solver, any update on the texture issue with the atv2?
Also I was wondering if you could implement a feature to use fanart for visualization? Since the atv2 does not have visualization implemented the screen just goes black. Would be nice to have a feature to set to a folder or use the xbmc databse to show some pictures.
Thanks for your work on this!
rflores2323 Wrote:solver, any update on the texture issue with the atv2?
Sorry, I haven't had time to look at it for some time. I'll let you know when I do.
rflores2323 Wrote:Also I was wondering if you could implement a feature to use fanart for visualization? Since the atv2 does not have visualization implemented the screen just goes black. Would be nice to have a feature to set to a folder or use the xbmc databse to show some pictures.
Please don't take this the wrong way but I think it would be a waste of time. The next version for iOS will probably have these things corrected making whatever code I write for it obsolete. Have you tried compiling from trunk? It may already have been corrected.
BUG REPORT - Can you solve that problem?
What steps will reproduce the problem?
1. install grooveshark addon through the addons-menu in xbmc
2. start grooveshark addon
3. error occurs immediately
What is the expected output? What do you see instead?
Unable to get a new session ID. Wait a few mintes and try again.
What version of the script are you using?
dunno. Installed it today through the addons-menu in xbmc
What revision of XBMC are you using?
SVN 25.07.2010
What platform are you using? (XBOX, Linux, Windows, Mac, Live)
Linux
Will there be an update that makes the script to shuffle the music in your playlist or is allready there? Please tell me if there is shuffle or if it will come later!
CyrusQ Wrote:BUG REPORT - Can you solve that problem?
SVN 25.07.2010
Linux
I can't do anything without a debug log. PLease upload one to pastebin and I'll have a look
rymanjohan Wrote:Will there be an update that makes the script to shuffle the music in your playlist or is allready there? Please tell me if there is shuffle or if it will come later!
The script integrates with XBMC's player controls. So turn on shuffle in XBMC and the playlist will be shuffled.
I must be blind but cant find it! Have looked in settings and in Grooveshark settings but still no clue where it is...
Can you please explain exactly what I must do?!
Thanks anyway
rymanjohan Wrote:I must be blind but cant find it! Have looked in settings and in Grooveshark settings but still no clue where it is...
Thanks anyway
Turn on debugging in the script and have a look here:
http://wiki.xbmc.org/index.php?title=Log_File
rymanjohan Wrote:Thanks but dont know how that will help me?
It tells you where the log file is. A detailed description of the issue is in that file which is what I need to figure out what is causing the error
solver,
Is searching disabled at the moment? Trying to use the search feature does nothing. Can post a debug log if necessary.
Hi there.
After installing this script on ATV2 where do I add my grooveshark login data in order to use it?
Hutch Wrote:solver,
It's working fine here. Could you post the debug log? Maybe that'll shed some light on it
depro Wrote:Hi there.
Bring up the context menu on the grooveshark addon and click on addon settings
