furii Wrote:just an fyi then. the gt240 doesn't officially support hd audio bitstreaming. truehd will most likely work fine but dts-hd will be hit or miss. you'd have to upgrade to a fermi based card to get both working for sure. that said, i wasn't able to get dts-hd to work even with a fermi based card and my vsx-1020. i tried with a gt430 and gt520 which other people have gotten to work fine. hopefully it's just a problem with my specific model and not pioneer in general.
The strange thing is that I've gotten it to work with the ATI card under windows with one of the pre-compiled releases.
[ 24.348024] HDMI: detected monitor SC-05
[ 24.348026] at connection type HDMI
[ 24.348029] HDMI: available speakers: FL/FR LFE FC RL/RR RLC/RRC
[ 24.348033] HDMI: supports coding type LPCM: channels = 2, rates = 44100 48000 88200 176400 192000 384000, bits = 16 20 24
[ 24.348036] HDMI: supports coding type LPCM: channels = 8, rates = 44100 48000 88200 176400 192000 384000, bits = 16 20 24
[ 24.348039] HDMI: supports coding type AC-3: channels = 6, rates = 44100 48000 88200, max bitrate = 640000
[ 24.348042] HDMI: supports coding type DTS: channels = 7, rates = 48000 88200 176400 192000, max bitrate = 1536000
[ 24.348044] HDMI: supports coding type DSD (One Bit Audio): channels = 6, rates = 48000
[ 24.348046] HDMI: supports coding type E-AC-3/DD+ (Dolby Digital Plus): channels = 8, rates = 48000 88200
[ 24.348048] HDMI: supports coding type DTS-HD: channels = 8, rates = 48000 88200 176400 192000 384000
[ 24.348050] HDMI: supports coding type MLP (Dolby TrueHD): channels = 8, rates = 48000 88200 176400 192000 384000
[ 24.348053] HDMI: supports coding type WMAPro: channels = 8, rates = 44100 48000 88200 176400 192000
It detects all the specs of the receiver just fine. I might go pick up a new video card tomorrow night and give it a shot. It would suck if things just didnt work with the pioneers considering they make some of the best receivers!
I tried the tests using aplay and all i got was static. Might just be because of the video card.
XBMC Is segfaulting when i change some of the audio output settings. I'll throw up the debug log later but not sure how much good it'll do since everyone seems to be on vacation
