything works fine.
Two points: The Remote looks like this:
http://img405.imageshack.us/i/remoten.jpg
on my Acer P300, resolution is: 240x400
And my second thought: A volume control would be nice.
Thanks for your work so far!
mine remote also looks like this
i m getting this error on opening movie tv shows or anything(other than remote...it works fine)
XBMC Remote for WinMo.exe
WebException
An error message is available for this exception but cannot be displayed because these messages are optional and are not currently installed on this device. Please install ‘NETCFv35.Messages.EN.wm.cab’ for Windows Mobile 5.0 and above or ‘NETCFv35.Messages.EN.cab’ for other platforms. Restart the application to see the message.
at System.Net.HttpWebRequest.finishGetResponse()
at System.Net.HttpWebRequest.GetResponse()
at XbmcJson.JsonRpcClient.Invoke(Type returnType, String method, Object args)
at XbmcJson.JsonRpcClient.Invoke(String method, Object args)
at XbmcJson.XbmcVideoLibrary.GetMovies(String[] fields, String sortMethod, String sortOrder, Nullable`1 start, Nullable`1 end)
at XbmcJson.XbmcVideoLibrary.GetMovies()
at XBMC_Remote.MovieForm.frmListDemo_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form._SetVisibleNotify(Boolean fVis)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at XBMC_Remote.MainForm.OnClickGeneric(Object Sender)
at StedySoft.SenseSDK.SensePanelItem._notifyClick()
at StedySoft.SenseSDK.SensePanelItem.OnMouseUp(Int32 x, Int32 y)
at StedySoft.SenseSDK.SenseListControl.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WnProc(WM wm, Int32 wParam, Int32 lParam)
at System.Windows.Forms.Control._InternalWnProc(WM wm, Int32 wParam, Int32 lParam)
at Microsoft.AGL.Forms.EVL.EnterMainLoop(IntPtr hwnMain)
at System.Windows.Forms.Application.Run(Form fm)
at XBMC_Remote.Program.Main()
